Old 02-20-2012, 04:34 PM   #1
jmews
Member#: 310897
Default Roof rack options for 2012 Impreza
I searched, but could not find much information on this.
It looks like I am going to be forced into buying a sedan, as my car died and we are in a hurry to purchase (been renting for a week now). Hatches in Socal are all slightly out of our price range (or just plain unavailable!), but we can get a sedan for $500 under invoice. We specifically are looking for premium, CVT, all weather.
I was okay with this compromise, as I figured I could put my bike on the roof. Browsing the Subaru website, it looks like the roof bars are only available for the hatch. This is a big problem! I can't find anything compatible on Thule or Yakima, but I am entirely new to this whole roof rack thing as I previously drove an Outback wagon and could fit anything I needed in there!
We WERE going to buy tonight (sedan, awp premium - $19500 or $20k dependent on options), but this is something I cannot compromise on. Does anyone have any more information on this? Any potential solutions?
James
jmews is offline   Reply With Quote
Old 02-20-2012, 09:47 PM   #2
noahj
Member#: 310829
You are correct. The Subaru crossbar set is only for the hatchback, and neither Thule nor Yakima sells anything that fits yet.
I'd go for a hatch, regardless (can't imagine why anyone would buy a car with a trunk, since the hatch is so much more useful). If that's not on, see if you can get a tow hitch amd a hitch mounted rack.
noahj is offline   Reply With Quote
Old 02-20-2012, 11:57 PM   #3
RxMPLS
Member#: 303353
2012 Impreza
Sport Ltd
You can drill your roof and put racks on the sedan, but it's going to be a much easier option to go with the factory raised rails on a Sport model and then add a rack from there. If you need any help, call Yakima; they're super helpful over the phone. You can find their number on www.yakima.com
RxMPLS is offline   Reply With Quote
Old 02-21-2012, 02:47 AM   #4
somebody else
Member#: 21618
You don't even need the Sport rails.
The hatch rood comes with sockets for fixed-position cross-bars which can be removed and returned to flush easily. That's what I'm doing.
somebody else is online now   Reply With Quote
Old 02-21-2012, 03:02 PM   #5
RxMPLS
Member#: 303353
2012 Impreza
Sport Ltd
Somebody else is right -- this is a new fit since the last time I looked on Yakima's site. It's a good one, too.
The 5 door must have some attachment site where you can put Control Towers with Landing Pad 11 and 48" crossbars to build your base rack. This is actually a better fit than the one for the Sport models as it's rated at a higher weight-bearing capacity (165 pounds vs 125 pounds). Heck, now I wish I hadn't gotten a sport! You could carry nearly anything on this.
The four door will require Q Towers or drilling for a fit, though. Both of these are slightly more labor-intensive racks, and Q Towers should be removed when not in use. I'd go with a 5 door non-Sport...
Old 02-21-2012, 08:07 PM   #6
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
Default Impreza Sport Premium - Thule Aero Setup
I figured I'd chime in since I haven't seen anyone else with this rack on here yet. I moved my Thule Aero Bar Setup from my old car to the new Subie. I know you're talking about the sedan, but I love the way everything fits on the stock rails and I've been using the hell out of it going skiing!
BoxerSport2.0 is offline   Reply With Quote
Old 03-04-2012, 03:03 PM   #7
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
Has anybody actually confirmed that the attachment points aren't on the sedan?
Most places say no, but when I hit a search engine, came across this dealer/parts.subaru.com site:
Roof Carrier Bars
Description
Can be installed or removed in minutes. Fits both 4- and 5-door models and are compatible with most Genuine Subaru roof attachments and carriers.
I want to believe the above, but I doubt it is true. Especially when the WRX/STI and 2010-2012 model years are included.
Beanboy is offline   Reply With Quote
Old 03-04-2012, 03:57 PM   #8
RxMPLS
Member#: 303353
2012 Impreza
Sport Ltd
Roof Carrier Bars
Description
There might be attachment points there that would fit the Subaru branded roof rack, but not ones that Yakima currently has a fit for (as of last time I checked their site, at least). Aftermarket roof racks (Yakima and Thule, at least) tend to be superior to the Subaru branded racks, often made by companies that don't make great racks. Sometimes Subaru sells old Yakima racks rebranded as Subaru racks, too...also not as good as what you'll get directly from Yakima or Thule.
Old 03-04-2012, 04:18 PM   #9
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
I've got the Mont Blanc (http://www.montblancuk.co.uk/) cross bars on my LGT, which are the Subaru accessory bars for the LGT rails, so I figured Subaru re-branded.
My brother just got a 2012 Impreza sedan and was asking about roof rack options, hence the question.
Thanks to the OP for starting the thread BTW...
Old 03-04-2012, 04:23 PM   #10
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
Huh, plot thickens, check this out:
http://www.etrailer.com/roof-2012_Subaru_Impreza.htm
Yakima Control Tower Roof Rack - 2012 Subaru Impreza
Sedan with no existing rails or crossbars
Installation Notes
This system attatches to OEM fixed mounting points on your vehicle's roof
Capacity 165 lbs
Maybe there are attachment points on the sedan after-all?
Old 03-04-2012, 05:10 PM   #11
Geerolla
Member#: 264827
2011 2.5i 5D
All 2011s, sedan or hatch, had OEM mounting points. There's no reason Subaru would remove this from the 2012 models. Makes no sense. All you need are the 2012 OEM crossbars. There are numerous rack options available that will fit these bars.
Geerolla is offline   Reply With Quote
Old 03-04-2012, 06:04 PM   #12
RxMPLS
Member#: 303353
2012 Impreza
Sport Ltd
Installation Notes
Capacity 165 lbs
It's entirely possible. Yakima fits don't all come out at once -- for landing pad fits, sometimes a specific landing pad needs to go to production. Also, fits depend on Yakima's fit team obtaining a test vehicle from local dealerships or the manufacturer themselves. With a popular vehicle like the Impreza, it can be harder to get some models tested right away, so fits come out in varying timeframes.
Old 03-04-2012, 06:09 PM   #13
RxMPLS
Member#: 303353
2012 Impreza
Sport Ltd
Installation Notes
Capacity 165 lbs
Actually, this is probably referring to the WRX sedan. Yakima's dealer fit guide doesn't yet show a 2012 Impreza sedan fit with Landing Pads, and their fit guide is the final word. That doesn't mean it won't happen...but there isn't one designated yet. There is a Q Tower fit, but there might still be a forthcoming Landing Pad fit, also.
Call them if you have any questions: 1-888-925-4621
Old 03-06-2012, 05:27 PM   #14
transistor
Member#: 174473
I love my yakima
transistor is offline   Reply With Quote
Old 03-06-2012, 06:49 PM   #15
brockd
Member#: 235571
2012 Impreza 2.0i
more pics?
brockd is offline   Reply With Quote
Old 03-06-2012, 10:00 PM   #16
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
Originally Posted by brockd View Post
more pics?
I'll try and take some more tomorrow.
Old 03-06-2012, 10:43 PM   #17
brockd
Member#: 235571
2012 Impreza 2.0i
Thanks. Debating on buyin one for my car. Yours is the only I hav seen with another fairing.
Old 03-07-2012, 09:32 PM   #18
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
Here are some pictures, I will say if you go with the Thule setup go with 53' bars. The 47's are too short in the front you can see in the picture the end caps are not on. On to the pictures from today.
Old 03-07-2012, 10:19 PM   #19
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
brockd, what sort of MPG hit do you see with just the rack on?
Xafen is online now   Reply With Quote
Old 03-07-2012, 11:59 PM   #20
RxMPLS
Member#: 303353
2012 Impreza
Sport Ltd
There are some things that are just not polite to ask!
(long-time roof rack devotee here, but they do cut back on mpg, for sure...so I take mine off when not in use)
Old 03-08-2012, 01:48 AM   #21
brockd
Member#: 235571
2012 Impreza 2.0i
I don't have the rack yet... My wife has a pretty nice one though.
Old 03-11-2012, 03:32 PM   #22
freshrider
Member#: 312955
[quote=BoxerSport2.0;36572428]Here are some pictures, I will say if you go with the Thule setup go with 53' bars. The 47's are too short in the front you can see in the picture the end caps are not on. On to the pictures from today.
Thanks for the tip. I am gonna go for the 53". Do 53"s get in the way of your head when you enter and leave the car?
freshrider is offline   Reply With Quote
Old 03-11-2012, 09:21 PM   #23
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
[quote=freshrider;36602339]
I would think you wouldn't have an issue hitting your head as it only will stick out another 3" on either side. In reference to where the roof rails are I think it will just make it flush with the top of the door if anything.
Old 03-12-2012, 05:50 PM   #24
gobells12785
Member#: 313335
2012 Impreza Sport
[IMG][/IMG]
Here is my optional crossbar with thule snowboard rack
gobells12785 is offline   Reply With Quote
Old 03-14-2012, 04:44 PM   #25
huckedup16
Member#: 20612
2012 Impreza Sedan
I can confirm that there are NO mounting points on the 2012 sedan. I can also confirm from trying to mess around with it that there is no simple way to put a rack on the vehicle. No rain gutters or any good places where a hook can grab the roof.
I'm going to be pissed if this is the case and may even go so far as to trade the car in. Skiing and cycling is pretty integral part of my life.
Edit:
Just got off the phone with Thule. They stated that in about 2 weeks, they will be releasing the kit for the 2012 Impreza 4 door with the "Naked Roof". Parts needed will be:
480 Foot Pack
LB50 Load Bars
1649 Kit
Keep your fingers crossed that it actually works.
huckedup16 is offline   Reply With Quote
WTB : roof rack crossbars for 08+ impreza tnguye09 NWIC Private Classifieds 0 11-16-2011 12:51 PM
Roof rail options for a MY97 Impreza L wagon? Levvy Interior & Exterior Modification 1 08-21-2005 10:51 AM
Roof Rack Options for '03 mikebike357 Forester Forum 13 05-19-2003 10:01 AM
MY02 TS roof rack options AllWheelDrift Canada Region Forum 2 03-09-2002 09:31 PM
Roof rack question for those Impreza OBS owners SubyLova General Forum Archive 3 12-04-2000 10:23 PM
Message Board Statistics All times are GMT -4. The time now is 07:51 PM.
