Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 01-21-2011, 06:00 PM   #1051
80884
Member#: 56783
2004 sti
Aspen white
It says "could not find the main class:Utij.Utij.app.Program will exit" when I try to open Uti.jar. What does that mean?
80884 is offline   Reply With Quote
Old 01-21-2011, 06:02 PM   #1052
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Are you sure you downloaded the full zip file? There should be a folder with libraries in it, and some other folders too. Also, if you just open the zip and try to run it won't work, you have to unzip it into its own folder on your hard drive.
NavyBlueSubaru is offline   Reply With Quote
Old 01-21-2011, 06:57 PM   #1053
80884
Member#: 56783
2004 sti
Aspen white
The problem is my laptop wont update Java to 6.0. Tried in on a computer and it worked but. thats no good for me if it wont work on my laptop. I guess its time for a new one.
Old 04-27-2011, 11:09 PM   #1054
langsbr
Member#: 209630
2002 WRX / V7 STI
3.9USM6 / PSM
Does this facilitate tuning using UTEC in speed density mode, or just MAF based? I see the screenshots show some MAF tabs.
langsbr is offline   Reply With Quote
Old 05-18-2011, 03:48 AM   #1055
azkaz
Member#: 283097
Jeff has stated that it does support speed density. You just have to change the "fuel mode" in the settings tab.
On another note, I have tried and tried to start the UTI program but can't. I have double clicked on the jar file and it just goes to winzip to unzip where it extracts the other files,. I have searched google for he answer, but till no joy. I have the latest java software too.
Cheers
azkaz is offline   Reply With Quote
Old 05-19-2011, 11:44 AM   #1056
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
It shouldn't be opening in WinZip. Something is off in your Java config. Try opening the file with your JRE/JVM and see if that works. You might have to change the default application for the .jar extension. What Java software did you install?
filbert is offline   Reply With Quote
Old 05-19-2011, 05:27 PM   #1057
azkaz
Member#: 283097
All sorted. Winzip was hijacking my file extension. Downloaded jarfix and all is well!
Cheers.
Old 09-29-2011, 10:23 PM   #1058
80884
Member#: 56783
2004 sti
Aspen white
I can't get the new version to work. I installer the way the note says to but this comes up when double clicking the uti in the same folder..."A Java execption has occured"
Old 09-29-2011, 10:25 PM   #1059
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
The newest version of UTI requries JRE 7, found here:
http://www.oracle.com/technetwork/ja...ad-432155.html
ensure that you have this, I bet this is the problem.
Old 09-30-2011, 02:47 AM   #1060
80884
Member#: 56783
2004 sti
Aspen white
The problem is that sometimes I forget to do the simplest things. I pretty much did not extract the zip file and was trying to open it directly from the zipped folder.
That's what happens when I play with computers later in the night. Anything interesting to know about the newest program? Anything that doesn't work?
Old 02-14-2012, 07:45 AM   #1061
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Default Did not get a reply to email so I thought I would post here.
I finally got all of the pieces to the puzzle installed this weekend. I have a 2005 baja turbo 5 speed and I am using an STI UTEC and an innovate lc-1 wideband.
The UTI program works great. I have some awesome 3rd gear pulls saved and some excellent cell hits on the tables. I do have a couple of questions that may seem stupid to some of you guys that have been using this setup for a bit.
1. When using speed density fuel tuning in UTI do I have to setup the UTEC in hyperterminal first to be able to use this function or does UTI do that for me?
2. I am trying to write a map with the logs and tables I have in UTI ME. One problem I am having is when I use the "Import tables" function I get tables with all zeros. I am pulling the tables file from the UTI folder (tables.csv)
3. Right now I am logging using map 0 on the UTEC (stock), should I be using a blank map on 1? Just not sure if it's okay to use the stock map for logging or not. I want to be able to write a nice map for it.
Any help you can provide to a new user would be greatly appreciated.
Thanks in advance.
2.5 turbo hyped is offline   Reply With Quote
Old 02-17-2012, 09:05 AM   #1062
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Thanks in advance.
I took the utec out since there is very little support for it anymore. it's in the dumpster if anyone wants it. Going with open source.
Old 02-18-2012, 04:09 PM   #1063
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
If you seriously took it out then I won't bother answering, but if you were just joking then I will answer.
-Jeff
Old 02-18-2012, 04:51 PM   #1064
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
-Jeff
hell yeah I took it out I got tired of waiting weeks on end for an answer. garbage man picked it up yesterday and I never felt happier. biggest waste of money I ever had. but at least you got my 25 bucks for the software.
Old 02-19-2012, 08:09 AM   #1065
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you're not too smart.
Old 02-19-2012, 08:50 AM   #1066
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
I agree, buying the utec was the dumbest idea ever.
I get an answer to my questions on the romraider forums within minutes and I do not have to purchase any software. I find it easier to understand and tune with anyhow.
Old 02-19-2012, 10:03 AM   #1067
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
How exactly did you wait weeks? You posted a question about the software in the thread about the software and the author responded in a few days.
Where I work we pay upwards of 90k for software and don't even necessarily get a support contract. You pay $25 and want immediate answers. Btw most of the answers to your questions are in the utec manual, RTFM.
SBW is offline   Reply With Quote
Old 02-19-2012, 11:07 AM   #1068
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
I used email first after not getting response I posted the question here. This app is being used on baja and the strange thing is that even with the software the dashboard wasn't showing up. I even went ahead and called turbo xs and they wanted nothing to do with me. I got a lot of I don't know and what's the deal answers from them. I understand open source a lot better than I do the utec. I was being sarcastic when I said I threw it away actually have the utec here it is in great condition it works just fine. 130 bucks shipped takes it. http://portland.craigslist.org/mlt/pts/2855487693.html
Enhanced UTEC Interface ...? ScreaminFast Engine Management & Tuning 4 09-20-2003 11:23 PM
UTEC interface enhancement (Long) LiquidForce Engine Management & Tuning 51 06-09-2003 04:10 PM
UTEC Interface Enhancement LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-29-2003 11:42 AM
UTEC software or interface nekard Engine Management & Tuning 5 10-22-2002 04:16 PM
UTEC interface program question? davidm_sh Engine Management & Tuning 3 10-09-2002 11:07 AM
