#126 |
Member#: 123370
SWIC
Vehicle:06 WRX TR WRB |
Hyundai actually does use the ZF6HP26 in their 4.6l Genesis and their equus models... They are really good 6 speed units that get used in a lot of high end BMW/ Land rovers / Jaguars... They're Strong 6 speed transmissions.
#127 |
Member#: 236710
NESIC
Vehicle:2010 WRX Five Door WRB! |
I like the looks of the Veloster but I agree with the at least 220 HP.
The GTI is the most refined of hot hatches but underpower also IMHO and the new 250 HP Golf will be 30K which is CRAZY and why I will stay with the WRX/STi's. |
#128 |
Member#: 12434
Tri-State
Vehicle:2002 Impreza WRX Aspen White |
201 - 220 is a 19 horsepower difference. Does it really matter that much?
#129 |
Member#: 43748
TXIC
Actually the mk6 gti is underrated from the factory. Most are putting about 200 at the wheels. The torques curve on the gti is long and flat and comes real early in the rpms. I never once felt the gti could use more power, in fact at times the torque was annoyance.
#130 |
Member#: 298119
Vehicle:2005 Impreza WRX PSM |
#131 |
Member#: 124113
NESIC
Vehicle:and beyond! |
#132 |
Member#: 12434
Tri-State
I wish they would just post the numbers for 0-60 and price already.
#133 |
Member#: 873
TXIC
Vehicle:2013 Golf R 1971 240Z |
Anything around 6 or 7 seconds will be just perfect for this car.
Expect. No more I want to hear how it drives |
#134 |
Member#: 163775
Vehicle:1984 Sheep Dog |
#135 |
Member#: 128760
RMIC
Vehicle:2012 Ruckus/WRX Red&White/Gray |
#136 |
Member#: 12434
Tri-State
#137 |
Member#: 163775
Like Scrappy said in so many words, this car will certainly make smiles happen.
#138 |
Member#: 236710
NESIC
#139 | |
Member#: 236710
NESIC
Last edited by lovin' it; 03-02-2012 at 12:44 AM. Reason: Had to leave for a few! |
#140 | |
Member#: 157348
South East
Vehicle:high impact sexual violence |
Airflow to the FMIC is an issue though. |
#141 |
Member#: 873
TXIC
FAst is relative to feel. Do not allow yourself to get sucked into being brainwashed into thinking you need to do 4.5 seconds to 60 to be fast. Fast is a marketing term at best. The old MG's and Triumphs and Datsun Roadsters of the time struggled to break 9 seconds getting to 60, but they were great fun to drive.
I would LOVE it if people started putting more of an emphasis on fun to drive, than in nurburgring times and magazine stats. CArs would get cheaper, mpg could go up, and in general people would be happier! But that is just my 38 years of experience talking. |
#142 |
Member#: 12434
Tri-State
I agree with you! 99% of the time everyone is driving their car to and from work or to the mall so needing a car with 9,000 horsepower isn't really necessary.
I'm looking at getting the Veloster Turbo because I think it looks cool, has a ton of gadgets, should be plenty quick and fun, runs on 87 octane, and gets good gas mileage, and it "should" be a pretty good price. |
#143 |
Member#: 7887
Pricing has already been released.
#144 |
Member#: 12434
Tri-State
#145 |
Member#: 7887
I swear I saw $21,xxx officially somewhere. Google isn't proving my memory right, though.
#146 |
Member#: 271589
Vehicle:2012 WRX Obsidian Black Pearl |
Hyundai needs to stop with the cat fish mouth grill. It's as bad as the mazda's front. It's not that hard to design a front end. Just look at what the aftermarket is doing in terms of front fascia's and put your own spin on it. Luckily, we have the aftermarket if they don't realize their mistake.
#147 |
Member#: 304819
SWIC
#148 |
Member#: 136612
Tri-State
Vehicle:2002 WRX SRP |
#149 |
Member#: 12434
Tri-State
#150 |
Member#: 119958
Vehicle:2005 Legacy GT Ltd. Garnet Red Pearl |
It is a 1.6 liter version of the GDI Turbo.
direct injection into the combustion chamber mitigates the need for high octane, since the fuel doesn't have to pass through the hot walls of the intake port in the head, where it can pre-detonate. High octane just means it resists detonation more, not that there is more or less energy content in the fuel. It has to be used with carbureted or port fuel injected engines that run hotter, to prevent pre-detonation in the intake tract, or ignition too early in the compression stroke, which can cause damage to the engine. commonly referred to as "pinging" or "knocking." Knock sensors bolted directly to the engine listen to the acoustics of the engine to isolate that signature, and signal a dial back in ignition timing to prevent damage. Lower octane gasoline actually requires less pressure or heat or spark strength to ignite. It burns more easily, which actually helps combust the full fuel charge, with less unburned hydrocarbons in the exhaust. Injecting that fuel directly into the end of the compression stroke prevents pre-detonation merely by the time aspect of when the fuel is introduced, so higher octane tends not to be required. It can also meter the fuel delivery to more approximate a stratified, leaner burn, rather than all the fuel, at a richer mixture, being delivered before ignition starts. |
| Thread Tools | |
| Display Modes | |
| FS : Sold Please Remove | legspecb08 | Engine/Power/Exhaust | 29 | 03-21-2012 10:17 PM |
| 2013 Hyundai Genesis Coupe Confirmed With 350-HP V6, 275-HP 2.0L Turbo | AVANTI R5 | Non-Subaru News & Rumors | 183 | 02-23-2012 08:49 PM |
| Hyundai Veloster Turbo Heading to SEMA Show with Rally Car Style | AVANTI R5 | Non-Subaru News & Rumors | 29 | 10-04-2011 09:45 AM |
| Spy Photos: 2013 Hyundai Veloster Turbo | AVANTI R5 | Non-Subaru News & Rumors | 89 | 08-27-2011 12:50 PM |
| WRC: no S2000+ for 2010, 1600cc+turbo in 2013 | bmxpunk | Motorsports | 4 | 03-02-2009 05:01 PM |
