Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Closed Thread
Old 02-28-2012, 06:30 AM   #51
m_clark54
Member#: 224322
2013 WRX Spec Ed
Tangerine Orange
Had maint done yesterday and was, told power steering pump bracket was broken and air filter tabs broken. Told battery needed replaced and needs new tires soon.
So this morning I opened my hood to see. Air filter is sealed correctly, no visible issues. Power steering appears to be fine, but fluid reservoir was loose. Clipped it back into its bracket and everything is fine... now.
Battery was disconnected all weekend so it just needed a little charge. Works fine. Tires had good tread.
I'm glad I told them to hold off on that other stuff. Anything for a dollar.
m_clark54 is offline
Old 02-28-2012, 10:45 AM   #52
Jester808
Member#: 166085
1990 Skyline GTR
Jet Silver Metallic
^ Sounds about right
Jester808 is offline
Old 02-28-2012, 05:01 PM   #53
TOI
Member#: 238230
98 impreza sedan
made a new EGR block off plate, the old one was warped and causing my no idle issues. so now my car does idle, still idles rough and low, and still dies alot.
TOI is offline
Old 02-29-2012, 05:44 PM   #54
Davenow
Member#: 23676
Relocated my battery to the trunk.
I need to flip the battery around to make the wire cleaner and tucked. This is just quickly put in for a test drive to make sure its solid.
It is. I am very happy with it.
And no, I wont have any problems at the drag strip. San Antonio raceway could give a flying ****.
Its also in there ROCK solid, there are 4 Grade8 bolts holding it down with 1" washers under and over. You would rip the floor out of the trunk before you would dislodge that battery tray.
I put it on the drivers side because I wanted to keep my shaker1000 sub. I put it sideways because, well **** it why not.
I used this kit
http://www.summitracing.com/parts/TAY-48000/
Which I got from the local speed shop.
Impressions
Well, dont expect the world. But, the nose definitely seems to come up a bit more freely, and again, wheelspin is a touch better. At least more easily modulated off the line. For 90 bucks I am extremely happy.
I am going to put a fuse on that battery line here as soon as I figure out what I want.
Davenow is offline
Old 03-01-2012, 05:43 PM   #55
Davenow
Member#: 23676
Just washed it real good, and did a light detail under the hood for Cobb austin first thursday.
Its also misting out. If its raining I am staying home with my nice clean dry car.
Davenow is offline
Old 03-01-2012, 06:14 PM   #56
oakcliff
Member#: 273767
Red
Had it towed to Sewell Subaru because my clutch went out 40 miles from home. Just in time for the Hill Country Cruise.
Now its time for warranty roulette!
FML
oakcliff is offline
Old 03-01-2012, 07:14 PM   #57
Davenow
Member#: 23676
FML
SURVEY SAYS!!???
DENIED!!!
Davenow is offline
Old 03-01-2012, 07:26 PM   #58
oakcliff
Member#: 273767
Red
Originally Posted by Davenow
SURVEY SAYS!!???
DENIED!!!
Most likely outcome
oakcliff is offline
Old 03-01-2012, 07:48 PM   #59
TOI
Member#: 238230
98 impreza sedan
remembered i drive a front wheel drive subaru....
TOI is offline
Old 03-01-2012, 09:25 PM   #60
TOI
Member#: 238230
98 impreza sedan
oh and i tried driving up a hill and my check engine light came on again. it seems to do that alot when i'm under a load
TOI is offline
Old 03-02-2012, 01:20 PM   #61
oakcliff
Member#: 273767
Red
FML
They are covering under warranty
Big thanks to Bryan at Sewell!!
oakcliff is offline
Old 03-02-2012, 06:58 PM   #62
Davenow
Member#: 23676
Nice!
Davenow is offline
Old 03-02-2012, 10:01 PM   #63
8thWonder
Member#: 230366
2005 STi
it's motor buildin' time!
finalllly got it washed. about to go vacuum the interior and remove the front lip to prepare for the Hill Country cruise tomorrow
8thWonder is offline
Old 03-03-2012, 04:26 AM   #64
8thWonder
Member#: 230366
2005 STi
wired up the wideband gauge and installed it into the blank Subtle Solutions ashtray bezel, further growing the nest of wires in my dash.
Old 03-03-2012, 05:14 PM   #65
TheTallOne
Member#: 302855
2008 WRX
DGM/CF
New toys, cosworth tgv deletes. Can't wait for the intake manifold to get here so I can start polishing.
TheTallOne is offline
Old 03-04-2012, 12:33 AM   #66
aznburn210
Member#: 84062
2005 WRX
CGM on Bronze Work's
Installed my clutchmasters fx300 clutch and act flywheel. Feels good! Let the break-in begin
aznburn210 is offline
Old 03-04-2012, 01:04 AM   #67
RustyHinge
Member#: 299742
2007 STI Limited#382
07 WRB STI sold 9/28/12
Added my first decal.... I'm from Washington state, now living in Houston.
RustyHinge is offline
Old 03-04-2012, 01:05 AM   #68
RustyHinge
Member#: 299742
I want these!
Old 03-04-2012, 01:29 AM   #69
Dka67
Member#: 296721
11 5door
Not today, but yesterday! Installed Perrin front 25 and rear 22 sway bars, and KartBoy Endlinks. Also installed KartBoy front and rear shifter bushings. Great upgrades!!!
Dka67 is offline
Old 03-04-2012, 02:48 AM   #70
Jester808
Member#: 166085
1990 Skyline GTR
Jet Silver Metallic
Flushed and replaced the fluid in the power steering, transmission, and diff on the FXT.
Old 03-04-2012, 09:46 AM   #71
2_fast
Member#: 237523
2008 WRX Wagon
Installed some new Eibach sways, Centric blank rotors, Hawk HPS pads, Goodridge stainless braided brake lines and flushed the brake fluid with some synthetic. Now need to flush remaining fluids with synthetics and find me some struts (08 WRX anyone???) to install my new Eibach springs as well.
2_fast is offline
Old 03-04-2012, 10:19 AM   #72
JbibWrx
Member#: 203162
2005 Wrx
Íhlin is the only way to go on struts. I think that spelling is correct?
JbibWrx is offline
Old 03-04-2012, 10:31 AM   #73
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Oops. Wrong thread.
5lipstream is offline
Old 03-04-2012, 05:39 PM   #74
Damned_Yankee
Member#: 278251
2008 WRX
Washed and waxed her although she's probably going to get caked in pollen overnight.
Damned_Yankee is offline
Old 03-04-2012, 06:36 PM   #75
TheTallOne
Member#: 302855
2008 WRX
DGM/CF
Raised it 1/2" to keep my new tires from rubbing.
Closed Thread
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-14-2009 11:42 PM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
