Old 01-31-2012, 08:47 AM   #26
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Doesn't fit sometimes.
Old 01-31-2012, 09:09 AM   #27
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
not only that, but the block vibrates a lot.
the constant vibration, along with the mass of the sensor, can cause the joints to fail/leak.
putting the sensor at the end of a flexible hose avoids this.
Old 01-31-2012, 09:12 AM   #28
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Meh... my mech one is just dandy to me.
340Duster is offline   Reply With Quote
Old 01-31-2012, 11:35 AM   #29
hoffmanEstates
Member#: 122043
04 wagonier
psm
I would watch out for that hose. its rated high psi but not to handle heat cycles. idk sounds like might work
hoffmanEstates is offline   Reply With Quote
Old 01-31-2012, 11:48 AM   #30
silver03bugeye
Member#: 225570
03 wrx
79 trans am 462stroker
^thats exactly what I was wondering.
vision.dynamix how well do these hold up after heat cycles and if you are subject to it the cold weather? I know the hoses we run at my work crack the outer plastic but there is a braided line underneath.
silver03bugeye is offline   Reply With Quote
Old 01-31-2012, 11:54 AM   #31
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Ive had no issues. Yeah the plastic cracks sometimes, but underneath its no different than a standard SS hose.
Regardless, periodically checking it isnt a bad idea. This goes for pretty much all aftermarket parts you install on your car.
Old 01-31-2012, 08:10 PM   #32
krish51287
Member#: 268623
hi,how do you connect the wire previously on the stock oil pressure sensor to the new one?
krish51287 is offline   Reply With Quote
Old 01-31-2012, 08:13 PM   #33
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You don't. Just just eliminate it
Old 02-01-2012, 03:59 PM   #34
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Wire previously on the stock idiot sensor is left unplugged. It is also a good idea to wrap the wire with plastic cover like I did.
Will keep you posted. So far so good.
Old 02-05-2012, 11:16 PM   #35
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
So far so good after a week of driving!
Ended up buying Philips E-treme power bulbs and (100) T-tap connectors on amazon with money saved.
Old 02-06-2012, 08:50 PM   #36
Serkan
Member#: 180514
2004 Sti
Is there are SKU number for the 1/8" npt female female, I can't find that one. All they have is male-female.
Serkan is offline   Reply With Quote
Old 02-18-2012, 02:17 PM   #37
tomtom84
Member#: 167794
08 STI 6266 e85 DD
91 miata and 71 porsche
great idea guys. I'll try this next week.
tomtom84 is offline   Reply With Quote
Old 02-19-2012, 09:29 PM   #38
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
No idea on SKU #. Home depot has everything you need for install.
Old 03-05-2012, 08:57 AM   #39
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
I completed this installation yesterday with an Autometer Phantom series Oil Pressure gauge w/ autometer's sender.
The install went good, however the gauge is not receiving a signal from the sender. After reading through install directions sent with gauge, I says to wire the ground from the gauge close to the sender unit (not sure why that is). I grounded my gauge to the 12v source that feeds my A-pillar setup. Also, if a remote kit is used, autometer reccomends to ground the sender from the body of sending unit.
Did OP ground his sending unit? Any thoughts or help is appreciated. My plan is to ground the oil pressure gauge to the battery directly. And solder a lead onto the sender body grounding that to engine compartment wall.
ckswanecamp is offline   Reply With Quote
Old 03-13-2012, 05:12 PM   #40
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
Never mind, got it squared it away. The sender needed to be grounded in order to keep the needle from jumping around all over the place.
As far as not receiving signal, i ran a new wire for the sender. The first attempt, i reused a wire coming through the fire wall that original owner used for audio equipment (i think) but it proved to be damaged / useless.
Old 03-13-2012, 05:18 PM   #41
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Yes, I grounded the sending unit to the bolt on the driver side fender.
Old 03-14-2012, 12:09 AM   #42
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Or the sensor to eventually show random numbers for pressure.
ciper is offline   Reply With Quote
Old 03-14-2012, 10:24 PM   #43
sol_tegra
Member#: 259406
02 WRB WRX
from reading the thread, you guys are saying we can get everything from home depot but to make it easier on some of us (newbies.....lol) can we get some part numbers if possible?
to make this a one trip deal would be great!!!
which parts did you get from prosport?
sol_tegra is offline   Reply With Quote
Old 03-15-2012, 09:29 AM   #44
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
Prosport Subaru Oil Galley Plug- p/n PSNUT
http://prosportgauges.com/subaru-oil-galley-plug.aspx
Old 03-15-2012, 10:51 AM   #45
brutnus
Member#: 257195
2004 WRX
2.1L
Bought the hose from Home Depot.
brutnus is offline   Reply With Quote
Old 03-15-2012, 11:20 AM   #46
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Why didnt you use the rear plug??? There is another plug right by the crank case breather/pcv pipe on the top rear part of the engine. The way you did this makes extra steps and longer install time.
you use the OTHER factory plug on the back of the block. It has the same amount of oil pressure as the front and is just as accurate. Also gives more mounting points for the sender like, to the firewall!
Why? there is no need to do so, and this takes longer to install this way.
no, you shouldnt do this in the first place
Here, made this for you guys.
UK-Wagon is offline   Reply With Quote
Old 03-16-2012, 01:25 AM   #47
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
A possible answer to your question- would be to use the rear galley plug under the intercooler for an oil temp sensor. I don't think a temp sensor should be mounted remotely since you want the probe elemental in the flow of oil. Theres a lot more space under the intercooler for use of the rear galley plug. The front plug is tight as hell and almost requires the sending unit be mounted remotely.
So IMHO rear galley is for temp; front galley is for pressure.
Great diagram BTW. You can easily identify both galley plugs at the same time. More helpful information in this thread .
Old 03-17-2012, 04:29 PM   #48
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
This thread is about oil pressure sender sir. On a side note, Oil temp goes to the oil pan, or at least the OEM subaru oil temp gauge package comes like this with a small adapter and probe that is screwed into the oil pan drain hole. The reason I made the illustration is because i see them removing factory parts for no good reason, it also requires more work, and that front location makes it so the sender has to be shoved under the intake manifold or something like that were false knock could be created if its just left to vibrate under the intake. Put it in the rear location quickly, with less work, and have many options for mounting the sender in a safe secure location.
Old 04-14-2012, 11:12 PM   #49
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
1 month update - so far everything is working great!
Old 04-15-2012, 03:29 AM   #50
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
I have my sender mounted in the rear location but since this type is so bulky its wedged between a hose. Mine went bad and I need to change it but it won't be fun. I may go ahead and install the tiny autometer sensor and gauge. I can see the reason for remote mounting a huge sensor to make it easier when it comes time to change though, especially since mine has failed and I really don't feel like poking around under there to swap it out. Nice idea with the hose, btw.
2slofouru is offline   Reply With Quote
WTB : Remote Oil Pressure Sender Installation Kit EROCS04SBRUSTI Private 'Wanted' Classifieds 0 12-23-2011 05:10 PM
WTB : Remote Oil Pressure Sending Kit Dborne Private 'Wanted' Classifieds 0 07-21-2011 02:49 PM
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
FS: Oil pressure sender relocation kit. bisonjr MAIC Private Classifieds 0 03-07-2009 06:04 PM
WRXtra Oil Pressure Sender Installation Kit drees Car Part Reviews 1 06-21-2004 08:09 PM
