Old 02-15-2012, 09:29 AM   #1
Perks713
Member#: 304414
2012 Impreza Limited
Default 2012 Impreza CVT shift delay
I'm wondering if what I'm experiencing is typical with a CVT transmission and/or the 2012 Impreza.
Shifting from Park to Drive
or
Park to Reverse
or
Reverse to Drive
All comes with about a 2 second delay in the transmission actually shifting.
When shifting into drive the car almost lurches forward once it engages, possibly due to how I'm holding the brake in, I think it's more that it still catches me off guard.
Is anyone else having this issue? I checked with Uncle Google and it seems like there are a lot of message boards across multiple make/models where people are saying the same general thing, but the same thing keeps coming out "it's my first CVT, is this normal?" with no real info if it is.
Perks713 is offline   Reply With Quote
Old 02-15-2012, 07:33 PM   #2
subiTWO
Member#: 273054
2012 Impreza CVT HB
It's normal.
subiTWO is offline   Reply With Quote
Old 02-15-2012, 07:56 PM   #3
JRod25314
Member#: 306903
Have it too. Takes some getting used to.
JRod25314 is offline   Reply With Quote
Old 02-17-2012, 09:00 AM   #4
FCP Import
Member#: 305489
91 skyline GTR
champ white
Its normal. My wife's Nissan Rogue is the same way. You get used to it.
FCP Import is offline   Reply With Quote
Old 02-20-2012, 04:30 PM   #5
jmews
Member#: 310897
I have experienced the same delay.
jmews is offline   Reply With Quote
Old 02-21-2012, 02:51 AM   #6
somebody else
Member#: 21618
The two other CVTs I have driven do the same thing. The Impreza 2.0i has less of a delay than my previous 2007 Nissan Altima.
somebody else is offline   Reply With Quote
Old 02-22-2012, 12:12 PM   #7
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Noticed this on my car too. Only happens when going to Drive (from any other position).
riccnick is offline   Reply With Quote
Old 02-22-2012, 10:19 PM   #8
rygar
Member#: 307459
2012 Impreza Spt Wgn
same here breh
rygar is offline   Reply With Quote
Old 02-23-2012, 12:33 PM   #9
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
It almost feels as if something is sticking inside the transmission, or as if there is not enough fluid in the trans. I know that when an old truck takes some time to shift between gears, its a sign that a rebuild is coming soon, or that the trans fluid is shot/low. I'm bringing it in this weekend to have them check it out. Sometimes it clunks pretty hard when it finally does shift into drive, and that is with my foot on the brake and the car not rolling at all. Other times it feels like it partially engages, and i can see the revs fall slowly, instead of the normal drop rate to low idle. I'll report back asap for all who are interested.
Old 02-23-2012, 03:53 PM   #10
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Just as a side note, I noticed today that when the weather is warmer (~45-50°F) and the car is warmed up, the transmission shifts from gear to gear like a normal auto. Really no extended delay at all. Usually its been 3-4, maybe even a 5 second delay. But for some reason (probably because it heard me say I would take it in) today at lunch it was fine.
Old 03-06-2012, 12:43 PM   #11
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Just wanted to let you all know, Dealer say this is normal when its cold. That was it. I asked them if the transmission fluid was low, would it do this. They said yes, but all the cars are filled at the factory to the exact level. They didn't want to waste their time checking, so off I went. Doesn't seem to be getting better or worse. Just slow when its cold, and almost normal speed when the trans is warm.
Old 03-10-2012, 08:36 AM   #12
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
or
Park to Reverse
or
Reverse to Drive
I experience that too, it took me by surprise when I backed it out of my garage for the first time, I guess its something we'll get used to.
Old 03-13-2012, 05:54 PM   #13
kufman
Member#: 313453
2012 Sport Premium
Mine does this too and my older Saturn SW2 did it as well (it had a regular 4 speed auto). I assume this is due to cold fluids (cold = thick) making things move into place slowly. The trans also seems to respond more slowly to throttle inputs when it is cold. It all seems to normalize after 5 minutes.
kufman is offline   Reply With Quote
Old 03-19-2012, 11:09 PM   #14
pkL
Member#: 313093
2012 Impreza 2.0i
I still haven't gotten used to this yet, it just feels delayed. Do you guys step on the gas right away after shifting or do you wait a couple seconds until its "in gear"?
Old 03-20-2012, 09:13 AM   #15
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
I've gotten into the habit of waiting until I feel the trans kick in, to the point where if I drive a regular auto it catches me off guard.
Old 03-20-2012, 10:31 AM   #16
kufman
Member#: 313453
2012 Sport Premium
I wait until I feel it engage. No sense in putting extra stress on the trans if I don't need to.
Old 03-20-2012, 06:06 PM   #17
Bluey2012
Member#: 305312
2012 Imp 5dr 2.0i Li
Marine Blue Pearl
Yup, notable reverse-to-drive delay backing out of a space in a sloped lot today (on an 80+ degree day). Felt like I was rolling backwards since I had stepped off the brake already. Surprised the heck out of me. Next time I'll be prepared.
Bluey2012 is offline   Reply With Quote
Old 03-20-2012, 07:11 PM   #18
subiTWO
Member#: 273054
2012 Impreza CVT HB
If you shift to drive a few feet before you stop reversing, you'll be in motion right away, with no driveline shocks...
Old 03-20-2012, 11:55 PM   #19
pkL
Member#: 313093
2012 Impreza 2.0i
Yeah I wait for it to it to shift into gear too, unless I really have to, which I haven't done yet.
On a related note do you guys notice when you park your car and pull your key out, you hear a mechanical whirling sound, is that the CVT disengaging?
Old 03-21-2012, 01:23 PM   #20
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
That is the fuel system de-pressurizing. The extra fuel is pumped back from the throttle body to the tank through a small return line. Every fuel injected car does this, some are quieter that others. Some are a constant whirring sound, others have a rhythmic "knock". Also, if it is not that, it may just be the CD player cycling. When you turn the car on, the CD player preps itself to be ready, whether or not you are playing the CD. When you turn the car off, it cycles back to a default setting. Sometimes this is confused with the fuel return noise and vice-versa.
Old 03-21-2012, 02:32 PM   #21
pkL
Member#: 313093
2012 Impreza 2.0i
You have the 2012 Impreza too, do you notice it? Both scenarios do makes sense though.
Old 03-21-2012, 03:04 PM   #22
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
I'll have to listen for it tonight. These noises are normal, I'll try to pinpoint which one is more prominent. Neither noise has caught my attention, but I wasn't exactly listening for them either.
Old 03-23-2012, 12:16 AM   #23
pkL
Member#: 313093
2012 Impreza 2.0i
Well I don't hear it except when I pull into my garage, it seems to be the fuel pump, I would think.
Old 03-23-2012, 10:14 AM   #24
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Crap, sorry man, I didn't listen for it yet. I'll try to remember on lunch today....
Old 03-25-2012, 03:02 AM   #25
pkL
Member#: 313093
2012 Impreza 2.0i
Haha its alright, no worries.
[Mini Review] Traded 2011 Impreza Outback Sport for 2012 Impreza Sport Premium tornado542 General Community 15 05-04-2012 07:07 AM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
4eat 2-3 shift delay Meat Supply Transmission (AT/MT) & Driveline 4 03-02-2009 06:11 AM
Message Board Statistics All times are GMT -4. The time now is 09:11 AM.
