Old 03-07-2012, 11:03 PM   #51
eeebalaji
Member#: 248935
2003 WRX Bugeye
Subscribed,
Feal suspension/Mr. odi, I am also super eager to know the estimate on such a setup if you have something in mind.
Originally Posted by sorrowfulkiller View Post
Feal Suspension, can you setup a set of coilovers for rally (mostly tarmac, occasional dirt and gravel), spring rate wise and valving wise? Could you PM me an estimate on price also? I'm planning on getting a set beginning of next month.
eeebalaji is offline   Reply With Quote
Old 03-15-2012, 12:26 PM   #52
Feal Suspension
Member#: 227414
Are they wagon specific?
I have a forester and would use 1 inch lift kit
Car is driven mostly in NYC so roads are brutal.
Would this set up run nice.
I had bc coils and they were disguting and dangerous the car felt like it was going to fly off the road.
They are not wagon specific. However, there is enough camber adjustability allowing them to work on the wagon (we even supply Ingals rear camber bolts). We have sold several sets to forester owners, reviews will hopefully be up in the future. For the forester, we supplied 6K rear springs instead of 5K. The ride will be firmer than oem, but high speed compression and rebound valving in general is dialed for a great ride.
As of now, we do not market a Feal Suspension gravel/rally coilover kit. For gravel use, you need atleast oem lenght travel. We do sell Hot Bits coilovers in non adjustable and adjustable versions. These kits are very affordable and can be utilized on a street car. You can view pricing on our website as I cannot discuss it here. Feel free to email or call me as well.
Feal Suspension is offline   Reply With Quote
Old 03-15-2012, 08:10 PM   #53
2slow2curious
Member#: 115638
04 WRX Vagon
Dubh
So tempting to get these for my Foz
Is there room on the top hat bolts for some spacers
1/2" maybe
2slow2curious is offline   Reply With Quote
Old 03-16-2012, 10:18 PM   #54
rmaxwellusn
Member#: 310864
2003 WRX wagon
Red
I'm interested in these, will you ship to FPO/AP?
rmaxwellusn is offline   Reply With Quote
Old 03-17-2012, 02:01 AM   #55
teiva-boy
Member#: 22825
Not an actual SG kit right? Just an impreza fitment...
teiva-boy is offline   Reply With Quote
Old 03-23-2012, 11:16 AM   #56
forfun
Member#: 153693
2004 forester xt
black
Installed on my Forester last weekend. So far I like them, I went with 8k and 6k
Primarily for autocross. I have had some perch noise and need to adjust hight.
Put them on as they came and ended up with 13.25" rear and 12.75" front measured from center of Hub to fender.
forfun is offline   Reply With Quote
Old 03-23-2012, 02:07 PM   #57
sorrowfulkiller
Member#: 170439
I <3 Lamp
Odi, any plans on a camber/caster plate in the future?
sorrowfulkiller is offline   Reply With Quote
Old 03-23-2012, 09:26 PM   #58
FL4T
Member#: 293206
06 STi
would it be possible to get these with 9k front and 8k rear?
FL4T is offline   Reply With Quote
Old 03-24-2012, 12:36 AM   #59
FL4T
Member#: 293206
06 STi
also what rear camber plates work with these?
Old 03-24-2012, 06:52 PM   #60
2slow2curious
Member#: 115638
04 WRX Vagon
Dubh
That might be a tad low for a foz unless you have supporting mods.
What are the comfort levels like?
Old 03-24-2012, 10:43 PM   #61
fizzyl
Member#: 103490
06 STi
These come with front and rear camber plates. Paragraph 2:
http://odib.web.officelive.com/Feal441.aspx
fizzyl is offline   Reply With Quote
Old 03-25-2012, 03:00 AM   #62
FL4T
Member#: 293206
06 STi
it says mounting holes. not plates
Old 03-27-2012, 02:34 PM   #63
battousai
Member#: 44977
2015 Mustang GT
Any reviews for this yet? Most likely will pick these up to replace my Stance GR+ but sure would be nice to see some people actually riding on them and critiquing them.
battousai is offline   Reply With Quote
Old 03-28-2012, 12:30 AM   #64
Feal Suspension
Member#: 227414
1/2" maybe
The three studs are 1" long.
I'm pretty sure we have before.
We pre set your spring pre load and estimated a ride height since it was not an Impreza. Let us know where you end up on ride heigth.
The fronts do come with camber plates, but the rear top mounts are not adjustable. However, the upper bolt hole is slotted to allow for a about 3 degrees of adjustment. We can also supply a 2 degree camber bolt to allow for plenty adjustability.
Old 03-28-2012, 12:32 AM   #65
Feal Suspension
Member#: 227414
We have GC and GRB kits that we will be installing into vehicles this week.
Old 03-30-2012, 07:46 PM   #66
Feal Suspension
Member#: 227414
We have been working on an application for the 2008+ STI. Here is some info on the 441 Coilovers being fitted on a 2008+ STI.
These are valved with more low speed compression than the GD application and we use 8K/8K springs.
Front spring preload was set to 5mm and the rear to 3mm. This resulted in about 2" of droop front and rear.
We preset the height at about a 13.5" gap from hub center to fender in the front, and 13.25" in the rear.
We liked 10 clicks from full hard damping setting front and rear.
Old 03-31-2012, 11:40 PM   #67
AND0
Member#: 306449
from my iwsti forum post
http://www.iwsti.com/forums/gd-suspe...-coilover.html
Just installed and adjusted my new Feal 441 coilovers.* Don’t have too much time on them yet but I can throw some initial impressions.
First, my set up, previously I had stock struts, springs, and bars with ALK, x brace, poly bushings all through the drivetrain.* The car drove pretty well, but there was a lot of uncontrolled motion that could be better handled, and the car felt pretty choppy for such light springs… riding on the bumpstops?* I don’t know..
Install was not seamless, as the Brake line stays on the struts are not in the same spots, nor are they the same style as the stock, so, some minor tweaks to make everything compatible.* For the fronts I added a little bit more (~5mm) preload to get a droop of ~40mm out of the 120mm of travel and set the ride height at 14”* Had to run the camber plates at an angle to add some caster and camber and balanced out with the camber bolts.* Front camber = 1.8* could had gone with more, but I feel this was a good balance with the high caster.* caster = 6+* 0 toe.* Rear Preload seemed about right 40mm droop, set the ride height at 14” rear camber = 1.4* 3mm toe in.*
Driving impressions are much better, more controlled suspension motion.* Stock USDM suspension is just too soft.* The ride doesn’t feel any harsher then stock on the small chop, just better controlled.* Car feels way more planted with more grip, though I was able to add caster and camber over stock, so not really a fair comparison.*
I was worried that I might have been making a mistake ordering these, as they have pretty limited suspension travel, and I was concerned about lifting a rear wheel or bottoming out, but I have felt absolutely no downside and all in all I have been very pleased with these.* I think the independent adjustability of the preload and ride height negates any draw back to short suspension travel.*
At the price point these are the best coilover option out there, and I wouldn’t want to go with anything less expensive.* Needless to say, Odi was helpful and knowledgeable to talk to.* More updates to come as I get more time on these…..
AND0 is offline   Reply With Quote
Old 04-05-2012, 02:34 AM   #68
B-SILVER
Member#: 285412
2004 WRB STi JRTuned
424whp/427wtq E85!
Just got the Feal 441 coilovers put on my 06 STI through Synergy Tuning. Very happy with them so far. Here are some pics.
B-SILVER is offline   Reply With Quote
Old 04-18-2012, 10:25 PM   #69
B-SILVER
Member#: 285412
424whp/427wtq E85!
heres an updated pic after the coils have settled and how my car currently sits
Old 04-20-2012, 10:24 PM   #70
Dragonbreak
Member#: 96860
2006 STI
That looks really good. Pretty flush! Let us know how it handles!
Dragonbreak is offline   Reply With Quote
Old 04-21-2012, 03:21 PM   #71
STi&me
Member#: 169900
07 STi
swp
how do i go about ordering a set of these for my car? went on the feal website but it didnt have an option for buying it.
STi&me is offline   Reply With Quote
Old 04-23-2012, 04:15 AM   #72
runboyrun
Member#: 287901
2003 WRX Wagon
how adjustable are these as far as comfort goes? How soft is the softest and how hard is the hardest?
runboyrun is offline   Reply With Quote
Old 04-23-2012, 03:20 PM   #73
Feal Suspension
Member#: 227414
As of now, we have been taking orders over the phone and email. I will add a buy it now feature on the site.
The softest setting yields a very soft compression and lower rebound damping setting, I think most would find it too soft. The stiffest setting is very aggressive and I would not reccomend it for street use. There is a large spectrum of adjustability.
Old 05-28-2012, 12:13 AM   #74
JSti07
Member#: 190019
07 STi
swp
Anyone else get these coilovers?
JSti07 is offline   Reply With Quote
Old 05-28-2012, 11:51 AM   #75
sorrowfulkiller
Member#: 170439
I <3 Lamp
Waiting to get them, ordered last week and said they would send mine out as soon as they're made. Good service.
Formula One 2010 Thread. The Skinny in the front Fat in the back Era artkevin Motorsports 3255 12-31-2011 12:35 AM
Adjustable or non-adjustable sway bars. What's the skinny? NJ_wrx Brakes, Steering & Suspension 4 09-07-2011 05:58 PM
Home Refiancing - What's the skinny? Sharkbait Off-Topic 68 03-30-2009 02:46 PM
What's the Skinny on the Crowbarn<sp>???? The_Triton Off-Topic 24 07-02-2004 05:52 PM
What's the skinny on water injection in a turbo engine? Digital_Boy Technical Forum Archive 5 08-26-2000 12:08 AM
