Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 02-22-2012, 07:41 AM   #276
HoboBob
Member#: 253560
'05 FXT
Asspen White
Originally Posted by kwikside
^^ Is that a CM110 camera?
No it's an eBay special
Originally Posted by theoutbackdream
Looks good, but maybe you should get a fisheye lens for it, because it doesnt look as usuable if just a small image.
Just my 0.02 though.
The lens actually has a slight bend to it. When it's not on my garage you get a wider field of view, it's not too bad for what it is. Plenty usable.
HoboBob is online now   Reply With Quote
Old 02-22-2012, 05:30 PM   #277
spec.B - autox
Member#: 209699
2009 STI
Here's my home made clutch stop... Less than $10 hardware store parts, done in 20 min.
spec.B - autox is offline   Reply With Quote
Old 02-22-2012, 07:33 PM   #278
tcoffin014
Member#: 173734
Sexy White Princess
That's pretty cool. Is there already a hole there or did you drill one? And is it a noticeable difference?
tcoffin014 is offline   Reply With Quote
Old 02-22-2012, 07:38 PM   #279
P-Train
Member#: 279233
2008 WRX, Stage II
What be the benefits?
P-Train is offline   Reply With Quote
Old 02-22-2012, 08:06 PM   #280
tcoffin014
Member#: 173734
Sexy White Princess
It makes the clutch only depress to the disengagement point, not past it. Apparently it makes your shifts a little quicker and more precise.
Old 02-22-2012, 08:46 PM   #281
spec.B - autox
Member#: 209699
2009 STI
There's already a small hole there where the small plastic tab is now... Remove the tab, and enlarge the hole to a size that makes sense for the diameter of the foot peg you buy. I had to drill mine out to .375"
The quality of driving while in traffic is drastically improved, as there's no more guess work, and no wasted efforts. As with most springs under negative load, the more you push in the clutch, the harder it gets. Furthermore, I can now double-clutch without even thinking about it... Great for traffic lights
Old 02-22-2012, 09:53 PM   #282
EvilCerealBoX
Member#: 62924
2002 WRX Wagon
Where's the actual engagement point? I'm confused on how you determined that.
EvilCerealBoX is offline   Reply With Quote
Old 02-22-2012, 09:58 PM   #283
riseown
Member#: 311210
I'm confused about that too.
riseown is offline   Reply With Quote
Old 02-22-2012, 10:41 PM   #284
pheonix991
Member#: 154173
2006 STI
Or you can just get used to where it actually engages, and only push your foot till that point.
pheonix991 is offline   Reply With Quote
Old 02-23-2012, 01:23 AM   #285
tcoffin014
Member#: 173734
Sexy White Princess
Awesome I'm gonna do this tomorrow. I found another version on a Beamer forum where he used an "elevator bolt". I'm thinking about adding a couple of nuts to make it adjustable
Old 02-23-2012, 01:25 AM   #286
tcoffin014
Member#: 173734
Sexy White Princess
It seems to jump around sometimes for me. And that would be hard to do when on the track or something
Old 02-23-2012, 01:43 AM   #287
pheonix991
Member#: 154173
2006 STI
You just think it jumps around, fact of the matter is you're not paying attention to where it engages. And different slopes make it feel like it's engaging at different points.
And around a track, your muscle memory comes into play real fast.
Old 02-23-2012, 01:45 AM   #288
faylix
Member#: 70184
2012 WRX STI
This is my old 04 that I had before I switched to a CTS-V for a while.
back then car-puters and tablets weren't very common but I found out this Tomtom 910 was linux based, came with hard wire connections and a mic for bluetooth calls, and had 13 GB's of extra space on the hard drive for mp3s. I decided this was a match made in heaven for my clock spot:
A whole shot of the interior - thats v7 spec c seats, stearing wheel, etc. I don't remember the make of the gauges.
Close up shot of the mount.
Bluetooth mic. Didn't end up using it much because you had to change the volume of the sound system way up for some reason. Eventually I found a setting in the files on the tomtom that wasn't accessible from the touch screen - one had to ssh into it - but it added an automatic 10 pts of volume to blue tooth calls and that fixed that
And the whole system was removeable!
I hope to begin working on my 2012 STI as much as possible.. I'm thinking about molding my moto Xoom into the dash. I know tablets are old hat these days, but I'm sure I can come up with some unique way of doing it.
- faylix
faylix is offline   Reply With Quote
Old 02-23-2012, 02:11 AM   #289
tcoffin014
Member#: 173734
Sexy White Princess
No trust me, it jumps around. Not much but it does. It has something to do with the clutch delay valve. I live in Louisiana, there are no slopes lol. And actually I pay a lot of attention to where it engages which is why I know it jumps around. Like you said, my muscle memory comes into play so I let out where it usually engages but sometimes it moves and I get jerky shifts
Old 02-23-2012, 02:12 AM   #290
pheonix991
Member#: 154173
2006 STI
http://www.iwsti.com/forums/how-inst...ve-method.html
Old 02-23-2012, 02:17 AM   #291
tcoffin014
Member#: 173734
Sexy White Princess
Yeah I've seen that. I just don't want to do it until my warranty is up just in case. So I figured a couple dollar bolt would work better than nothing for now
Old 02-23-2012, 08:53 AM   #292
treefan
Member#: 176856
02 wrx wagon
white
- faylix
Is that you speed racer? I recognize that Tom-Tom. This is Ken.
treefan is offline   Reply With Quote
Old 02-23-2012, 09:46 AM   #293
spec.B - autox
Member#: 209699
2009 STI
Trial & error!!! MAKE SURE YOU TEST THE SETTINGS WITH THE CAR OFF FIRST!!! You should be able to dry shift in and out of all gears (including reverse) before you set the height.
Shift point DOES vary, but only VERY slightly. Make sure to accommodate for this when adjusting the height of the stop.
Old 02-23-2012, 11:23 AM   #294
foolycooly
Member#: 260545
2011 WRX Limited 4dr
It can vary enough on the 2011s to significantly affect stop and go driving in traffic...I have many miles of personal experience and it is extremely annoying.
But then I just wail from 1st through 2nd when there's a break and it makes me feel better.
foolycooly is offline   Reply With Quote
Old 02-23-2012, 12:35 PM   #295
tcoffin014
Member#: 173734
Sexy White Princess
This. Usually it varies the most on cold starts and doesn't get better until the car warms up or I find the new engagement point
Old 02-23-2012, 01:48 PM   #296
spec.B - autox
Member#: 209699
2009 STI
You guys will have to try it to figure out what height works best, OR if this works at all on a stock clutch.
I have an Exedy Hyper Twin, and this small mod makes a WORLD of difference when I'm putting around. At high RPM under load (IE spirited or track driving) this mod makes NO difference to me. Since my ride isn't a trailer queen, and I have to drive to my events, this was a must.
Old 02-23-2012, 01:51 PM   #297
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Exedy Hyper Twin clutches on these cars are nothing but bragging rights that you spent a lot of money on a clutch. Functionally, there is no real point.
P.S. Wrong thread.
Byzantium is offline   Reply With Quote
Old 02-23-2012, 01:52 PM   #298
spec.B - autox
Member#: 209699
2009 STI
FAIL...
Run a nickel AWHP and get back to me on that one
Old 02-23-2012, 02:00 PM   #299
Byzantium
Member#: 207826
85k 2002 WRX
Um, I'm pretty sure I make more power than you. That "85k" you see in my signature is not my mileage.
Old 02-23-2012, 04:16 PM   #300
hawkasock
Member#: 252054
1994 2.1l WRX
Matte Black
Bickering is not a unique mod. Post more skid plates that turn into wings that have cup holders!
hawkasock is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
Message Board Statistics All times are GMT -4. The time now is 06:19 AM.
