Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 02-16-2012, 03:22 PM   #1
soccermom
Member#: 302690
2002 wrx wagon
Default DIY - Power window/Lock switch illumination
Our window switches (02's anyway) do not come with any backlighting so they are hard to see at night. The driver window switch has a small green LED but it's way too dim. This DIY will fix this problem.
Final product:
This is a relatively easy mod if you already know how to wire LEDs. I’m not going to explain it, there is a ton of info on the subject all over the web, google is your friend. Use this page if you're not sure of the wiring. Remember the source voltage when your car is on will be 14.4V, not 12.
Tools needed:
Phillips screwdriver
Small Flathead or panel popper
5 LEDs (any color) + proper resistors and wiring
Wire strippers
Small drill bit (this will decide the size of the dots on the switches)
Hole punch or needle
Small flashlight
Electrical tape
Hot glue gun
Optional:
Dremel
Sandpaper (the finer the better)
Krazy Glue or clear nail polish
How this will work: the switches were engineered and built by Nissan with the intention of having an led light them up; there might be a Subaru model out there with those lights working from the factory. As i was writing this up i had an 02 Altima in the shop and this is what their version of the switch looks like.
Technically you could buy the Altima switch assembly and just plug it in, but that might get expensive. There are two things you will have to do in order to get this working: install LEDs under each switch, and on the passenger window switches you will have to drill small holes in order for the light to shine through. The driver window and the lock/unlock switches are already done for you, just add LEDs.
I don’t have pictures for every step because this wasn’t originally going to be a DIY, but I’ll explain it the best I can. I went back afterwards for extra pictures.
Step 1: Remove the driver side window switch panel. There is a Phillips screw hidden in the handle pocket next to it, take that out.
Pry up the pocket gently then pull towards the back of the car, the switch panel will come out too, it is only held by clips. Don’t unplug it from the door wiring just yet.
Step 2: Remove the switch assembly from the panel. Take out those 3 screws. You have to pry out the white part from the assembly; this is easier if it’s still plugged into the door. Use something flat to free it from the 4 clips, one at a time. It will come out, don’t worry no moving parts can fly out.
You can now unplug the assembly from the door wiring.
Step 3: Your are now left with a black and white piece with a green circuit board.
On the green board, you will see that single LED, its a small style flat square light (SMD). Cover that up with a piece of tape, this one is too weak to keep. (circled in blue)
On the black plastic piece, peek in those holes (circled in orange) and you will see that the switches are blacked out on top, but white on the inside. What you need to do for the passenger switches is to drill small holes but not too deep.
I went with 3 holes per switch, but you can go with just one or whatever you like. Start with a small hole punch or needle to line up the holes, then grab the smallest drill bit you can find, and start drilling BY HAND until you reach the white part underneath the switch. It’s important not to go through all the way because the light output will be too intense and it will look weird.
Do one hole at a time, and guide yourself by holding a flashlight underneath to see how deep you are. Take your time, you will regret it if its even 1/32” off . This is how it should look when lit up:
Step 4: LEDs. I went with 4 purple/blacklight LEDs for the windows and an orange one for the door lock switch, matches the rest of my illumination. Pick the color you like, the sky is the limit. To diffuse the LED light a little more so your dots look even, shave off the top of each LED. I used a bench grinder, sandpaper works too (just longer). I finished with 1000 Grit sandpaper because i’m a perfectionist, you can use whatever you want but the lower the grit the less light output you will get. Once it’s nice and flat, put a tiny drop of krazy glue or clear nail polish on the top part you just sanded it and let it dry.
(before krazy glue)
Since the LED is sanded down, the light isn’t directional anymore, its diffused evenly. The Krazy glue will give it that gloss see-through appearance it had before you sanded it, for better light output.
Step 5: Wire up your LEDs and insert them into the holes of each switch. Have your wiring long enough to come out of the switch assembly, we will be tapping the 12V and ground wires from the door’s wiring. I used hot glue to keep them in place and well pointed towards the white part inside the switch. Make sure there is no metal from the LEDS or wiring exposed, it will be sandwiched onto the green PCB when you put it back in and the last thing you want is an electrical short in there.
http://img.photobucket.com/albums/v2...214_163300.jpg
You may have to do a little trimming with a dremel in order to fit the wiring you’re adding, nothing too big though. Have your wiring come out the side or in between the switches. Once everything is in, tight and dry, you can snap the white part of the switch assembly back into the black one.
Step 5: Tap into the door wiring for power. In that white connector, you will see in the middle 2 wires with a slightly bigger gauge than the other. The Green/Black is the positive (+) and the Black is the negative (-).
Tape up your wires properly and reassemble everything. These lights will only work when the key is in and at Ignition, they are on a separate circuit than the dash illumination. Once you confirm that your lights are working, and that all your windows and locks work (In case one of your windows doesn’t work, pop out that white assembly, make sure the guides are lined up and put it back in. I had that happen to me), pop the switch panel back in, screw the pocket down and enjoy your new illuminated switches.
That’s it!
soccermom is offline   Reply With Quote
Old 02-16-2012, 03:22 PM   #2
soccermom
Member#: 302690
2002 wrx wagon
Passenger switches will come soon...
Old 02-16-2012, 03:53 PM   #3
Unrealgtx
Member#: 178853
2007 Sleeper Suby
Very nicely done! this definatly will kill the envy i have of eveyrone that has backlit switches
Unrealgtx is online now   Reply With Quote
Old 02-16-2012, 11:50 PM   #4
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Nice work! Some tips for the passenger door: The way "master and sub switch" windows are wired will make your brain hurt. Some wires will be power and flip to ground depending on the switch position of pass window switch in the master switch in the driver's door. There won't be a wire that is always ground you can use on the window switch plug but there should be a power wire that is always (+). For a ground (-), you can use the door lock switch ground.
Are you going to do this for the rear doors too? When you do that there is no lock switch, you'll have to wire a ground to the door metal.
To offer another avenue for others, there might be other models that have lighted switches? For the later 3g WRX, I found the STI and Forester have fully lighted window switches on both doors up front. I got some of those cheap off EBay and they plug and play for the most part. I wonder if the older Foresters have lighted switches that could swap to the older WRX?
Power6 is offline   Reply With Quote
Old 02-17-2012, 01:28 AM   #5
soccermom
Member#: 302690
2002 wrx wagon
ive done the passenger front switch as well. its a different design, a lot more complicated, maybe too much for some. The door lock switch cannot light up on that side, its just painted on, but i got the window switch working (not afraid of custom work). Thanks for the tip on the wiring, ill check it out. Pictures will be up soon. I am not planning on doing the rear switches (car has never had a passenger back there yet haha), but i assume it would be the same principle as the passenger front.
The forester might have the lighted switches, as well as the altimas and other nissans. ill keep an eye out for these from now on and keep you guys posted.
Old 02-17-2012, 02:40 AM   #6
Izzy_
Member#: 292321
Definitely useful! Gotta hate Audi for their fully illuminated interiors. I don't know a single switch/button that isn't illuminated. Even the air vent regulators have lights . On my Subbie, I go crazy to find where is the button I need lol
Izzy_ is offline   Reply With Quote
Old 03-18-2012, 10:53 PM   #7
castper
Member#: 300342
This is how mine turned out, bad picture but it works pretty well
castper is offline   Reply With Quote
Old 03-19-2012, 07:55 PM   #8
emazz104
Member#: 281811
04 WRX
World Rally Blue
This is a great idea, although I hate when things are uneven, so does anybody know if the the switch for the drivers is the same size as the others? So I could get a blank and drill them all so they are equal? I was actually thinking about doing one, two, three, and four, then looked at the picture above, I like it.
emazz104 is offline   Reply With Quote
Old 03-20-2012, 12:05 AM   #9
john3dpeople
Member#: 287310
Huh.... a mod that I've never thought about... I love the idea and now that I've learned about it I have to do it..
john3dpeople is offline   Reply With Quote
Old 09-14-2012, 05:31 AM   #10
inabysskit
Member#: 255304
Hey, any updates on the passenger side switch? Di you end up getting that done?
inabysskit is offline   Reply With Quote
Old 12-11-2014, 02:49 AM   #11
andrewjt19
Member#: 336760
A two year old thread.... But did you get the passenger doors completed????
andrewjt19 is offline   Reply With Quote
Old 12-11-2014, 09:50 AM   #12
nepbug
Member#: 328631
2008 FXT
I've got all window switches illuminated in mine, here's the write-up.
I used all factory illuminated switches.
http://www.dirtyimpreza.com/forums/s...4&postcount=23
nepbug is offline   Reply With Quote
WTB - Power window switch 03 WRX sry110 Private 'Wanted' Classifieds 6 08-17-2010 12:58 AM
WTB 05+ Power window/lock switches, all doors Hando567 Private 'Wanted' Classifieds 1 08-21-2007 02:21 AM
WTB: 98' 2.5 RS Hood Latch, Window/lock Switch BoomerE30 Private 'Wanted' Classifieds 0 10-31-2004 08:55 PM
window lock switch gifty74 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-25-2002 10:26 PM
