Old 03-19-2012, 07:03 PM   #26
doomskies
Member#: 290901
2011 Wrx
How did you fix rotation?
doomskies is offline   Reply With Quote
Old 03-19-2012, 07:09 PM   #27
Andrew025
Member#: 303408
04 STi
Have you made a thread on HIDplanet? Someone over there might be able to help better, cuz after looking at the pic you posted I honestly don't know where the extra light would be coming from.
Andrew025 is offline   Reply With Quote
Old 03-19-2012, 07:10 PM   #28
mattesonb
Member#: 139607
DGM Wrapped Satin Black
Originally Posted by satrya View Post
Too bad you've already re sealed the headlight housing. The fact remains that:
(1) There doesn't seem to be anything visually different from other Mini D2S units (or more precisely, other D2S owners haven't spotted any possible cause).
(2) The effect appears equally on both headlights.
If it was a one off "defect", then having it happen on both seem unlikely. If it was a "design change" relative to previous D2S, then it might be visible from the pictures.
What about the shrouds? Could the inner side of the shroud, combined with the depth of the shroud relative to the projectors, cause some light that should've been bent down by the projector lens to deflect somehow? I'm not talking about the outer surface of the shroud, which you've painted a flat & dark color.
I find it surprising that TRS believed this to be a common D2S "feature". If it's also on mine, I don't see it. (here's how it looks before adjusting the hotspot & rotation alignment on the left one)
I agree i wish i had not put them back together, unfortunately this is my daily driver so i had no choice.
as far as it being evident on both lights, the part i find strange is that if you look closely, its not even on both. the driver side has a noticeably larger spot than the passenger. and as i looked closer today i noticed that it appears my driver side has a bit of light leaking off to the left as well.
i will take a better photo this evening to show what i am talking about.
mattesonb is offline   Reply With Quote
Old 03-19-2012, 07:12 PM   #29
mattesonb
Member#: 139607
Rotation is not corrected, its not too bad but just a bit annoying
Old 03-20-2012, 02:09 PM   #30
mattesonb
Member#: 139607
update with some better photos
both lights with leak and different size leaks
passenger side leaking light above and on left and right
Old 03-25-2012, 12:53 AM   #31
mattesonb
Member#: 139607
bump!!!
Old 03-25-2012, 11:49 AM   #32
XIEmperoriX
Member#: 140933
2015 WRX Limited
WR blue
hmm..I'll have to check mine to see if I am having the same issues. Never noticed anything this with my kit?
XIEmperoriX is offline   Reply With Quote
Old 03-25-2012, 12:05 PM   #33
FromEvoToRS37
Member#: 91396
Talk to Cezar at Lightwerkz? he's like the king of retrofits and headlight jobs
FromEvoToRS37 is offline   Reply With Quote
Old 03-25-2012, 07:17 PM   #34
JWill7
Member#: 123261
2011 WRX 5-Door
My retrofit did not go great either. I may have found the issue, though.
The light seems to be reflecting off part of the bi-xenon mechanism. If this piece were removed or covered with a non-reflective material, the problem would be solved.
I don't have time to open my headlights for another couple of weeks, but if someone wants to try this solution, let us know how it goes.
JWill7 is offline   Reply With Quote
Old 03-26-2012, 10:44 AM   #35
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Pics to come, but I can confirm i do NOT have the two little leakage spots. Hm...
Old 03-26-2012, 11:08 AM   #36
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Afaik, for those identified areas to cause unwanted bright spots, the bulb placement is likely too far off center. Specifically, the bulb is probably tilted too high (facing forward). This means the hotspot (when viewing the projected beam on a wall) is far below the cutoff.
With the Mini D2S that I use, if I pull the connector that mates to the bulb down, the hotspot can move down a noticeable amount. Try to see if the hotspot on yours also move, and see if the unwanted bright spot disappear once the hotspot is vertically dead center (wrt the cutoff).
satrya is offline   Reply With Quote
Old 03-26-2012, 03:15 PM   #37
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^ Good point. My bulbs do NOT sit as they normally would, they're tilted so as to get the hotspots at the zigzag cutoff point.. maybe that's why I avoided the little parasitic spots.
Old 03-26-2012, 04:28 PM   #38
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
The hotspots on my Mini D2S are slightly below the cutoff point, but I don't observe the rogue spot mentioned by the OP. Looking at the geometry of the parabolic reflector, shield, and the solenoid area, the bulb has to have quite a tilt for any parts around the solenoid to reflect rogue spots. That's what I hypothesized mattesonb has on both D2S units. (since the hotspots seem rather low for such a close distance wall picture)
Old 03-26-2012, 06:10 PM   #39
mattesonb
Member#: 139607
i'm going to play around with them tonight and see if i can either make it better of fix it by better aligning the bulb in the housing
Old 03-26-2012, 06:44 PM   #40
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Good luck. From this and another thread ad hidplanet, there doesn't seem to be other Mini D2S owners that had / noticed this issue (myself included). When I was actively researching which retrofit projectors I wanted to select, the only issue I recall seeing with the Mini D2S is tweaking the hotspot location.
On that note, I initially assembled the rubber washer and c-ring in reverse order in one of the units, which resulted in the bulb in that unit being easier to rotate when the end cap is pushed/pulled. What I noticed was the hotspot was a bit low compared to the other one.
Once I reassembled the washer & c-ring correctly, the hotspot was much more centered, and a bit harder to nudge off center.
Old 03-26-2012, 08:13 PM   #41
dwf137
Member#: 161333
'09 wrx
'14 Outback
there is a thread on 3gwrx with my issues.
the spots you're seeing above the cutoff are very likely caused by the horizontal shield that moves the cutoff shield up and down. I painted mine with a flat-black grill paint and they went away, but I caused another issue. When warmed, the paint caused the high beams to stick in the high position. I had to rip the headlights apart and remove the paint, so don't go that route.
I had major issues getting the hotspot correct with oem bulbs. the reflectors in these just suck.
and get ready for bouncing on rough roads. I don't know what the hell it is, but I think it's the cutoff shield. Some say they don't see it, and some do.
oh and another issue, the TRS brackets, at least the ones I was supplied with, are two different thicknesses. Who cares you ask? well it aims the low beam down. Does that matter? why yes, it does, because then you need to aim the whole housing, including the high beam, up in order to set the cutoff correct. My halogen high beams now point to the trees.
I hate my TRS kit now, but I'm too lazy and cheap to fix it. If I had to do it again, I would have gotten TSX's and bailed on the bi-xenon function (oem bi-xenons are too large for our housings, from what I've found)
Old 03-26-2012, 09:24 PM   #42
mattesonb
Member#: 139607
man i wish i had known about this before i went ahead and did the whole thing...
Old 03-26-2012, 09:40 PM   #43
mattesonb
Member#: 139607
well screw it, found a set of used OEM STI headlights on ebay for a good price. i will be sending back these stupid TRS ones
Old 03-27-2012, 10:05 PM   #44
Bluefoton
Member#: 141373
2008 2.5i-hatch -
After all the hassle, I do love my D2s. The problem is that it took FAR more headaches than it should have, given this is a retrofit, and not a crappy kit in Ebay headlamps. IIRC, a "new" version of the D2S projectors is in the works.
Old 03-28-2012, 02:04 AM   #45
mattesonb
Member#: 139607
I feel a bit decieved by TRS, they make this kit look very straightforward with the whole "retro-quick" wording and it seems clear.
then when you get into it the directions arent really correct, there is no clear instruction on wiring up the harnesses, and when its all said and done they havent really been able to resolve the issue with light above the cut off. to top it all off now that i want to return the kit i am being told there will be a 25% restocking fee because apparently large rainbow colored blobs above the cut off are "within the norms of the d2s" WTF!!!!
Old 03-28-2012, 10:05 AM   #46
Ric WRX
Member#: 187009
2008 WRX Sedan Prem
VF52, CAMTuned, Stage 2
Did you get the Phillips bulbs or Morimoto, I have the Phillips and mine don't have any light above.
Ric WRX is offline   Reply With Quote
Old 03-28-2012, 10:42 AM   #47
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Phillips. Again, a D2S should be a D2S, down to a micrometre of alignment of every single element. Someone just got really lazy at TRS so as not to make the bulb sitting position perfect from the start. Using spacers/silicone/tiewraps so as to put it where it should be is lame (though fun..if you have time and beer).
Old 03-31-2012, 12:03 PM   #48
11SubieWRX4D
Member#: 264443
2011 WRX Sedan Stg 2
My headlight is producing the same "hotspot". I had it professionally installed and everything is bolted correctly.
11SubieWRX4D is offline   Reply With Quote
Old 03-31-2012, 04:54 PM   #49
mattesonb
Member#: 139607
you photo isnt working,
who did you lights?
Old 03-31-2012, 05:52 PM   #50
infinite012
Member#: 74392
2015 Forester
If you guys cared to do more research, you would have known that the correct Morimoto projector to buy isn't the D2S, but the H1. Why? Because the H1 bixenons are better in every regard.
infinite012 is offline   Reply With Quote
Perrin EL header fitment on 06 WRX- Help from those that made it fit... phlegmon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 11-20-2010 09:40 AM
I need some help from those that know TVs please. Badmunky Off-Topic 21 09-10-2009 06:28 PM
Real (ALS) those that have it O4STInger Engine Management & Tuning 0 08-21-2008 02:49 AM
Engine not running right; need some input Texasrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-04-2006 07:51 AM
Need help from those that have JDM STi front lip Spec C Wannabe Interior & Exterior Modification 11 03-21-2005 09:29 PM
