Mid Atlantic Impreza Club
Closed Thread
Old 02-23-2012, 06:35 PM   #26
whitegalant
Member#: 287106
2007 WRX STi
UGM
Ground 2nd gear first time since ive had the car
whitegalant is offline
Old 02-23-2012, 07:42 PM   #27
ricepapertiger
Member#: 213581
'09 WRX, '88 GL
OBP, Panda
Put on deez rotors, muteki SR48 open ended, ARP extended lugs, aaand Hawk HPS pads. On the fronts.
Techna-fit Lines, Pentosin RBF, and rear blank rotors go on tomorrow.
ricepapertiger is offline
Old 02-23-2012, 07:48 PM   #28
ppayer38
Member#: 234407
04 Self-tooned
STi
More logging and finally got my UEGO to log!!!
Hopefully hearing from somebody about BLTing my car this weekend...
ppayer38 is offline
Old 02-23-2012, 08:07 PM   #29
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
The Uego is a BITCH to get to log isn't it? Lol
Uncle Tattoo is offline
Old 02-23-2012, 08:31 PM   #30
ppayer38
Member#: 234407
04 Self-tooned
STi
It works everytime now! I was pulling my hair out trying to figure it out... Best part is I figured that out now I gotta figure out why I'm running lean @ WOT...
The joy of a 109,xxx mile car
ppayer38 is offline
Old 02-23-2012, 09:00 PM   #31
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Feel your pain. Mine he 114k
Old 02-23-2012, 09:13 PM   #32
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
Washed it.
yuephoria is offline
Old 02-23-2012, 09:14 PM   #33
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
YOOOOO WHAT DID YALL DO??? haaa, my UEGO still won't log
only thing i can think is its the win7 svcpack 1
God&Sme is offline
Old 02-23-2012, 09:44 PM   #34
ppayer38
Member#: 234407
04 Self-tooned
STi
Follow these steps... Mine installed just fine and I then installed it manually also so that wasn't an issue for me.
You should use this order:
Start car...
Computer on
BFM cable plugged in
OpenPort2 or VAG-COM cable plugged into car and computer
Start up RR Logger
If using VAG-COM select its COM port (not needed for OpenPort2 cable)
Select COM port in Plugin menu for AEM UEGO 9600
Select an ECU parameter such as Engine Speed (Logger should now be updating)
Select External sensor AEM UEGO 9600
What problem are you having with it?
ppayer38 is offline
Old 02-23-2012, 09:50 PM   #35
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
I followed the faq on the romraider website where I basically had to do everything but reformat my win 7 laptop lol.
Old 02-23-2012, 10:24 PM   #36
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
solid, ill try that procedure next time. Im fairly certain thats the procedure i use but it's been awhile since i tried. It sucks b/c a year ago i got it all setup and logged everything fine for six months or so. didn't log anything until thist past fall when i tried to log my buddies sti and it just wouldn't recognize the cable in RR. I had updated RR and ecuflash and Win7 so I didn't know which one it was. I did try earlier versions of RR with no luck and even used my buddies alienware laptop with no success. My computer recognizes the cable but just can't get it to pull up any data in RR. I need to finish tuning w/Mikey b/c my partial throttle is all off but all i can send him now are videos of my afr gauge
God&Sme is offline
Old 02-23-2012, 10:28 PM   #37
ppayer38
Member#: 234407
04 Self-tooned
STi
I was in the same boat but since I tried that it works fine for me now... Not gunna lie I felt pretty stupid about it cause it was something so simple but hell it works I'm happy!
Goodluck dude just holler if you need a hand or have ??'s
ppayer38 is offline
Old 02-23-2012, 10:46 PM   #38
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
thats whats up!!! haaa i had prettty much given up on the idea of being able to log my uego again , buuuuuuut i got mad faith now Thanks!!!
God&Sme is offline
Old 02-23-2012, 10:50 PM   #39
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
actually i found the directions I had been using before. These seem fairly similiar to yours
1. OP2 & WB02 plugged into the car
2. Start up the computer with nothing plugged in
3. Let the computer fully boot and start RR Logger
4. Start up the car or at least move ignition to the ON position
5. Plug in the OP2 & WB02 connections
6. RR Logger finds and connects to the ECU
7. Load profile as required
8. Confirm WB02 COM port is correct (actually if I see it in the RR main COM list then I know it is)
9. Switch to the Externals tab and check the WB02 item
10. Log as needed
God&Sme is offline
Old 02-23-2012, 11:04 PM   #40
GRiNCH503
Member#: 311345
I inatalled a h4 xentec flex bixenon 6k H I D kit and its installed properly, and only the passenger side works for both hi and low. The driver side.dose not work niether highs or lows. I put the halogens back in and they work for highs and lows. if nothings wrong with the H I D kit what would be wrong with the car to cause the H I D kit to not work on the driver side?
GRiNCH503 is offline
Old 02-23-2012, 11:09 PM   #41
GRiNCH503
Member#: 311345
I installed new HIDs in my 92 legacy and they dont work
Old 02-23-2012, 11:44 PM   #42
infinite012
Member#: 74392
2015 Forester
Good. Make sure they stay that way.
infinite012 is offline
Old 02-24-2012, 06:32 AM   #43
ppayer38
Member#: 234407
04 Self-tooned
STi
Agreed, bad idea! Even know I did it for like 2 months it was horrible output and the glare sucked!
10. Log as needed
This is the set of directions I was using and couldn't get it to work. Tried it the other way and has worked everytime since.... Just talk to her nice before and maybe she will be nice and work haha
ppayer38 is offline
Old 02-24-2012, 09:39 AM   #44
golden_boy
Member#: 248620
2013 BRZ
Dark Grey Metallic
Tried to figure out why my turbo is overheating.....
golden_boy is offline
Old 02-24-2012, 10:06 AM   #45
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Originally Posted by WRX WARRIOR View Post
A mustang tapped me in a parking lot.
Take some compound to that man, God damn FORDS!
NutWagon is offline
Old 02-24-2012, 10:08 AM   #46
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Me likey
NutWagon is offline
Old 02-24-2012, 10:09 AM   #47
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Originally Posted by Uncle Tattoo View Post
The driver happened.
Lmao, Oh shyt.
NutWagon is offline
Old 02-24-2012, 10:57 AM   #48
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
every comment of yours makes me happier than the one before
im confined to a bed w/strep throat right now buuuuuuut when i rise again, eh who am i kidding, i got mad schoool work to catch up on
God&Sme is offline
Old 02-24-2012, 11:20 AM   #49
mangostick
Member#: 256936
2013 FRS
pearl white beetches!
made some tweaks and flashed a new map n data logged yesterday afternoon. Yesterday evening tweaked some more and loaded new map this morning.
Throttle response now nice n crisp .. car pulls solid n smooth. Also, for some reason, without changing the wgdc tables any at all.. just the temperature change outside has put my boost back on its targets. hmm.. Apparently it really loves cold weather, even with cold weather temp comps set to pull 1.5psi at 50* F and 2psi@ 32* F Its still 1-1.5psi over target on wot pulls when its cold out.
mangostick is offline
Old 02-24-2012, 01:34 PM   #50
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
your TURBO is overheating?!! Care to explain what you mean there?
Can you give us some description/symptoms of what's going on?
Homemade WRX is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
