Old 03-09-2012, 05:58 PM   #1
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Post Januch09's 2011 STi 600+whp Build (PTE6266)
Frank’s 2011 STi Limited (SWP Sedan) Build
Follow me on instagram @Fjannucci
Interior:
-Cipher Auto Reclineable Bucket Seats (black leather, black felt inserts, red stitching)
-Cipher Auto Harness Bar Powder Coated Perl White
-NRG 6 Point 3" Harnesses (red)
-NRG Harness Pads (black)
-GT SPEC D Shape Steering Wheel w/ Red Stitching
-Pioneer Avic-X930BT Head Unit w/ Navigation
-2 10" Kenwood KFCXW1000F Subwoofers (cf plate) w/ custom fiberglass trunk/floor enclosure
-Infinity Primus PR6500cs Front Door Components
-Infinity Primus PR6502is Rear Door 2-Way Speakers
-(1) Pioneer D9500M 800 Watt amp (for door speakers)
-(1) Pioneer D8500M 1200-Watt amp (for subwoofers)
-DynoMat front ann rear doors, rear deck & trunk
-Red LED front and back footwell illumination
-Red/White LED trunk illumination
-Red LED Dome Courtesy Light (custom)
-6k Dome & Map LED's
-SMY Clustermaker
-JCS 3 Gauge A-Pillar Pod
-AEM Air/Fuel Ratio Wideband Gauge
-AEM Boost Gauge
-AEM Oil Pressure Gauge
-AEM Fuel Pressure Gauge
-Zeitronix Ethonal Content Analyzer
-Escort Passport 9500xi Radar Detector (red edition) hard wired
-SWP Paint Matched Radio Bezel Trim, Shifter Trim, & Dash Vent Trim
-SWP Paint Matched AcessPort Face (Mounted near headlight switches)
-Anarchy Motive Weighted Shift Knob (Perl White)
-Subaru All-Weather Mats
-Spy-Tec A118-c Dash Cam hard wired
Exterior:
-15% Tint all around (except windshield)
-Crux Back-Up Camera
-Debadged Trunk (except STi logo)
-Bayson R CS Style Front Lip (painted gloss black)
-Custom Front Splitter by Galvez (painted gloss black)
-ForceWorkz Side Skirt Extensions (painted gloss black)
-Custom Shaved Front Bumper & Mouthpiece for FMIC & Molded Mini Cooper Tow Hook Cover
-Seibon CF CW Hood (paint matched w/ cf vents)
-AeroCatch Hood Latches (painted gloss black)
-Seibon CF 10mm wider fenders (paint matched)
-HT Autos Badgeless Front Grill (painted gloss black)
-Painted Side Vents, Trunk Trim & Roof (painted gloss black)
-Painted Window Trim (gloss black)
-Clear Flush Fog lenses w/ Yellow Overlay w/ Yellow XML2 Hi-Power LED Bulbs
-White License Plate LED's
-Hi-Power Reverse LED's
-Rear Turn Signal LED's (amber)
-Red LED Grill Illumination
-Cusco Shorty Antenna
-R205 Black STi Side Badges
-Custom Rolled/Pulled/Cut Rear Fenders
-JDM Rear Foglight w/ Red LED bulb
-SWP Paint Matched Hella Supertones
-Subi-Mods Bracket
-F n' A Automotive Relay Harness
-SWP Paint Matched SPT Vortex Generator
-SWP Paint Matched GTSpec Radiator Shroud
-SWP Paint Matched Alternator Cover
-Grimmspeed License Plate Relocator
-OEM Window Visors
-Aluminati Battery Tie Down
Headlights:
Done by F n' A Automotive
-TSX-R Projector Lenses
-Gloss Black Painted Housings
-Black Chrome Painted Hi-beam and Turn Signal Bowls
-Amber Reflector Delete
-Nokya Yellow 2500k Hi-beam Bulbs
-Switchback LED Turn Signals
-DRL Delete
-Red Demon Eyes
-White COB LED Halos
Short Block:
Built by Prime Motoring in East Rutherford NJ
-New EJ257 Case Halves
-Darton Sleeves & O-ringed
-OEM Nitraded Crankshaft
-Cosworth 99.5 / 8.2:1 CR Pistons
-Manley Turbo Tuff I-Beams w/ ARP Bolts
-King XPG Main and Rod Bearings
-Killer B Oil Pick-Up & Baffle
-11mm High Volume Oil Pump
Heads:
Built By Headgames
-Pocket Port
-O-Ringed
-Ferrea Exhaust and Intake Valves +1mm
-Ferrea Guides & Locks
-GSC Beehive Springs & Retainers
-GSC S2 (272) Camshafts
-Cosworth Oversized Head Gasket
-ARP CA625+ Headstuds
-NGK 1 Step Colder Plugs
Fueling:
-ID2000 Injectors
-DW65c Fuel Pump In Tank
-Radium Engineering Fuel Surge Tank w/ 2 walboro 485 submerged
-Vibrant -6an feed and return lines w/ vibrant fittings
-Aeromotive Fuel Regulator (red)
-Agency Power Fuel Rails (red)
-Aeromotoive inline fuel filter 6 Micron
-Setup for flex fuel (just needs to be tuned on it)
Induction/Turbo/Cooling:
-ETS Rotated Turbo Kit
-Precision Gen2 6466 V-Band Turbo, hot side ceramic coated, compressor cover powder coated Perl White
-ETS Black Anodized FMIC 4'' Core, 3'' Black Piping (AIT bung and tial flange) (white powder coated clamps) (speed density)
-AEM AIT Sensor
-Tial QR BOV (white powder coated)
-Grimmspeed Electronic Boost Controller
-Crawford FMIC Rotated AOS
-Koyo Radiator
-Cosworth 4 Bar Radiator Cap
-Samco Radiator Hoses (black)
Exhaust:
-Killer B Holy Header (ceramic coated)
-ETS Rotated Up-pipe w/ Tial 44mm EWG (red)
-ETS Catless Rotated Down-pipe
-Invidia Q300 Rolled Titanium Tips CBE (kartboy extra long exhaust hangers)
Drivetrain:
-P&L/Competition Triple Disk Clutch
-Kartboy STS w/ all Bushings
-Aluminati Solid Motor Mounts
-Aluminati Solid Pitch Stop Mount
-Aluminati Solid Trans Mount
Gauge Setup:
+SMY Clustermaker
-AEM Boost Gauge
+JCS 3 Gauge A-Pillar Pod
-Zeitrnoix Ethanol Content Analyzer Gauge
Wheels/Tires/Suspension/Brakes:
-Airlift V2 Performance Air Ride Kit w/ Dual Viaar 380c Compressors, single 5 gallon tank & water traps (tank paint matched SWP)
-Whiteline Front and Rear 24mm Adjustable Sway Bars
-Kartboy Front and Rear Endlinks
-Whiteline Steering Rack Bushings
-Whiteline Rear Dif Positive Power Kit Bushings
-Whiteline Rear Positive Traction Kit
-SBC Rear Control Arms
-18x9.5+30 Enkei Kojins (Powder Coated Roman Gold Transparent Copper)
-Sumitomo HTZIII 265/35/18
-Muteki SR34 Neo-Chrome Closed End Lugnuts
-Hubcentric Rings 56.1 to 76
-Stoptech Drilled & Slotted F&R Rotors
-Hawk HPS Pads
-Stoptech Stainless F&R Brake Lines
-Motul SP600 Brake Fluid
-Grimmspeed Master Cylinder Brace
Tuning:
Pro-Tuned by JR @ Prime Motoring
*Pump Gas- 450whp/350wtq
*E85- 713whp/613wtq
Winter Mode:
-Thule Foot Pack & Fit Kit
-Thule 50" Load Bars
-Thule 44" Fairing w/ White Camo Vinyl Wrap
-Yakima Snowboard/Ski Holder
-Stock BBS Wheels
-25mm Hub Centric Spacers
-Dunlop SP Winter Sports 235/45/18
Januch09 is offline   Reply With Quote
Old 03-09-2012, 06:21 PM   #2
NJJer
Member#: 288369
2011 STI Limited
Looks great......and great choice in colors (Have the same Limited also)
Where are you located?
NJJer is offline   Reply With Quote
Old 03-09-2012, 06:23 PM   #3
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Central Jersey...Union County! Hbu?
Old 03-09-2012, 06:26 PM   #4
NJJer
Member#: 288369
2011 STI Limited
West Central
A mile out of Flemington
Work in Princeton
Old 03-09-2012, 06:27 PM   #5
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
flemington is about 45 min from me...u go to any meets?
Old 03-09-2012, 06:52 PM   #6
besthaticouldo
Member#: 279660
nice looking car. man i really dont like the SPT gauge. still a great looking vehicle though.
like the intercooler backlit. lol
besthaticouldo is offline   Reply With Quote
Old 03-09-2012, 07:41 PM   #7
boostedrex2005
Member#: 305327
great looking subie! what SPT gauge are you talking about? I see a prosport 52mm boost gauge thats about it.
boostedrex2005 is offline   Reply With Quote
Old 03-09-2012, 07:48 PM   #8
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Ya, I was just gonna say I didn't know I had an SPT boost gauge?!? lol But yes, it's a Prosport 52mm Halo Boost Gauge!
Old 03-09-2012, 07:54 PM   #9
RallySoob
Member#: 74872
2006 STi
White/Black
Cool man....I dig the red in these pics more than your last. did you make sum alterations to the led strips?
RallySoob is offline   Reply With Quote
Old 03-09-2012, 07:57 PM   #10
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Yeah I did, in the scoop I got rid of the Individual Bulb look (as you can see in the new picture, you can't see the bulbs anymore, just the glow) and got better grounds for the interior so they are "cleaner" and brighter!
Old 03-10-2012, 02:14 AM   #11
NJJer
Member#: 288369
2011 STI Limited
Have not had a chance to get to any yet. Met a few people from buying/selling parts, and they were real nice guys.
Old 03-10-2012, 08:04 AM   #12
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Well if your interested you should come to the next meet with myself and a few buddies. Might be a bit of a hike for you but some meets are pretty fun (the ones with few hondas lol). PM me if you want!
Old 03-10-2012, 01:10 PM   #13
TurboWRX
Member#: 7632
2015 VW Golf R
Oryx White
Is the Magnaflow drone unbearable?
TurboWRX is offline   Reply With Quote
Old 03-10-2012, 01:37 PM   #14
mattw278
Member#: 276165
2013 BMW 328i Sport
I was just bombing around the back roads in Tewksbury! I used to live there a while back. Hunterdon County is where it's at. Keep a lookout for a SWP 2011 Hatch with an NC license plate and that'l be me when I'm up visiting friends and going into the city.
mattw278 is offline   Reply With Quote
Old 03-10-2012, 06:06 PM   #15
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
it depends on the mood you are in lol...for example if its cold out and you feel like **** then yes it is extremely annoying.....but if its nice out and ur chillen its still extremely annoying lol.....but like honestly when u wanna get on it and bring the RPMs up it sounds real good.
Old 03-11-2012, 09:59 PM   #16
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
new pics..btw STi vs EVO day was pretty good
Old 03-12-2012, 01:18 AM   #17
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
Car looks really great
Shipman is offline   Reply With Quote
Old 03-12-2012, 09:58 AM   #18
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
thanks man
Old 03-12-2012, 10:21 PM   #19
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Stock VS Magnaflow CBE
Stock Mufflers
Magnaflow Mufflers
Stock Midpipe
Magnaflow Midpipe
Stock Y-Pipe
Magnaflow Y-Pipe
Finished Product :b
Old 03-14-2012, 03:26 AM   #20
loudog6
Member#: 255267
Nice ride man!
loudog6 is offline   Reply With Quote
Old 03-14-2012, 03:42 AM   #21
C4pt Insano
Member#: 290990
2011 WRX Sedan
looks good. I plan on using my friends lift to put my exhaust on, when i actually get one. I was wondering where the best spots to put the lift arms are? and looks like it clears the sideskirts fine with the extensions i see. Thanks
C4pt Insano is offline   Reply With Quote
Old 03-14-2012, 10:03 AM   #22
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
yea a lift is such a help for exhaust..and what I had to do was jack it up with a floor jack then swing the arms through becuz it would hit the side skirts if I didn't...then when u bring it down u have to jack it up again with the floor jack to get em out..a bit of a pain in the a** but it worked fine!
Old 03-14-2012, 10:03 AM   #23
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Originally Posted by loudog6 View Post
Nice ride man!
thanks
Old 03-15-2012, 03:19 PM   #24
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Just a little update:
-Ran a 13.4s 1/4 mile @102.45mph w/ a 1.9s 60'
Not bad for my first time ever on the track. Very happy with results. Still think I can run a 13.2s-13.3s. Launch control set to 5000rpm's. Flat-footing the whole way
Old 03-25-2012, 12:58 PM   #25
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
New Front Lip CS Style Polyurthane
Before
After
Side Shot No Lip
Side Shot New Lip
New Bumpers JK
Slammed
My 2011 WRX limited Hatch TGUN11 Newbies & FAQs 11 08-10-2011 06:19 AM
Brake and Rotor Upgrade for 2011 STI limited aznboi0204 Brakes, Steering & Suspension 10 04-06-2011 07:37 AM
Trade in 2008 STI for 2011 STI Limited ericsson Newbies & FAQs 17 10-07-2010 12:54 AM
2011 STi limited interior pics..... 3rdsubaru Member's Car Gallery 1 09-22-2010 07:31 PM
2011 STi Limited soon to be delivered! oscarmayer Texas Impreza Club Forum -- TXIC 13 07-22-2010 01:05 PM
