Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 03-22-2012, 05:53 AM   #1
K2e2vin
Member#: 308481
2005 Legacy GT
Default V8/V9 EJ207 in '05 Legacy GT
I'm looking into swapping a V8 or V9 EJ207 into my 2005 Legacy GT(blown engine); I plan on using the stock ECU since I'm assuming the V8 is 16-bit and the V9 uses an immobilizer? Of course, the ECU will be remapped. Would everything "play" OK?
As far as the actual engine, I've run into the issue of the DBW stock setup and the V8/V9s using DBC. I've read that using a 06-07 WRX or 04-07 STi manifold would work; but does this mean I need to swap over my TGV's too(or would I need the intake manifold's original TGV; assuming different bolt pattern), and would the original LGT TBW throttle body bolt to the WRX or STi manifold? Also, would I just be reusing my old engine harness(main thing is if I were to do top-feed conversion, they would still fit)?
Sorry for so many questions; I've been searching for basically a week now and couldn't find the exact answers I was looking for.
Thanks, Kevin
K2e2vin is offline   Reply With Quote
Old 11-23-2012, 02:23 PM   #2
Chromes
Member#: 287917
Thumbs up
Thanks, Kevin
free bump, i also want to know
Chromes is offline   Reply With Quote
Old 12-07-2012, 09:52 PM   #3
Chromes
Member#: 287917
Anyone?
Old 12-10-2012, 02:34 PM   #4
2JZ
Member#: 291949
Its been done before
http://montreal.kijiji.ca/c-autos-et...AdIdZ432840996
contact the seller and ask away
2JZ is online now   Reply With Quote
Old 12-10-2012, 10:00 PM   #5
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
It takes some work but the results are worth it
http://forums.nasioc.com/forums/show....php?t=2372623
lukeskywrx is offline   Reply With Quote
Old 12-11-2012, 03:14 PM   #6
Chromes
Member#: 287917
Thumbs up
he is running exhaust manilfold,up-pipe and twinscroll turbo on a ej255...
thanks for the input
Old 12-11-2012, 03:14 PM   #7
Chromes
Member#: 287917
Thumbs up
thanks bro
Old 12-11-2012, 04:31 PM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
My thread has some more pictures and details in addition to that one Luke posted above. I am doing this conversion on my 2006 WRX right now. I'm about a month out from finishing it.
Check out pages 12+ or so:
http://forums.nasioc.com/forums/show....php?t=2061849
Old 02-17-2013, 09:23 AM   #9
K2e2vin
Member#: 308481
2005 Legacy GT
Just thought I'd update for those curious:
Got it running 100%!
The fitment on mine is a little bad since I used mix/matched parts from my LGT and an STi manifold; but the if you get the a complete USDM STi "top end"(waterpipes, etc.) then it should work/fit just fine. The intercooler fitment should be addressed though because the DBW TB is different(refer to "STi intercooler" swap threads, basically need different elbows for the Y-pipe and TB). I should note that I also had to reuse the "accessories" from the LGT(mainly P/S and A/C; alternator looked like it was interchangeable).
On mine, there was nowhere to hook up the EGT sensor so it was disabled. Also, to avoid milling the driver's side head I went with an aftermarket hall sensor that was a smaller diameter, fabbed up a mount, and installed it so it was offset in the cam sensor bore(this pushes the sensor back a couple millimeters, which allows it to read the trigger edge). The stock LGT cam sensor was used on the passenger side but the mount hole was slotted. No CELs and works just fine. Also the stock LGT intake cams were swapped over.(Do this before dropping the motor in!!! I paid a lot because the shop that swapped the motor over didn't do it)
It should also be noted, with no cam sensors installed, it takes a while to start up(almost 5s).
When tuning, one thing I overlooked was I reused the O2 sensor that came with the engine swap, and OL/CL transition. Without adjusting for these, my car felt like the power was oscillating on/off during CL. Turns out, the scaling of the O2 sensor on the EJ207 engine is way different, and OL transistion is much sooner on the EJ207.
Old 02-24-2013, 02:35 PM   #10
army21b
Member#: 228116
2008 FXT Sports
AW
Pics! how does it drive, i thought of doing the same but was worried about a lack of torque for such a heavy car.
army21b is offline   Reply With Quote
Old 02-24-2013, 03:16 PM   #11
K2e2vin
Member#: 308481
2005 Legacy GT
I'll upload pics when I get the chance, though doesn't really look anything special(except that it's messy due to "slapping parts together"; still looking for parts to clean that up).
Even though it's a smaller engine, the HP is higher on the 2.0l and I believe torque is around the same but comes in earlier on the EJ207 due to the twin-scroll turbo and more aggressive AVCS mapping.
The LGT isn't that much more heavier than the STis; I think about 150-200lbs more. I've seen cars with a much lower torque/weight ratio(especially naturally aspirated cars).
Old 02-24-2013, 03:23 PM   #12
army21b
Member#: 228116
2008 FXT Sports
AW
I see.
I was looking for more like swap pics, things you had to modify, etc.
FS: Legacy GT Head Unit/HVAC out of an '05 Legacy GT Wagon Geoff Interior/Dressup/Audio & Security 0 07-14-2009 12:33 PM
WTB in NH: (2) '05 Legacy GT Stock 5-Spoke Wheels ksnh Private 'Wanted' Classifieds 3 12-05-2008 11:21 PM
FS: '05 Legacy GT Limited Wagon in PDX gavin NWIC Private Classifieds 2 12-28-2007 03:43 PM
WTB: '05+ Legacy GT/MP3 Stereo /w Aux in Geoff Private 'Wanted' Classifieds 0 05-25-2007 03:13 PM
Gauging interest in Endless Brake Pads for '05 Legacy GT RaceComp Engineering Legacy Forum 6 03-14-2005 09:43 AM
