Old 03-03-2012, 08:12 PM   #1
SoulApostle
Member#: 163682
Default switching oil brand issues PLEASE HELP
Hello all, I have a 07 wrx with cobb stage 2 catless. I just changed my oil a day and a half ago switching from gtx synthetic to valvoline now it acts puttery in my early rpms would switching brands over filling cause that because i did over fill a little
SoulApostle is offline   Reply With Quote
Old 03-03-2012, 09:08 PM   #2
how much over filled??
Old 03-04-2012, 06:37 AM   #3
mikeythejew
Member#: 141672
A: You can overfill it to a point it will bog the engine down.
B: Going form a thin viscosity like 5W30* to something thicker like 20W50, will cause a loss in horsepower felt by the butt dyno.
C: An engine overfilled with oil can lead to many problems depending how much overfilled it is.
D: Switching brands with the same viscosity shouldn't be felt unless your a hypersensitive freak.
* Uncle Scotty @ 5W30.
mikeythejew is offline   Reply With Quote
Old 03-04-2012, 09:29 PM   #4
CosmoTheCat
Member#: 3409
1/2 quart overfull, no big deal. 2+ quarts over full, maybe a big deal. 5 quarts overfull, definitely a big deal.
CosmoTheCat is offline   Reply With Quote
Old 03-11-2012, 08:15 AM   #5
megabyte5689
Member#: 313179
I've always been told as a good rule of thumb that if you start the vehicle out with a synthetic oil, you stay with the synthetic oil. I've heard way too many stories of leaks showing up after the switch and other problems arising. I just use the 5w30 in mine and change it at the 3,000 mile mark
megabyte5689 is offline   Reply With Quote
Old 03-11-2012, 01:12 PM   #6
bluesubie
Member#: 767
04 FXT
Even though SoA recommends that you stick with synthetic if you begin using it in the latest Outback owner's manuals, this is 1980's logic. You can contact any of the oil companies and they will tell you this. Oil manufacturers today balance their oils much better than oils only just a few years ago. Now if if have been running conventional in a WRX for 75,000 miles at 6,000 mile intervals, chances are there is a lot of sludge in the engine and around the gaskets and seals. Switching to a synthetic in this case will clean up the sludge and perhaps leak past the seals that were previously blocked with sludge. This is just a case of poor maintenance the first place.
http://www.mobiloil.com/USA-English/...eage_Cars.aspx
http://www.mobiloil.com/USA-English/...ics/Myths.aspx
Myth: Mobil 1 will leak out of the seals of older cars.
Reality:
Mobil 1 does not cause leaks. In fact, new Mobil 1 was tested in dozens of industry standard and original equipment manufacturers (OEMs) tests to prove its seal performance. It is fully compatible with the elastomeric materials from which all automotive seals and gaskets are made. If an older engine is in good condition and does not have oil leaks, Mobil 1 provides the same advantages as when used in a new engine. ExxonMobil recommends taking measures to repair the leaks, then using Mobil 1. ExxonMobil also recommends following the automobile manufacturer's manual for the proper oil to use.
-Dennis
switching oil brands...bad? hi-revs Service & Maintenance 3 12-21-2011 09:32 PM
L ---> RS window switch toubles....ELECTRICAL GURU's please help hail2theTheif North West Impreza Club Forum -- NWIC 13 08-09-2011 12:04 AM
big hit in MPG after switching oil brand mattymx Service & Maintenance 44 10-30-2009 08:33 PM
Oil line issues!! PLEASE HELP!! street_racen_va Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-23-2009 12:22 AM
Sti Injector issue please help WRC WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-01-2003 12:45 PM
