Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 03-01-2012, 02:28 AM   #5376
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Originally Posted by amalgrover
yeah...btw ron, would you mind pm'ing me your paypal address please. i am not really sure when i will send it, but i still owe you some $ from that tune
you're like the 8th person in the last month that's said they still owe me money. I gotta start keeping track of that.
Old 03-01-2012, 03:06 AM   #5377
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
And charge interest lol...
07wrx84 is offline   Reply With Quote
Old 03-01-2012, 04:09 AM   #5378
Rem1993
Member#: 234680
2011 STI Sedan
Plasma Pearl Blue
Whats the biggest and what brand injectors recommended for E85 on a daily driver . I already running DW1000cc on a GT3076R. I want to keep good idle and drive ability , as I will be running pump 93 65 to 70% of the time.
Rem1993 is offline   Reply With Quote
Old 03-01-2012, 08:51 AM   #5379
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
Pm me your address ron. I wanna send you something...
maxpowr is offline   Reply With Quote
Old 03-04-2012, 02:55 AM   #5380
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I finally joined the E85 club today. I went with FiveO custom series 1000's. I found them to be really easy to tune with only slight adjustments needed from the provided flow and latency times. They idled and ran like stock when I setup the gas tune. E85 was easy to dial in from there. I can already tell a difference and I haven't touched boost, fuel or timing from my fairly conservative Stage 2 tune. I can't wait to see how it responds to some more tuning.
One things I found to be odd and I haven't seen anything about:
I started out by running the car down to E and adding 5 gallons of E85 (it was about 73% E). I tweaked the tune until the fuel trims were good and drove it almost back to E again. I reset trip A at the start of my drive and the avg MPG was reading 35 after 60 miles or so. As awesome as that would be it was obviously wrong. I filled all the way up with E85 and adjusted my tune again and drove about 20 miles or so. The MPG reading seems more normal now but it still not reading lower than gas like I thought it would. I haven't done anything to try to improve fuel economy.
My question is: is the Avg MPG reading accurate when running E85? I don't know anything about how its calculated but I assumed it would still be accurate. Thoughts? What avg MPG reading do people normally see?
WRXt4cy is offline   Reply With Quote
Old 03-04-2012, 03:14 AM   #5381
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
why use a reading....just run a tank....miles/gallons = mpg
PhatBotti Tuning TKR is offline   Reply With Quote
Old 03-04-2012, 11:11 AM   #5382
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
it will always be much worse than gasoline, wait till you get on summer mix( 85) and also it usually takes around three tanks depending on how low you were able to get your tank, to get all the left over gas out. So with that in mind keep an eye on your fuel trims as they might need readjusted at your next two fill ups.
I probably get around 13 city and never go to far with the car on E so am not sure about highway mpg.
mecpgh is offline   Reply With Quote
Old 03-04-2012, 12:58 PM   #5383
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
It's not reading correctly because you changed the size of the injectors. The ECU assumes the stock (~500cc) injectors when doing this calculation. Because you nearly doubled the size of the injectors, your MPG readout will be off by nearly double. You will just have to use the trip meter and calculate miles/gallons yourself.
Old 03-04-2012, 01:48 PM   #5384
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Thanks xluben. That's exactly what I was looking for. I figured the avg MPG reading was pretty worthless now.
I went through a quarter tank in about 60 miles or so its burning through it quickly like it should be
Old 03-04-2012, 03:05 PM   #5385
Maxwell Power
Member#: 190729
It uses injector pulse width to calculate mpg. So as it was said, changing injectors changes the reading. With e85, you can add 30% to your injector size and it would still be close. However, what fun is that?
I have often wondered if it would be an adjustable feature or firmware flashable. Na legacy's and imprezas have the same type of mpg computer feature in the same housing so maybe it is just a chip or a jumper that differentiates the settings between the 550 and 270 injectors.
Maxwell Power is offline   Reply With Quote
Old 03-04-2012, 09:13 PM   #5386
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I had thought maybe the mpg calculation would take into account the new injector scaling but I guess not. Like your saying it just sees the new, lower pulse width and calculates the mpg reading higher.
It would be nice if it could be corrected but its really not that important. I'm just mildly OCD so I like have everything read correctly
Old 03-05-2012, 12:17 AM   #5387
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Got tuned on " speed density " today!! Car feels great.
Old 03-06-2012, 02:56 AM   #5388
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
got some acceleration times for you guys...
50-100mph= 4.5 sec
50-130mph= 8.66 sec
60-130mph= 8.41 sec
...i will post up the vid when i get home from work in the morning. honestly, the 50-100mph time was a **** hair slow because it got away from me a little bit and lost traction, and since it was breaking loose, i was shifting a little slower than normal.
...btw, i kept it so that i use 2nd and 3rd for 50-100mph and 2nd, 3rd, and 4th for 50-130mph...
amalgrover is offline   Reply With Quote
Old 03-06-2012, 08:23 AM   #5389
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
50-100mph= 4.5 sec
50-130mph= 8.66 sec
nice! what was the 60-130mph? the high hp guys usually measure 60-130mph not 50-130mph.
Here are some times for comparison:
3.04 - Underground Racing TT Gallardo E-Gear (Bob Helms' car) / 1-shift
3.31 - AMS Alpha 12 GT-R
3.33 - Divexxtreme / Switzer R1KX GT-R
3.53 - Underground Racing TT Gallardo Nera 6-MT / 2-shifts
3.61 - HoustonT / Underground Racing TT Gallardo 6-MT / 1-shift
3.85 - Switzer / R1K GT-R / 2-shifts
3.95 - 1swtride / C6 Z06 / built 427, YSI blower, 1080rwhp, auto
4.09 - Acicchelli / TT Gallardo / 1-shift
4.21 - DJborya / BMW 325i / S52 with 80mm turbo / 1-shift
4.23 - TwinTurboM3 / TT E46 M3 with nitrous / 0-shifts (4th gear only)
4.49 - TwinTurboM3 / TT E36 M3/ 0-shifts
4.52 - jbsteven / SC&TT Ford GT 994 rwhp / 1-shift
4.53 - HoustonT / 880 rwhp Supra / 1-shift
4.55 - Greg-TT / 770awhp GT-R
4.70 - SCvette00 / Switzer E900 GT-R / 824 awhp
4.87 - Oz / Supra / 1-shift
4.88 - 1SwtRide / C6 Z06 / 1,080rwhp
5.14 - Hllywood / TT Viper / 93 octane/ 2-shifts
5.24 - Blacksheep / Supercharged '08 Z51 Corvette, Dallas Performance 1000: Forged 416, ProCharger F1C @ 18psi, Alky Control Methanol 942whp/938tq, 0-shifts
5.27 – Lil Powell / C5 Vette with big motor and NOS
5.51 - FiskeGTS / Heffner bolt-on TT800 Gallardo
5.61 - RaceMX-M3 / Turbocharged E46 M3 / 1-shift
5.74 - Divexxtreme / Supercharged C6 Z06 / 1-shift
6.23 - MikeWads / E92 M3 DCT with ESS SC and 100 shot of nitrous
6.36 - Jmoney / Supercharged E92 M3 11 psi, 1-shift
6.59 - Dads C63 / Bolt-On C63 AMG + 125 shot of Nitrous
6.65 - Acicchelli / Renntech SLR
6.73 - FikseGTS / Ford GT with pulley and Heffner tune
6.80 - DLSJ5 / ESS SC'd E92 M3 DCT / 3-shifts
6.85 - gringointegra / TC'd Acura Integra, 1-shift
6.89 - Vrybad / C5 Z06TT (APS Turbo, no cats, stock muffler, 573 rwhp @ 9.5 psi) / 1-shift
6.95 - hotrod182 / 335i w/ JB3 piggyback ECU and Nitrous / 2-shifts
7.05 - Divexxtreme / 2010 GT-R, Switzer cat-back exhaust, drop-in air filters and Switzer 100 octane tune, peak boost 18
7.24 - Acicchelli / Stock SLR
7.48 - Acicchelli / Renntech SL65 AMG
7.52 - IMG / E90 M3 / ESS VT625 Supercharged
7.58 - PencilGeek / E92 M3 6-MT, RD Sport RS-46 "Stroker" motor and ESS Tuning S/C (6.25psi)
7.59 - Blacksheep / C6 Corvette Z51 (heads/cam, 484 rwhp) / 2-shifts
7.60 - Easy2Speed / GT-R / downpipe, mid-pipe and tune
7.71 - TMC CL65, '09 CTS-V with 8.6" pulley, CAI, LS7 ported TB, headers w/ cats, heat exchanger
7.74 - HoustonT / GT-R / 640 HP (downpipes, y-pipe, BC, hard IC pipes, custom tune)
7.85 - Acicchelli / Stock LP640 / 2-shifts
7.86 - Divexxtreme / Stock C6 Z06 / 2-shifts
7.95 - Byzantine / '06 Gallardo 6-MT, catless exhaust & 105lb weight reduction, 2-shifts
8.04 - JHDavis / SL65 with tune
8.08 - Dads C63 / Bolt-On C63 AMG
8.16 - 930chas / E55 AMG
8.25 - Dodger63 / C63 MHP headers, tune, intake, scoops, DRs and skinnies, race fuel
8.24 - DrivenAgain / CL600 AMG
8.28 - KeithTA, Panamera TT with ecu flash
8.31 - biglare / SC'd E90 M3 DCT / 2-shifts
8.40 - bassn_07, E5 with full bolt-ons
8.45 - TMC CL65 / '09 GT-R, mid-pipe, tune
*3.40 – Bob Helms, TT Viper, Auto
*3.53 – Underground Racing TT Gallardo, 1,300 rwhp, 2-shifts
*3.93 – 931 rwhp Supra, 88mm turbo, TH400 Auto, ET Drags
4.8 – 900 rwhp Supra (88GT47, TH400, no NOS, drag radials)
4.9 – 940 rwhp Supra (35 psi)
*5.1 – 780rwhp 240SX with Supra motor, 3-shifts (trapped 152 on this run)
5.1 – 840 rwhp Supra (30 psi)
*5.26 – 997 GT3 RS TURBO / 1-shift
5.4 – 1,000 rwhp TT Viper
5.6 – Bugatti Veyron
*5.72 – Subaru Impreza GC8, built motor, big turbo and 100 shot of nitrous
*5.8 – Ford GT, Whipple S/C, 780 rwhp, 1-shift
5.9 – GSXR 1000 with bolt-ons
6.1 – Saleen S7 Twin Turbo
6.6 – Ford Cobra, Whipple S/C at 22 psi
6.9 – Mosler MT900S
7.0 – Ferrari Enzo
*7.06 – C6 Z06; intake, tune, headers, cam, no cats, 560 rwhp, 2-shifts
*7.24 – Mercedes SLR McLaren
*7.25 – Stock 997 GT2 / 1-shift
7.3 – Porsche Carrera GT
7.3 – Ferrari Enzo
*7.66 – 996 TT ‘S’ with K16/24 Hybrids, 4th gear pull only
*7.75 – Shelby GT500, Kenne Bell, 700+ rwhp, 1-shift
*7.8 – Lamborghini LP640, stock, 2-shifts
*7.8 – Chevrolet Corvette C6 Z06, stock, 2-shifts
7.8 – Chevrolet Corvette ZR1
7.9 – RX7, turbocharged (GT35), 360+ rwhp -
9.1 – Porsche 993 RUF Turbo R (100 octane)
9.4 – Lamborghini Diablo VT 6.0
9.5 – Porsche 997TT
Old 03-06-2012, 09:25 AM   #5390
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
50-100mph= 4.5 sec
50-130mph= 8.66 sec
Great! Awesome to see someone else try this. Do you think you could post up the following info? I will start a list of more people want to do a 50-100. If anyone else wants to extend the pull out to 130, I'd be happy to make another list for comparison against the other 60-130 lists out there.
http://forums.nasioc.com/forums/show...8#post36420698
Vehicle: 2011 WRX
Motor: Stock
Turbo: Blouch 20G XTR
Transmission: Stock 5 Speed
Redline: 6700rpm
Upgrades:
  • Invidia Catless Downpipe
  • Stock Catback Exhaust
  • Tial 44mm EWG
  • FMS FMIC
  • KSTech Intake
  • Five-0 1200cc Injectors
  • Walbro 255 Fuel Pump
  • E85 Tuned
  • Steelies and Winter Tires
Weight: Full Stock Weight + Driver
50-100MPH: 5.33sec
Old 03-06-2012, 09:28 AM   #5391
amalgrover
Member#: 183480
2009 Forester XT
added the 60-130mph time...and here is the vid...you can really see how much it spun at the top of 2nd cause I brake boosted and it slowed me down some (got ALOT of torque steer and had to get it back straight before getting back on it ). so figure about 0.5 sec faster in not freezing weather when i can shift faster and not have to worry about breaking loose...
Old 03-06-2012, 09:41 AM   #5392
amalgrover
Member#: 183480
2009 Forester XT
Vehicle: 2011 WRX
Motor: Stock
Redline: 6700rpm
Upgrades:
  • Tial 44mm EWG
  • FMS FMIC
  • KSTech Intake
  • E85 Tuned
50-100MPH: 5.33sec
here ya go ...
Vehicle: 2002 WRX Wagon
Motor: EJ255 longblock with CP pistons/Element Tuning Rods 9.77:1 CR and completely stock heads, cams, and exhaust manifold
Turbo: FP Red 8cm
Transmission: 5 speedPPG straightcut 1-2/helical 3-4 stock subaru 5th
Redline: 7600rpm
Upgrades:
  • TurboXS catless RFL-Ti Turboback
  • SSAC FMIC
  • KSTech Intake
  • FIC 1250cc Low-Z Injectors
  • DW300 Fuel Pump
  • Kenne Bell Boost-A-Pump
  • Perrin 3" Inlet
  • DIY TGV Deletes
  • 06-07 WRX wheels
  • E85
Weight: 3336lbs + Driver
50-100MPH: 4.5sec
Old 03-06-2012, 09:57 AM   #5393
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Wow , very impressive .
smeerone is offline   Reply With Quote
Old 03-06-2012, 10:45 AM   #5394
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Awesome! How much power was the car dyno'd at? I think that's probably something I should add to the template, because I know people will be curious to know.
Old 03-06-2012, 09:33 PM   #5395
Phatron
Member#: 36033
CEO PhatBottiTuning
^ u should start your own thread so this doesnt turn into 50-100mph thread.
Old 03-06-2012, 10:07 PM   #5396
02RexWI
Member#: 165141
Last time I tried to start a thread like that I got bitched out by a moderator for "going too fast on the road"
02RexWI is offline   Reply With Quote
Old 03-06-2012, 10:14 PM   #5397
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
^^^ its never right on here lol
Old 03-06-2012, 11:52 PM   #5398
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
500whp daily driven 02 WRX Wagon 50-130mph - YouTube
Holy crap! what's your setup, or if it's here I missed it.
340Duster is offline   Reply With Quote
Old 03-06-2012, 11:58 PM   #5399
Phatron
Member#: 36033
CEO PhatBottiTuning
Red on e85
Old 03-07-2012, 12:05 AM   #5400
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
still a 2.0?
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 03:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 11:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 09:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 12:01 PM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 08:06 PM
