#1 |
Member#: 130990
NWIC
Vehicle:06 Red Wagon hta68 MPS tuned JDM 6-speed |
Shop: Maxwell Power Services
Location: Arlington, WA Ambient Temp: About 50 degrees F Elevation: 200 feet Weather: Cloudy Car: 2006 WRX Tuner: Dominic Dyno Info: Dynocom Transmission: Stock 5-speed Gear:3rd Peak HP at RPM: 387 @6400 rpm (about 340 on a Mustang) Peak Torque at RPM: 410.8 @ 3950 rpm (about 360 on a Mustang) Baseline hp/tq for a stock Sti on same dyno: 245/245 Target Boost: 21.8 psi Target AFR: 10.7 Fuel: 92 pump Engine/Power Modifications: HTA68 with 10cm hotside installed by Dom, Helix catted downpipe, STi intercooler, Invidia Q300 catback, Gimmick inlet hose, 725cc injectors, Walbro fuel pump, APS Cold air intake, Agency Power UEL header, TGV deletes, Grimmspeed Uppipe, Prosport MBC for hybrid boost control. Driveline Modifications: ACT street clutch Suspension Modifications: Whiteline F/R swaybars, Stoptech stage 2 brakes Tires: Federal SS595 215/45/17 on stock WRX wheels. After my #4 ringland objected to 75k modded miles, I went with a Maxwell Power Factor SS EJ257 with some B25 heads. The block has JE pistons, H-beam rods, ACL bearings and is balanced/blueprinted. I also added some stronger springs and 264 exhaust cams, plus an Accessport so that Dom could do a speed density tune. A post-intercooler IAT sensor helps keep things safer. The car's last tune (and the very last for the previous motor) produced 371hp at 5900 and 400tq at 3950. The new build has noticably more kick up top. Dom did the pull up to 7500rpm, but you can see there's not much point in holding it that long, except that in first gear I no longer bounce off the limiter (now set to 7700) and the extra headroom puts the shift to 2nd in a very good place. The powerband is pretty good -- over 350hp/tq for almost 4k of range. It will be fun to go bigger in the future, but the next upgrade, someday, will have to be the tranny. ![]()
#2 |
Member#: 279449
MWSOC
Vehicle:2004 Perrin Stg2+WRX Platinum Silver |
Yea for sure get some work on that tranny.
Great job though! Good numbers and this a good read. I plan on running a 68hta with 850cc injectors and a walbro. I like seeing this because I'm aborting my plan on moving to e85. I'll be staying with 93 pump. Thanks for the read. |
#3 |
Member#: 130990
NWIC
Definitely go with the 850's -- Dom said my 725's were getting close to max.
#4 |
Member#: 204014
South East
Vehicle:02 Bugeye Rotated, HTA3582, E85 |
I bet its fun to drive. What kind of valve springs did you go with?
I wonder how Dom likes tuning with SD? |
#5 |
Member#: 173656
Nice graphs. I am doing a similar build, but I will be using a 8cm hot side, I want the boost earlier that where you are getting it. I am willing to sacrifice some off the top end to get power earlier.
#6 |
Member#: 178426
Vehicle:2010 Evo X MRt Silver |
Looks very nice! I'm surprised you are losing the power in the higher rpms though with that 10cm hotside. Any head work done besides the cams?
#7 | ||
Member#: 130990
NWIC
He likes keeping the stock MAF for a better idle, I know that much. Quote:
No headwork was done besides resurfacing. |
#8 |
Member#: 309758
MWSOC
Vehicle:2004 STI PM me if u need a Tune |
thats a great looking graph 68HTA even with the 10cm hotside..and on 92 oct
I think you should consider selling the 725cc injectors for 1000cc or even 1300cc and go with E85 if its in your area. That will be a easy way to see further power while running a bit safer fuel for making power with. Do you have a Wideband in your car? you should get one since your 725cc can be pushed to their limit easy on a cold day where your boost might spike |
#9 | |
Member#: 130990
NWIC
The injectors might not be a bad idea. Then I could up the boost a bit more -- who know, I might break 400. ![]() |
#10 |
Member#: 263470
Weird my 11 is hitting 320 (318whp) on Akumas very low reading dyno with my HTA68, so are you saying I am around 350-360 on a different (higher) reading dyno?? I am going for the meth to get a little more so in theory I should be right around your numbers w/meth on a stock block,tranny,clutch?
#11 |
Member#: 263470
Sorry guys 315WHP/318WTQ
#12 | |
Member#: 130990
NWIC
I'd say meth ought to get you there, especially since you have a reputable tuner. |
#13 |
Member#: 263470
Wow. thanks for the information. People really seem to hate on the HTA68 around here, do you get the same feeling?
#14 |
Member#: 108051
Tri-State
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
I Wanna see this on a high comp stoker motor with e85 would be a perfect set up probably even go tens lol
#15 |
Member#: 260624
TXIC
e85 and an RA gear set, should be good for 400 whp fun.... I think mine is, we'll see.
#16 | |
Member#: 108051
Tri-State
#17 |
Member#: 130990
NWIC
I think it's slowly picking up a reputation as people learn more about tuning it. It was over-hyped and somewhat deceptively promoted in the beginning, IMO.
#18 |
Member#: 178426
It only seems to work well when modified with the 10cm hotside. Even then it's dropping 30+whp up top. That's pretty significant I'd say. Still not impressed with it.
#19 | |
Member#: 108051
Tri-State
#20 | |
Member#: 130990
NWIC
Edit: I see you had a bad experience with the hta68. Are you back on your Dom 3? Last edited by Dave D.; 02-22-2012 at 08:39 PM. |
#21 |
Member#: 166005
MWSOC
Vehicle:2005 Saab 92x Beaten Silver |
Is there any reason you chose to stay with the stock rod length over the +2 long rod iterations I see MPS going with so often?
I love the max effort build you've got going on with a 'questionable' turbo. It's taken a lot of work, but I'd say your results speak for themselves! |
#22 |
Member#: 285777
MWSOC
Vehicle:2004 STi- |
U would be able to get more out of this setup once u get a better TMIC or even FMIC...What are your IDCs with the 725cc?
#23 | |
Member#: 130990
NWIC
Turbo: Thanks for the kudos. I did want to see what this turbo could do as my contribution to the community. One of these days I'll probably go 20GXT. I shouldn't need to replace anything but injectors. Then we're talking 450 whp or so, or close to 400 on a Mustang. |
#24 |
Member#: 130990
NWIC
Dom said they were getting close to max. Dom's not a big fan of huge topmounts. He says once they heat soak they take much longer to cool off. I'm sure a FMIC and bigger injectors would allow me to run more boost and timing, but I don't want to cut my bumper beam. Perhaps in the future, though, I'll rethink this.
#25 | |
Member#: 108051
Tri-State
| Thread Tools | |
| Display Modes | |
| 2004 ej205 wrx hta68 last runs before built motor | 2000subie | Proven Power Bragging | 17 | 10-19-2011 10:07 AM |
| FS : CO: 2004 Sti Psm, >80k, Unique sleeper, Built Motor, HTA68, E-85, Coilovers | mrkt321 | Private Vehicle 'For Sale' Classifieds | 42 | 08-10-2011 03:00 PM |
| Yimi Sport Tuning: 2002 WRX, HTA68, stock motor, 91 octane = 338whp/312wtq | paul@YimiSport.com | Proven Power Bragging | 6 | 06-16-2010 02:50 AM |
| MAINE: 02 wrx sedan silver, built motor, built heads, 16g, 6 speed! | cquirki | Private Vehicle 'For Sale' Classifieds | 31 | 10-29-2008 04:38 AM |
