Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 03-24-2012, 01:21 AM   #1
maddhatteroo7
Member#: 78840
Default EJ207 radiator system pressure issue?
Yay coolant circulation issues....top hose leaks a little bit apparently near the coolant inlet that runs under the intake manifold. Haven't had issues for the 2k miles+ since coolant was flushed and refilled. No coolant temp issues and coolant level has all been good since the flush. Maybe time to change the thermostat? Pressure cap is good/clean and not jammed it's an sti 1.3bar cap. Thoughts folks? Thanks
01 EJ207
roughly 33k miles on the engine
maddhatteroo7 is offline   Reply With Quote
V7 EJ207 Fuel System Upgrade... KenSekiguchi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-25-2014 02:30 PM
EJ207 Evap system need help jam007 Subaru Conversions 1 04-05-2011 12:40 PM
Cooling system pressure check...2 radiator caps? Boxerocks Service & Maintenance 1 09-07-2010 08:27 PM
Radiator high pressure cap function? lushboy Bay Area Impreza Club Forum -- BAIC 8 10-04-2002 06:37 AM
Radiator cap pressure Peaty General Forum Archive 3 03-14-2001 04:13 AM
