Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 08-16-2011, 12:02 PM   #1
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
Question Tactrix OpenPort 2.0 SD logging?
Ok, hoping to get some logs from my car tonight. I am searching around RomRaider and OpenECU websites/forums and I am getting some conflicting data. I think it is due to the initial posts in FAQ's or links I am guided too not being updated, and in some cases, not being clarified.
Basically, I want to know the basics and how to just get the logs onto the SD card, as well as if there is a way to pull a log, stop it, and restart logging on a separate file while driving (I believe there is or used to be an option to use the defogger button for this).
Also, do we need to copy the appropriate text file from the logger definitions to the SD and rename it to logcfg.txt anymore? I check one FAQ it says to do so, check another and it says not too. My head is spinning from data absorption
I think I have most of the pieces to this puzzle, just need some input to solidify this stuff.
ScubaruImpreza05 is offline   Reply With Quote
Old 08-16-2011, 01:10 PM   #2
fenix-silver
Member#: 231700
2004 WRX Wagon
You can still use the rear defroster button to start/stop logging. If you look around the OpenECU forum in the standalone logging thread, there is a website that someone created to generate the log config file for you. Create that file, copy it to the SD card and go log.
fenix-silver is offline   Reply With Quote
Old 08-16-2011, 03:45 PM   #3
ScubaruImpreza05
Member#: 74041
SV650 For sale
Is it this link?: http://www.romraider.com/forum/viewt...hp?f=32&t=5581
Says it is no longer in developement...
Old 08-16-2011, 05:27 PM   #4
unknown001
Member#: 156326
2011 RA
03 bugiftw for the track
Default :
The .exe in the first post will generate the file you need to copy to the sd card for standalone logging. It can be activated via coolant temp, RPM, or the rear defogger like fenix said above.
http://forums.openecu.org/viewtopic.php?f=57&t=4396
The newest beta of romraider logs much faster than even the standalone logger so you'll be losing resolution by using sd logging.
unknown001 is offline   Reply With Quote
Old 08-17-2011, 08:22 AM   #5
ScubaruImpreza05
Member#: 74041
SV650 For sale
You mean I should log via the USB? All I have is a Mac OS X10.5 laptop to take to the car.
I downloaded and setup MOST of the definitions last night, but I didn't see a place to put the ECU definitions; unless it automatically finds them once I find the folder for the Logger definitions. Which would be a problem since I created separate folder for the unzipped definition files. Once I loaded the Logger definitions, it did show the monitors I could set to test (a metric ton!) and did display individual car models and the ROM versions.
Hopefully I did it right.
PS - Does it matter if you go back and forth between a MAC and a Windows OS assuming both versions have the most up to date definitions? I installed and setup everything(I think) on my Vista 64-bit OS Desktop; but my in car work will be on the Mac Laptop.
Old 08-17-2011, 10:25 AM   #6
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
The config maker uses your romraider defs to show the list of parameters.
Fast polling is actually slower than sdcard high speed logging, however the sd card logging is way too fast and provides too much data IMO. Airboys spreadsheet wont even graph that much data. Fast polling (in romraider rc9) is the perfect amount of data imo.
D0nets is offline   Reply With Quote
Old 08-17-2011, 07:53 PM   #7
ScubaruImpreza05
Member#: 74041
SV650 For sale
I must not be understanding something.
I loaded up RomRaider, installed the ECU definitions and the logger definitions.
I opened ECUFlash and when I try to add car.xml for my 2.5i, it lists a few ROM's but I don;t know which one to choose.
I tried using the Config creator listed, but I get an error:
fatal error
logcfg Mainform Form_Load Error:91(10420) Object variable or
With blcock variable not set
I plugged the Tactric OP2 in, with my SD card, and it reads as a drive, but there is nothing on it. It is formatted FAT32.
Old 08-19-2011, 08:16 AM   #8
ScubaruImpreza05
Member#: 74041
SV650 For sale
Bump. Someone tell me how to get it to log to my SD card, with the defogger. I know i can do it via laptop, and I may just be forced to do that tomorrow, but the SD overall is more convenient for my needs.
Do i need a logcfc.txt or not? If so, how do I make it? What would be the code for my 06 2.5i ECU ROM?
Old 08-25-2011, 10:03 AM   #9
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
1 - Open up your ROM file in ECU Flash or RomRaider and get the Internal ID. This should look something like "E2VH202C".
2 - Download logcfg.exe from this link. Put the file in your RomRaider directory.
3 - Run the logcfg program.
4 - Select your ECU Internal ID from the pulldown menu.
5 - Select the parameters you want to log.
6 - Select which switch you want to use to turn the logger on or off.
7 - Create the config file via the button in the top right. It will apear in the RomRaider directory.
8 - Copy this file into the root directory of you SD card in the OP2.0.
9 - Log away.
Y_I_K_E_S is offline   Reply With Quote
Old 11-11-2011, 07:36 PM   #10
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
I'm gonna give this another shot. Thanks Y_I_K_E_S.
punchjamesarnol is offline   Reply With Quote
Old 11-15-2011, 09:17 PM   #11
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
After all this time I couldn't get it to work because I was using an 8GB sd card. I swapped it out for a 2GB and wallah... Opened the files and there it was... USE ONLY A 1-2GB SD CARD! If I only paid attention to the details in the instructions....
Old 01-06-2012, 12:19 PM   #12
ckibue
Member#: 137707
Old post but how does one enable the sdcard high speed logging for the Openport 2.0?
ckibue is offline   Reply With Quote
Old 02-02-2012, 11:14 PM   #13
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
check this out. http://verticaltier.net/configtool/logger.php type in the last four digits of your ecu code and your parameters will pop up. MAke sure that you have no greater than a 2 GB sdcard or else it will not work. I thought would be much more convenient than logging with RR, it's really not.
Old 02-11-2012, 01:55 AM   #14
Dartholomew
Member#: 208771
2009 WRX
Why's that? Is it because it logs too slow? Or that it doesn't timestamp logs like RR does?
I just tried this for the first time tonight, and I gotta say, 4 lines per second is a bit of a bummer. But *convenient?* Damn right it is. If only you could leave the Tactrix in the ODB port without draining your batteries.
Dartholomew is offline   Reply With Quote
Old 05-16-2012, 08:22 PM   #15
WRick
Member#: 86107
old thread revival.
the site used to create a config file doesnt work anymore !
http://www.verticaltier.net/configtool/logger.php
any alternatives ? I also downloaded some logcfg.exe off openecu.org but I can't even make it start. bummer.
WRick is offline   Reply With Quote
Old 05-20-2012, 10:19 PM   #16
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
^^^ don't bother with SD logging. It's convenient but slow as molasses. I would much rather log without the laptop but the resolution is pitiful.
Ziggyrama is offline   Reply With Quote
Old 05-21-2012, 05:21 PM   #17
WRick
Member#: 86107
I'm not logginf with the tactrix actually. I have a display setup in my clock pod
sorry for the ****ty quality
But it has fast polling integrated, so logging resolution is great.
Old 06-07-2012, 03:14 PM   #18
Heide264
Member#: 249088
Ziggy - I think you are doing something incorrectly. I get 40Hz sample rate with my OP2.0 logger. Maybe you need to update the firmware on your cable. I had to download a version of ECU Flash from an Evo forum.
Heide264 is offline   Reply With Quote
Old 06-08-2012, 10:10 AM   #19
dan240
Member#: 57969
2004 WRX
Did you put together a write up when you built that? Looks great.
dan240 is offline   Reply With Quote
Old 06-08-2012, 12:08 PM   #20
Ziggyrama
Member#: 53665
Focal Active Setup
Interesting. Do you have a link? Clearly, the hardware is capable of much faster rate since RR logger can do it. I'd love to have it working without the laptop, if possible.
Old 06-11-2012, 03:35 PM   #21
WRick
Member#: 86107
I'm getting pm's by the dozen about this !
Here's another pic :
If you need info :
martin.gingras @ gmail com
take the spaces out.
I flushed my defi's for this and had change left
best mod ever. If the ecu reads it, this also reads it, and displays it.
Old 07-06-2012, 04:04 PM   #22
JBKbranden
Member#: 190992
'08 WRX
That is/could/would be a great tool but they have yet to make one that fits in
08+
JBKbranden is offline   Reply With Quote
Old 07-08-2012, 12:40 PM   #23
leemwalls
Member#: 325396
2014 WRX Hatch
WR Blue
If you need info :
I NEED that gauge... best toy ever! Where can we find that or how do you make it?
leemwalls is offline   Reply With Quote
Old 11-12-2012, 09:12 PM   #24
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Write that thing up its crazy!
Old 11-27-2012, 11:29 AM   #25
matigas_TT
Member#: 322775
2012 WRX-4Dr
Omg!! That needs a write up
matigas_TT is offline   Reply With Quote
WTB: (MD) Tactrix OpenPort 2.0 eduSti MAIC Private Classifieds 3 03-31-2009 03:10 PM
FS CT: Tactrix Openport 2.0 Boosted WRX STi Engine/Power/Exhaust 10 03-19-2009 07:30 AM
Tactrix Openport 2.0 Coming Soon! 07-08+ compatible. fujiillin Open Source Reflashes 388 02-21-2009 01:56 AM
WTB: Tactrix Openport 2.0 Cable Xissix NWIC Private Classifieds 2 11-04-2008 10:35 PM
FS: Tactrix Openport 2.0 $160 shipped scoobysti05 Engine/Power/Exhaust 7 10-20-2008 12:30 PM
