Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-16-2012, 10:38 PM   #1
TiM801
Member#: 289115
Default Cel P0442
Hey, so i have a CEL P0442 some sort of small leak? Not sure what it is.. or what it could be, my engine is pretty much stock, besides an intake. Anyone have any clues? I've tightened my gas cap.. /shrug If i ignore the CEL could it escalate to something more serious? It's more annoying than anything.. Thanks!
TiM801 is offline   Reply With Quote
Old 02-16-2012, 11:57 PM   #2
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Look on the left side of your alternator and behind the power steering pump, its common for the lines there to pop off and cause that check engine light.
bhhamblin is offline   Reply With Quote
Old 02-17-2012, 12:36 AM   #3
Not-EWRX
Member#: 158043
2013 Wrx Hatch
This is the code from hell. You have a leak in your evap system somewhere. It could be anywhere from the gas cap, gas stem, gas tank, canister, or any of the like 50ft of evap lines between the engine and the back of the car. Good luck. Check the lines back by the canister as well.
Not-EWRX is offline   Reply With Quote
Old 02-17-2012, 02:53 AM   #4
TiM801
Member#: 289115
Damn, ok thanks I'll check it out...
Old 02-17-2012, 09:39 AM   #5
TurboJunkie85
Member#: 193412
1985 pumas.
white
Check the lines that run on the passenger side of the intake manifold, zip tie them and then if that doesn't work. Look at the Lines under the passenger rear of the car that connect to the charcol can.
TurboJunkie85 is offline   Reply With Quote
Old 02-17-2012, 11:48 AM   #6
Develitate
Member#: 134559
2005 2.5 RS
I've been dealing w/ this CEL the ENTIRE time I've owned my Subie. Taken it into the dealership 15+ times and they can never do anything for me. I bought a new gas cap, checked my lines and finally learned to live with it and bought a bluetooth OBD II sensor so I can turn off the CEL myself. Hopefully yours is an easy fix. If you find what the issue is on your car will you LMK?
Develitate is offline   Reply With Quote
Old 02-17-2012, 12:33 PM   #7
TiM801
Member#: 289115
Yeah for sure...
Old 02-17-2012, 03:23 PM   #8
Momosaurus WRX
Member#: 214737
Most people don't know how to diag evap system codes. It's really not that hard, just a matter of plugging off the right lines and using a smoke tester.
Problems that it could be:
1) gas cap
2) vacuum lines under the passenger side of the intake manifold
3) a broken/cracked nipple that those vacuum lines go to
4) Lines going to charcoal canister. It's going to be a SMALL leak. So look for damaged lines/hoses.
It's not going to cause you any damage, it's just annoying. I've had this code come up on my 99 Legacy. It was for the sensor that is on the passenger side of the intake manifold that the vacuum lines go to, the nipple broke. And yes I know that I just restated what everybody else said. I just figured organization to problem areas might be nice.
Momosaurus WRX is offline   Reply With Quote
Old 02-17-2012, 04:03 PM   #9
Not-EWRX
Member#: 158043
2013 Wrx Hatch
How do you get your car to pass emissions? Mine wouldn't pass without out having readness on the Evap system.
Old 02-18-2012, 12:36 PM   #10
Develitate
Member#: 134559
2005 2.5 RS
In Weber County you're allowed to have 1 system "not ready" and they will still pass you.
Old 02-19-2012, 04:59 PM   #11
zackl801
Member#: 171753
cracked nipple
zackl801 is offline   Reply With Quote
Old 02-20-2012, 01:56 AM   #12
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Is it the same for salt lake? Holly hell that'd be lame.
Cel P0442 PorterFNU Newbies & FAQs 1 10-06-2009 07:52 PM
CEL P0442 stand up imma_stocker Texas Impreza Club Forum -- TXIC 6 11-04-2007 11:19 PM
CEL P0442 (evap small leak) + instable boost frederik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-20-2007 12:49 PM
Cel P0442 Rando Engine Management & Tuning 5 03-29-2006 11:14 PM
CEL P0442/P0457? (Help Needed) APSWRX1 Texas Impreza Club Forum -- TXIC 4 03-28-2006 03:16 PM
