Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 03-21-2012, 09:19 PM   #1
JaredV
Member#: 306766
Default Close Shave?
So does anyone have their street autocross tires shaved? Any experience with it? Worth it?
Thanks for the help.
JaredV is offline   Reply With Quote
Old 03-21-2012, 09:23 PM   #2
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
Not worth it.
R-comps...worth it. If you're THAT serious. Less tread rubber = faster steering response, better transition and sometimes higher cornering power. Problem with R-comps is that it takes them too many heat cycles to get them worn down to and ideal amount of tread rubber, so you shave them.
Street tires, in theory, have infinite heat cycles so financially there is no point in shaving street tires. They will eventually get down to that ideal amount of rubber remaining on their own. Will you get better performance from shaving vs. full skid depth on street tires? Yes. Is it worth it? It depends on how much your money is worth to you in terms of tire life.
For me its not worth it.
Dirty25RS is offline   Reply With Quote
Old 03-21-2012, 09:37 PM   #3
Back Road Runner
Member#: 60082
2004 Forester STI
It's worth some wear on brand new tires to get a good contact patch for whatever camber setting you're running. Outside of that, I sort of see it as a mute point. Less can be better in terms of weight, loading, etc.
Back Road Runner is offline   Reply With Quote
Old 03-21-2012, 09:40 PM   #4
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
ST National level Drivers have a optimum Tread depth that they use...for a competitive edge....when new the bigger/thicker blocks heat up and squirm...when they are shaved...less heat and less squirm... but that again, for National level drivers to get that edge or 2/10's of second...for the street...not worth it..
Scooby South is offline   Reply With Quote
Old 03-21-2012, 10:34 PM   #5
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Yeah, for a street tire I think the heat thing is the biggest advantage. It's something that I'd consider for Nats but that is about it. The Dunlops are so good without shaving I haven't really felt it was necessary.
moot
Butt Dyno is offline   Reply With Quote
Old 03-22-2012, 12:33 AM   #6
tuskenraider
Member#: 65699
15 WRX
WR Blue
Originally Posted by Dirty25RS View Post
Not worth it.
Really? Where have you witnessed this because I've never heard of anyone shaving their r-comps for autox either locally, for a Tour or Nationals. I can't imagine a Mini or ITR driver shaving a Hoosier A6 that might last them 20 runs before cording.........
tuskenraider is offline   Reply With Quote
Old 03-22-2012, 08:54 AM   #7
Illini_STi
Member#: 70634
Lots of info on ST tires here:
http://www.facebook.com/notes/hollis...45008598916447
More info on shaving here:
http://www.tirerack.com/tires/tirete....jsp?techid=67
The theory on shaving ST tires is that in some cases, the reduced tread squirm will reduce heat buildup and you can actually get more runs out of a shaved tire than a non-shaved tire. With Dunlops, which are the easy button suby tire, I don't know that it makes much difference. I've had both shaved and unshaved, and maybe for nats I will order with a light shave, but I'm not sure right now.
Oh yeah, and you are just burning money if you shave hoosiers. You want fresh A6's for the big events. Heck, Braun had 3 full fresh sets for SS last year.
Illini_STi is offline   Reply With Quote
Old 03-22-2012, 10:39 AM   #8
russubaru
Member#: 306295
2006 WRX STi
THere is a thread on my region's forum about this. From what I gather, the reason for doing so is what Illini-STi said. You can potentially get more runs out of a properly shaved tire because tread "squirm" will cause the tires to heat up pre-maturely.
russubaru is offline   Reply With Quote
Old 03-22-2012, 01:35 PM   #9
ComBIRDable
Member#: 277889
2011 WRX Limited
This is going to be tire dependent. General consensus is the Dunlop is fine without shaving. Bridgestones have a couple of compounds molded into the tread (UNI-T technology) where the tire gets softer the closer you are to the carcass. So shaving is probably a good idea there. Rumor has it some of the Toyos are softer on the outside and a little harder closer to the carcass, so shaving away the softer compound to get to the harder compound closer to the carcass might be a bad idea.
C/N: Your mileage may vary
Scott
Here is some great info on ST tires:
ComBIRDable is offline   Reply With Quote
Old 03-22-2012, 02:02 PM   #10
russubaru
Member#: 306295
2006 WRX STi
Scott
ahh you must be referencing the famed 195 toyo made of unicorn dust
Old 03-23-2012, 09:18 AM   #11
Evil STI
Member#: 36792
2014 Camaro 1LE
gold chains & meatballs
I usually run 5/32"-6/32" shaved. Less chunking, better wear characteristics, saves ~2lbs per tire on a 245.
Evil STI is offline   Reply With Quote
WTB : Closed Turbo.steve Private 'Wanted' Classifieds 16 03-14-2012 11:56 AM
Space rock gives Earth a close shave FunkerVogt Off-Topic 44 03-03-2009 04:03 PM
Asteroid to give Earth close shave next week Scoobie Noobie Off-Topic 16 01-24-2008 02:08 PM
ok why was the door lock shave kit thread closed? IllNastyImpreza Interior & Exterior Modification 4 06-22-2007 05:49 PM
To Shave or not to Shave that is the ? SubaFast1 Interior & Exterior Modification 9 06-07-2001 06:21 PM
