Old 03-21-2012, 10:42 PM   #1
castper
Member#: 300342
Cool Changing HVAC Lights in a WRX D.I.Y.
Hey guys i've wanted to do this for a while and i have seen some tutorials for this but none with great descriptions. I am changing the lights not adding bulb covers like trunk monkey did.
Background info:
02 WRX
Bulb Type:
#74 LED bought from http://autolumination.com/74.htm
Looks like this
Ok first lets take a look at what i had, i used regular bulbs which i do not recommend. For brightness and reliability use LEDs Like the one above, anyway this is what i had before, i changed the stock bulbs to blue bulbs.
I know, very dim and bad quality lol
Lets start
Step 1
Remove your radio and trim around the radio.
Step 2
Pull off your HVAC knobs, they will come off if you tug on them, i used needle nose pliers to get the air slider switch off (that thing that changes the air from recirculating and fresh)
Step 3
Remove the HVAC faceplate, there will be two clips on the top, undo those and pull but be very careful not to hit yourself with the faceplate or snap it
and
Step 4
Pull out the stock bulbs from the black twist lock holder thing
Hard to see but there are bulbs in there, just oull them out and you should be good
Step 5
Put your new LEDs in the socket where you removed the old bulbs. If they do not light, take them out and reverse it (LEDs are polarized unlike bulbs)
Then test
Step 6
Once everything is confirmed to be working, put everything back together in the reverse of how you took it apart
Once done it should look something like this
Then Your Done!
Also the stock bulbs come with this ugly green cover on them
I replaced the cap with a different blue one i got
Epic waste of $9 from cost and shipping not to mention they were also too big
Went to Blue bulbs
Then went to LEDs and they are by far the best out of all of those.
Good Luck and if you break something or somehow die its on you
castper is offline   Reply With Quote
Old 03-21-2012, 10:49 PM   #2
emazz104
Member#: 281811
04 WRX
World Rally Blue
That's a awesome guide! I started following another one a while back, but I couldn't find those covers anywhere.
This makes it look so simple, I may have to pick up some LEDs, now I just need to get the courage or somebody else to do my cluster haha.
PS: I believe 74s are also referred to as T5 in terms of LEDs because there are a few other similar bulbs that are essentially the same just different wattage's, just like T10 with 168, 194, and all those.
*EDIT: Just ordered a pair of white bulbs, should see them between the 24th and 26th, I'll post them here after!
emazz104 is offline   Reply With Quote
Old 03-22-2012, 02:37 AM   #3
wrx.
Member#: 258781
2002 Subaru WRX
Have you done the gauge cluster?
wrx. is offline   Reply With Quote
Old 03-22-2012, 08:46 AM   #4
castper
Member#: 300342
Not yet, I'm still nervous about hitting a needle lol
Old 03-22-2012, 09:13 AM   #5
RSXNTN
Member#: 287358
2006 2.5i
Regal Blue Pearl
The gauge cluster is pretty much the same process, but is way more time consuming and a royal pita!
RSXNTN is offline   Reply With Quote
Old 03-22-2012, 09:18 AM   #6
skep18
Member#: 214971
2005 WRX
Haha, wow, very cool!
skep18 is online now   Reply With Quote
Old 03-22-2012, 09:21 AM   #7
RSXNTN
Member#: 287358
2006 2.5i
Regal Blue Pearl
Deleted
Old 03-22-2012, 09:24 AM   #8
CobbWRX
Member#: 310040
I have done.
Hvac
Gauge cluster
Cruise control switch
Fog light switch
Key ring.
And I will be working on my door buttons shortly. I changed all of mine to red though
CobbWRX is offline   Reply With Quote
Old 03-22-2012, 08:35 PM   #9
castper
Member#: 300342
Originally Posted by CobbWRX View Post
I have done.
Hvac
Gauge cluster
Fog light switch
Key ring.
Nice! I like the fact that we can also change them to whatever we prefer
Old 03-22-2012, 10:35 PM   #10
emazz104
Member#: 281811
04 WRX
World Rally Blue
I forgot to ask before, and I'm assuming they do, but do they still properly dim?
Old 03-23-2012, 11:04 AM   #11
Trudd84
Member#: 250706
2004 Impreza WRX
WR Blue
I am in for do they dim, and that awesome, did you add a red led of the same style for the redline part of the tach? or leave the original? And what color is the light on the button for the a/c when you push it in?
Trudd84 is offline   Reply With Quote
Old 03-23-2012, 05:31 PM   #12
PyroParrish
Member#: 311156
03 WRX
looks sick
PyroParrish is offline   Reply With Quote
Old 03-23-2012, 09:15 PM   #13
CobbWRX
Member#: 310040
yes they properly dim i will post pictures of mine asap!
Old 03-23-2012, 09:45 PM   #14
scoobyrex123
Member#: 303380
2004 wrx hybrid
i want to do my cluster like that bad...
scoobyrex123 is offline   Reply With Quote
Old 03-23-2012, 09:50 PM   #15
20blkndyellow02
Member#: 307855
2002 subaru wrx
black and yellow
i have been looking at all the interior lighting posts and i have honestly no clue on what i would need or even the correct bulbs to use.. i have a 2002 wrx and i want to change all of the interior lighting to amber leds... can anyone give some advice???
20blkndyellow02 is offline   Reply With Quote
Old 03-23-2012, 11:03 PM   #16
castper
Member#: 300342
This is going to be to the best of my knowledge, anyone feel free to correct me.
HVAC- look up
Cluster- Same as HVAC #74
Dome- 30-32mm festoon bulb
Map- same as dome
Stock radio- dont know or care because i have an aftermarket radio
any more that you need?
Old 03-24-2012, 02:04 AM   #17
20blkndyellow02
Member#: 307855
2002 subaru wrx
black and yellow
Cool
Thanks so much Haha.
I think thats all I needed. Now I just hope I can put it all together correctly!
Old 03-24-2012, 10:50 AM   #18
Trudd84
Member#: 250706
2004 Impreza WRX
WR Blue
This is legit. If this thread had a link to the door switch thread, as well as... How many #74 tri led bulbs are needed to do the guage cluster, total? Awesome job. How about how did you keep the redline red, and what color is the ac button's little light when you push it in to turn it on? Still green?
Old 03-24-2012, 03:04 PM   #19
emazz104
Member#: 281811
04 WRX
World Rally Blue
I got my bulbs in today!
Here are a few iPhone pictures.
As you can see the LEDs are a lot brighter, but they are also directional, so the light isn't completely evenly dispersed, but it's very close.
There's the after, I don't have a before, but I like it a lot better. Unfortunately the white on my radio is either a slight blue or green depending on what way you go, so I went with a blue to offset it.
Old 03-24-2012, 04:10 PM   #20
Pencils
Member#: 152726
2003 SonicYellow WRX
WFC#3210
i might do this but still go through the trouble for green LED's.
just so they're match all my aftermaret gauges since the green on them is like ULTA MEGA BRIGHT GREEN
Pencils is online now   Reply With Quote
Old 03-24-2012, 04:35 PM   #21
20blkndyellow02
Member#: 307855
2002 subaru wrx
black and yellow
Was there a greenish backing by the nobs? It might just be my screen but it still looks like a greenish color?
Old 03-24-2012, 09:15 PM   #22
emazz104
Member#: 281811
04 WRX
World Rally Blue
If you're referring to me, no, there isn't. It might just be my iPhone camera, since I don't have a real camera, but they're completely white.
Old 03-25-2012, 12:20 AM   #23
20blkndyellow02
Member#: 307855
2002 subaru wrx
black and yellow
i see how many bulbs do you need? 2?
Old 03-25-2012, 12:35 AM   #24
emazz104
Member#: 281811
04 WRX
World Rally Blue
For the HVAC, yes.
Old 03-25-2012, 12:39 AM   #25
20blkndyellow02
Member#: 307855
2002 subaru wrx
black and yellow
For the HVAC, yes.
How about for the cluster?
*OFFICIAL* Space Trek Thread. Live long and proper: the droids aren't looking for you Protege Menace Off-Topic 8797 04-03-2012 09:29 AM
2011 STi with HID kit in driving lights SubeySTi2011 Interior & Exterior Modification 27 03-21-2012 11:11 PM
FS : 17x8 Gold Wheels and Dunlops KY OH IN ImprezaSaurusREX Wheels/Tires 10 03-21-2012 09:02 PM
FS : skid plates and map light JENowman Exterior/Styling 2 03-21-2012 01:01 PM
FS : Prodrive Round Tip Axle Back - New In Box DJHiRoller NESIC Private Classifieds 10 03-21-2012 08:35 AM
Message Board Statistics All times are GMT -4. The time now is 05:19 PM.
