Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 02-14-2012, 08:20 AM   #1
QuailEyes
Member#: 298881
2004 WRX wagon
Java Black Pearl
Question Catted in Massachusetts?
I have a 2004 wrx wagon, Im going to be putting on a turbo back exhaust this summer. Looking at a clear sounding, quiet-ish catback, and then putting in the downpipe. My local tuner has a couple 3" bellmouth downpipes that fit perfectly but they have no cat attached. Do I need a cat on my downpipe for MA emissions testing? I'll still have a cat by the midpipe, but do I still need the extra one like on stock or the Cobb downpipe?
Any Mass people, please feel free to reply.
QuailEyes is offline   Reply With Quote
Old 02-14-2012, 08:25 AM   #2
vision.dynamix
Member#: 139955
# OneBoston
According to the law, non-oem replacement exhaust = illegal. Louder than stock = illegal
Illegal = will not pass inspection.
If you have no cel, they're not going to know if the downpipe is catted or catless.
Your mileage may vary. Many here pass with fully catless loud cars. And I've seen people fail for the same.
vision.dynamix is online now   Reply With Quote
Old 02-14-2012, 08:54 AM   #3
MaddSubieLove
Member#: 108258
Slip someone a $20 and you can pass with any mod... Just sayin'
MaddSubieLove is offline   Reply With Quote
Old 02-14-2012, 08:56 AM   #4
QuailEyes
Member#: 298881
2004 WRX wagon
Java Black Pearl
^ CEL is an OBDII reading I take it? So if my computer readings all read fine, I should be fine? depending on the location I get it inspected of course.
I have an accessport, so my engine management should all be fine.
any suggestions?
Old 02-14-2012, 08:58 AM   #5
vision.dynamix
Member#: 139955
# OneBoston
From what I've seen, no. The places that will pass you will pass you regardless. The places that will fail you wouldn't pass you if you slipped them a thousand dollars.
Old 02-14-2012, 09:11 AM   #6
Jack ffr1846
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
So the short answer is:
Removing a cat from the system is illegal in Mass. (not mentioned is that it's a federal violation at $10k if they decide to prosicute you....I have never heard of the feds going after anyone)
Inspection without the correct equipment: they can fail you. They might not fail you, especially if they don't bother looking and you don't have any CEL.
It's all your choice.
Jack ffr1846 is offline   Reply With Quote
Old 02-14-2012, 09:23 AM   #7
QuailEyes
Member#: 298881
2004 WRX wagon
Java Black Pearl
So what I'm gathering is that as long as my computer reads fine, then it's just a visual inspection?
Old 02-14-2012, 09:25 AM   #8
Drowner
Member#: 49297
09 WRX
09 ZX6R
I posted in your other thread. Just have a shop weld a heatshield where the cat would be so it looks like its on there if you are really worried that they will get under the car.
Drowner is offline   Reply With Quote
Old 02-14-2012, 09:30 AM   #9
Garandman
Member#: 101117
2009 WRX 5 door
I used the Cobb "Street" catted downpipe.
Garandman is offline   Reply With Quote
Old 02-14-2012, 09:35 AM   #10
vision.dynamix
Member#: 139955
# OneBoston
Yes. Codes=Automatic Fail
No Codes= 50/50 shot on the visual.
Old 02-14-2012, 09:36 AM   #11
vision.dynamix
Member#: 139955
# OneBoston
Not any more legal than a catless pipe.
Old 02-14-2012, 10:00 AM   #12
Thug
Choke Artist
Member#: 603
Not really true.
Thug is offline   Reply With Quote
Old 02-14-2012, 10:19 AM   #13
eatus ravenous
Member#: 26068
Unless you are going to an ultra anal inspection station then you will pass as long as there is no codes ( check engine light on ) and it is not loud as F*&K and doesn't smoke obviously if your car looks like crap all riced out and loud as all get out then you will fail . I have run cat less exhausts on all of my turbo'd Subaru's here in Mass and never been hassled but then again my cars have always looked good and never too loud ...
eatus ravenous is offline   Reply With Quote
Old 02-14-2012, 10:53 AM   #14
rabbitnutz
Member#: 51940
If you have no cel, they're not going to know if the downpipe is catted or catless. unless it's loud
fixed.
it's up to the discretion of the inspection station to determine if your exhaust is too loud. no, they won't be able to tell if you're catted or not from a basic inspection, but i've had a loud exhaust warrant a few revs, then putting the car on a lift and looking for a cat.
just my two cents.
rabbitnutz is offline   Reply With Quote
Old 02-14-2012, 11:04 AM   #15
WRXSleeper
Member#: 43853
2004 WRX Sedan Stg 2
Platinum Silver
Odds are the shop will never know it unless the car is loud or you are throwing CELs. Basically, don't give them a reason to suspect otherwise.
To be somewhat safe you could paint the pipe flat black so it's not bling bling polished stainless steel which is a dead give away that something is not stock under there.
WRXSleeper is offline   Reply With Quote
Old 02-14-2012, 11:32 AM   #16
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
Who is your local tuner?
timeXlost is offline   Reply With Quote
Old 02-14-2012, 12:10 PM   #17
QuailEyes
Member#: 298881
2004 WRX wagon
Java Black Pearl
Ive been using JT Auto in Hyde Park for little things here and there. It's the most convenient place to me and they're pretty nice and reasonable as far as customer service goes. They mostly do Nissans, and they get quite a few VW guys there as well. Because it's Boston they get a lot of beater Integras of course. I think I'm the only Scoobie guy that walks through their doors, so they always want to unload stock on me at better prices just to move it out their door.
Old 02-14-2012, 12:27 PM   #18
tuzzio
Member#: 292532
05 STI
I passed ma state inspection with a catless downpipe. I put my stock sti cat back back on the car, however. As long as your ecu doesn't throw a C.heck E.ngine L.ight for it being catless, you should be fine. I believe that a stage two map from your accessport will take care of that. Also, I do not reccommend flashing a tune that your car is not set up for.
tuzzio is offline   Reply With Quote
Old 02-14-2012, 12:52 PM   #19
myklwrx
Member#: 150791
2002 wrx wagon
midnight black pearl
this pretty much seems to be how it is(at least in my experiences). ive failed in the past for just a loud catback. ive also past full catless and a mellon launcher. it seems more like its not only the shop, but the inspector that decides at the time what seems fit to pass or fail. i usually will wing it, and see how my chances are, if i were to fail swap it out and bring it back, then swap back if you want it that bad.
myklwrx is offline   Reply With Quote
Old 02-14-2012, 01:17 PM   #20
QuailEyes
Member#: 298881
2004 WRX wagon
Java Black Pearl
Another question for the group... Anybody have any experience with MeganRacing products? Specifically any of their catbacks? I hear mixed responses on them, mostly fairly positive (for an inexpensive part). Specifically their sound tho, is it loud? clear sounding? or tinny and cheap sounding? YouTube videos are tough to get a real guage on anything.
Also looking into the Cobb or SPT catbacks, their fairly quiet, deep and clear.
thanks,
Old 02-14-2012, 01:25 PM   #21
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
I got pulled over here in mass back when I had my Turbo XS axleback. I was told that ANY modified exhaust is illegal.
DSRX2005 is offline   Reply With Quote
Old 02-14-2012, 01:34 PM   #22
RR
Member#: 48191
2012 WRX
Ducati Monster
thanks,
I hear a lot of complaining about Megan Racing being cheap Chinese crap. I had no issues with the hardened engine/transmission mounts on my last car.
RR is offline   Reply With Quote
Old 02-14-2012, 01:43 PM   #23
Saabeh
Member#: 166413
2006 WRX Limited
SGM
Not condoning this activity but:
If you have an aftermarket exhaust and you get pulled over. Its probably because you were dicking around. My 2006 WRX is catless and pretty loud, see here:
Anyways...
An easy excuse if your exhaust is louder than a Camry would be that it is an SPT exhaust or something; a factory upgraded exhaust that is 50 states legal, and OEM. Even if something like this doesn't exist for your particular car, its still something that is well know to exist in the eyes of most people/cops.
Best way is to have a 100% legal car that has a valid sticker. Its your choice to be loud or not, when you want.
Saabeh is offline   Reply With Quote
Old 02-14-2012, 04:58 PM   #24
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
Do yourself a favor and give dent sport garage a call, or send them a PM on here. They are located in Norwood and specialize in Subaru performance. They can both tune your car Properly and give you the correct info you are looking for on a turbo back exhaust decision. If you don't know the answers to important questions like weather or not to go catted or catless...a good reputable shop should be the first call you make. DSG will take good care of you.
Old 02-14-2012, 06:09 PM   #25
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
Well when I got pulled over I was minding my own business just following the speed limit.
Im going to be in Massachusetts VanillaEps New England Impreza Club Forum -- NESIC 2 08-07-2003 08:04 PM
stupid front plate, need it in massachusetts tranjo New England Impreza Club Forum -- NESIC 25 07-02-2002 01:30 PM
WRX Shops in Massachusetts BryanD New England Impreza Club Forum -- NESIC 8 05-28-2002 03:39 PM
18" wheels in Massachusetts ambzod New England Impreza Club Forum -- NESIC 3 03-12-2002 12:25 AM
Message Board Statistics All times are GMT -4. The time now is 06:37 PM.
