![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 235745
E. Canada
Vehicle:2011 WRX 5dr WRB |
I know this is probably a long shot, but I've been looking for an 18X9 5X100 wheel in the 44 to 48 offset range and haven't been able to find much. I'm thinking +45 offset would be about the perfect fitment on the widebody 2011/2012 WRX without having to do fender modifications but still being 21mm less tucked than the stock wheels. It might also work well on older model WRX's possibly with some slight fender mods.
I really like the T2R style wheel and I asked Tommy at wheeldude about it. If we can get around 15 people who are interested we might be able to make it happen. Post here if you're interested. 18X9+35 G-forces run for $950 a set and 18X9.5 T2R's run for $1050 a set so I'm guessing these would be in that same price range. ![]() ![]() Gold ![]() Flatblack ![]() Hyper Black ![]() Hyper Silver ![]() Titanium Chrome ![]() White ![]()
#2 |
Member#: 271121
NESIC
Vehicle:2011 WRX Limited 4dr SSM |
I would love this wheel on my 2011 WRX!!!
#3 |
Member#: 139955
NESIC
Vehicle:# OneBoston |
I would think inboard clearance would be an issue.
#4 |
Member#: 235745
E. Canada
The inner clearance would be 5mm less clearance than the stock '11+ WRX and 4mm more than a stock 08+ STI so it should be fine. Many people are running 18X9.5 +38 on these cars (with fender modifications) with no inner clearance issues and that setup is 4mm less inner clearance than a stock widebody 3G WRX.
The 08+ STI setup has 8mm less inner clearance than the 11+ WRX so there is no reason 5mm less should be an issue. |
#5 | |
Member#: 97135
NWIC
You will run into inner clearance issues when running larger tires with stock struts. |
#6 | |
Member#: 235745
E. Canada
You are right that 18X9 +45 has 1mm less inner clearance than 18X9.5 +38 (18X9 +45 = 5mm less clearance than WRX, 18X9.5 +38 = 4mm less clearance than WRX, 5mm-4mm=1mm). I didn't mention that specifically, only that 18X9.5 +38 was 4mm tighter on the inside than OEM WRX. Both have more clearance than the OEM sti (if my above assumption is correct) so unless the WRX struts are significantly different than the STI in that area then I would think there should be no issue? |
#7 | |
Member#: 97135
NWIC
Its a difference of 3-4mm at the inside of the wheel, I'm not doubting that the wheel clears stock suspension - but when you run larger tires, that gap can easily be filled up. |
#8 | |
Member#: 235745
E. Canada
After all my research this seems like the best wheel fitment in terms of being as flush as possible without requiring fender mods on the 11+WRX, unfortunately finding 5X100 wheels in this configuration is tough. This size would probably even work well on earlier models to reduce the amount of fender work needed in comparison to something like an 18X9.5 +38 (which sticks out 13mm further). |
#9 |
Member#: 97135
NWIC
But then that gets into why you feel you want to run a tire that wide on a daily?
What is your current ride height? There have been plenty of people fitting 18x9.5 +40 with 265's on stock suspension (and mayyyybe a rear roll). |
#10 |
Member#: 184615
South East
Vehicle:2004 WRX Red |
I'm interest i G-force 18X9 5X100
#11 |
Member#: 308190
TXIC
Vehicle:2012 wrx hatch dgm,2010 swp legacy prem. |
Im interested in this group buy,so what kind of tires your planning to run?
#12 | |
Member#: 235745
E. Canada
I'm on stock suspension now and the lowest I'd go would be GTWORX/Bilstein which is only a 15mm drop. I realize that 18X9.5 +40 fits with a rear roll, but that is one of the points of the wheel fitment I'm looking for, I'd prefer not do that modification to my car. |
#13 | |
Member#: 235745
E. Canada
To maintain your speedometer/odometer reading 265/35R18 is another option with this wheel as 9" is the narrowest wheel that is is recommended for that tire size. This tire would have the same diameter as the OEM 11+ WRX 235/45R17 tires (25.3"). Yet another option would be 255/40R18. This would be 26" in diameter which would result in even taller effective gearing. It would also throw your speedometer off by 2.8% so many would probably say this size isn't recommended. |
#14 |
Member#: 53967
Tri-State
Vehicle:2011 WRX Premium Satin White Pearl |
I am definitely interested so please let me know if this group buy becomes active
#15 | |
Member#: 308190
TXIC
#16 |
Member#: 235745
E. Canada
Don't worry, that won't be an issue. Like discussed above, this setup would still have more inner clearance than the STI factory setup. Also it is very similar to the inner clearance that you have with an 18X9.5+38 or 18X9.5+40 wheel and 265/35 tire setup that many people are running.
#17 |
Member#: 235745
E. Canada
#18 | |
Member#: 308190
TXIC
#19 |
Member#: 301554
BAIC
Vehicle:2002 WRX Wagon PSM |
I'd be interested in titanium chrome 18X9 T2R. Subscribed.
#20 |
Member#: 288037
NWIC
Vehicle:2013 Orange XV 11' WRX *sold* |
I just bought some 18x9.5 +38 wheels. Waiting on my 265/18 tires and ill post my results. Going to be rolling the rear
#21 |
Member#: 159474
AKIC
Vehicle:2013 BRZ Ltd 6MT CBS Counter-steer like a boss |
I was actually thinking about giving up on the Gravels and going with these. No one has them in my state, yet, and I think they go well with the 3G WRX widebody.
I'm wondering what the discount would be for this group buy? I'd go with hyper black. I'm 89% sure I want this set-up, just depends on when. Plus I'd be giving up on my dream of JDM STI TS wheels for this year if I got these wheels. ![]() Last edited by chanomatik; 03-05-2012 at 08:02 PM. |
#22 |
Member#: 300323
1050 for replica fake wheels =\ iif price is cheaper i would be down (800 ish )
#23 | |
Member#: 235745
E. Canada
#24 |
Member#: 280177
Vehicle:2011 wrx DGM |
interested if this gets off the ground
#25 |
Member#: 276611
MWSOC
Vehicle:2011 STi 5-Door Plasma Blue Pearl |
I'm really liking those T2Rs! So if this takes off, would the group buy be fore $1050, or slightly less?
| Thread Tools | |
| Display Modes | |
| FS : DELETE seperated rims | 08blackpearl | Wheels/Tires | 6 | 03-29-2012 09:10 PM |
| FS : Vermont - Set of 18x9.5 Rota T2R Hyper Black 5x100 +38. FRESH! ~1500 Miles! | johnrocs | Wheels/Tires | 7 | 11-06-2011 11:26 AM |
| FS : Rota G-force 18x9 +35 5x100 Gold - Brand New - Los Angeles 90045 | fredtga | SCIC Private Classifieds | 20 | 05-13-2009 01:50 PM |
| FS : Rota G-force 18x9 +35 5x100 Gold - Brand New - Los Angeles 90045 | fredtga | Wheels/Tires | 14 | 05-10-2009 09:58 PM |
| Work XSA 02C Group Buy! 18x9 +45 5x100 Gold with Polished Lip! | WorldOne | Vendor 'Group Buy' Classifieds | 4 | 09-24-2008 10:51 AM |
