#276 | |
Member#: 303353
MWSOC
Vehicle:2012 Impreza Sport Ltd |
I have a really hard time believing your Outback numbers when I look at the fuelly data. They're just so far outside the norm (and even outside the outliers) for that vehicle that there is almost no way that could be true, unless there was a calculation error or an issue with the gas pump not fully filling.
#277 |
Member#: 309257
NWIC
Vehicle:2012 Imp 5D Prem CVT Marine Blue |
I finally got to borrow my wife's CVT Premium, PZEV hatch for a long freeway drive to a hike over the weekend. Our car has been notorious for bad mileage, BUT a recent visit to the dealer and insisting on a diagnostic seemed to MAYBE do a step function improvement in gas mileage, even though they claimed they didn't do anything to it. I did roll over the 1000 mile mark during this drive.
I zeroed the mpg average gauge and started out in approx 40degF morning temp, pulling out of a warm garage. Blue light went out soon after pulling out of the driveway.(verified average guage is 1.2 miles optimistic based on manual calcs on this same tank) First 5 miles was 14-16mpg, with the efficiency gauge pegged over on the plus side (max fuel usage) even when coasting downhill, on sections that the injectors SHOULD be shut and are normally pegged the other way when the car is VERY warmed up. The rest of the day is spent making up for that first 5 miles and probably explains why people with LONG commutes are happier than people with shorter commutes or errand runners, with this car. I proceeded to drive the entire drive VERY carefully, even drafting cars and trucks, keeping to 64mph max and no sudden accelerations. Coasting up to stop signs from WAY back. Only about a mile from my house to the freeway. Very little non-freeway driving on this trip. At about 8 miles I finally broke 20mpg per gauge. At about 20 miles I was edging up above 25mpg. At about 40 miles of freeway, the car was making up for the crappy starting mileage and a very tiny bit of "city" and getting over 30mpg. At about 60 miles when turning off the freeway the car was doing about 33-34 mpg, dropping slightly for some 35 & 50 mph easy country roads. After a couple hours cool down and with temps in the 50's, I did get up to 35+ mpg for the average on the way home, maybe dropping to 34 with a few 70mph stretches, but hanging at 35.1mpg as I exited the freeway. Driving the stop-go last single mile to my suburban home dropped it a suprising amount, down to almost 33. A GREAT car for long freeway road trips and long long commutes. Its has its challenges making up for that first 5 miles "warmup" though. It does look like the computer "diagnostic" hookup, did something to the car, IMPROVING overall gas mileage. Still not exactly kicking up my heels about its ACTUAL "City" mileage, but at least I can see some hope now of the ever increasing time they are asking for mileage break-in, and "summer gas" getting us into reasonable "mixed" mileage and awesome Freeway mileage. |
#278 |
Member#: 312150
Vehicle:2012 Impreza Dark Grey |
I had a question about the fuel efficiency gauge. When i start my car the needle is on the negative side of the gauge. Whenever I give the car gas the needle stays towards the negative side. When i let off the gas, the needle goes to the positive side of the gauge. Doesn't it mean you are saving gas when the needle is on the right side?
#279 |
Member#: 12181
MWSOC
Vehicle:2004 STi WRBro 12 Impreza Sport Limited |
#280 | |
Member#: 306218
MWSOC
Vehicle:2012 Impreza CVT DarK Grey Met. Sport Prem |
#281 | |
Member#: 189032
MAIC
Vehicle:2007 Sti Ltd 413/800 '12 Impreza Sport Ltd DGM |
#282 |
Member#: 313093
VIC
Vehicle:2012 Impreza 2.0i 5-door Sport. Dark Grey |
I have a non PZEV Impreza, since I'm in Canada but then again its still very wet and rainy here temperatures are under 10°C. Now that you guys mention it, I do notice that it takes a little while for the CVT to "loosen up," my idle rpms drop lower and acceleration is more consistent and smoother after this happens. The car seems a bit sluggish during this period though and I also try and keep the rpms as low as possible during this time.
@79letour, damn I wish I could do that, maybe I'll go test drive again at a different dealership. |
#283 | |
Member#: 309257
NWIC
It must have had a very odd and traumatic "birth" on the treadmill at the factory.:-) Based on your comment, I wonder if it would be worthwhile for ALL owners to reset the ECU (disconnect the battery) after coddling the car for the 1000 mile break in period, so it can learn our REAL style of driving? Just a thought. |
#284 | |
Member#: 302559
#285 |
Member#: 312150
There has been alot of talk about the impreza having bad gas mileage due to the cold temps which i agree with. DO you think the imp[reza will have similar problems when it is very hout out?
#286 |
Member#: 312928
After 2 days and 200 miles, I'm looking at 30.5. Not bad compared to the 19 from my '04 181,000 mile Forester.
#287 | |
Member#: 306218
MWSOC
If issues with MPG arrive next winter when cars are well broken in, I'll start heavily blaming the pzev, because it is clear to me that it runs the car much differently during warmup than a regular car (this is our 12th vehicle, none has run at such high rev for so long after the cold engine light goes out). |
#288 |
Member#: 302570
Vehicle:2012 Impreza Ice Silver Oil Burner |
I live in florida and have always gotten great gas mileage. Trip odo B is still the same mileage as the cars odometer and in 5000 miles my average speed is 29mph and my avg mpg is 31.7 indicated. Almost all my driving is ten miles or less. But my 5mt warms up fairly quick (seems like its quicker to watm up with the mileage on it now).
I don't think the engine is really whats needing the long break-in. I think its all the drivetrain "loosens up" a bit by 5k or so. Anyone wanting to try something to see if they notice a difference- try running Amsoil in the engine, transaxle, and rear. My car seemed to get a slight boost in mpg's when changed out all the factory filled stuff. Just my 2¢ |
#289 |
Member#: 302570
My pzev loaner seemed to take a good ten miles just to get all warmed up. I think I don't like pzev, glad mine was an early '12. Sucks we'll have that to deal with from now on. It seems like the oil companies are really behind the epa, as epa and fed regulations have taken away a good bit of efficiency and simplicity. I mean, car companies are building hybrids that dont really do any better than early 90's econocars, and arent nearly as fun to drive imo.
#290 | |
Member#: 302491
Tri-State
Vehicle:2012 Impreza 2.0i Pr Dark Grey Metallic CVT |
#291 |
Member#: 310047
NWIC
Vehicle:2012 Sport Limited ISM |
I brought up my poor mpg with the dealer today - so far working hard to get 22 mpg in 60/40 city/hwy. I'm trying really hard to drive with economy in mind and finding it really hard to get close to the combined mpg. I don't expect to get exactly the combined mpg but I really think that 22 for city/hwy mix that includes nice 12 mile 60 mph stretches with no traffic ought to get me higher than 22!
I was told that some other Impreza owners had mentioned this too. I was advised that since it seemed like I'm doing my part (not trying to drive like a maniac and watching the Eco gauge) it might be a good idea to bring the car in for what he described as an "ECM Flash". He said he's seen this issue in the past with Outbacks where for whatever reason the car leaves the factory with the wrong or old "firmware". I'll keep y'all posted but it seems like there could be a factory firmware issue out there. We will see! |
#292 | |
Member#: 313093
VIC
http://forums.nasioc.com/forums/show...1#post36600171 |
#293 | |
Member#: 309257
NWIC
PLEASE keep us posted on how this works out! I am trying to prove or disprove this theory, as I would really like to find a fix for this issue, on this otherwise wonderful car. We MIGHT have gotten an inadvertant ECM flash, and it seems like it might have helped a bit. (still determining how much). Sure would be nice to discover its that simple to fix. Then we just have to figure out how to chill out the PZEV from apparently trying to set up a nuclear fusion reaction in the catalytic converter by burning enormous amounts of gas for the first couple of miles. Futile of course, but it tries playing "the little engine that could". At least the ECU flash might make the rest of the drive meet expectations. Keep us posted on your results!!! ![]() |
#294 |
Member#: 313093
VIC
Do you guys with the CVT notice that the braking is is kind of weird when the car is cold? As in you have the brakes fully pressed down and you've come to a more or less complete stop and the car will jerk forward a bit after?
#295 |
Member#: 308095
I have noticed that as well as when its cold and I am at a stop light or stopped in general, it will give a "shudder"...similar to the jerk you mention. First time it did it I thought I got tapped from the car behind me.
#296 |
Member#: 313093
VIC
Does anyone have any idea what causes this, as this seems like a big enough issue, since you could potentially hit the car in front of you.
#297 | |
Member#: 302491
Tri-State
#298 | |
Member#: 313093
VIC
#299 |
Member#: 208950
NESIC
Vehicle:2012 Impreza Sport L White |
Ok so I am at about 5300 miles thus far on my 2012 Impreza sport....first mpg tank was 26.3...and ever since then I have been going up about 2 mpg per fill up. I am driving about 150 miles per day for my commute between MA and NH for work. For the past 3 days I have pulled into my driveway and the trip computer has been 36.0, 36.5 and 36.1 avg mpg for my commute. Overall average on the last 3 fill ups has been 31.4, 30.7, and 31.1. I am driving about 70 to 75 mph on average on the highway when there is no traffic. During the week I am 100% highway and on weekends i am all city. I am averaging 4.4 days between fills and, although the first few weeks in the car the mpg performance was less than I expected I am now seeing some really good numbers. Keep the faith people....keep the faith!!!! By the way the mpg calls are true readings and not from the trip computer. I have found the trip computer is about 1.9 mpg higher on average than true readings.
https://lh5.googleusercontent.com/-g...520mileage.jpg Here is the data on my car since I started tracking... 2012 Subaru Impreza: Mar 27, 2012 8:54:01 AM Total Fuel Cost $512.50 Avg Fuel Cost $3.63 / gal Total Distance 3583 mi Fuel Cost $0.13 / mi Avg fuel economy 28.0 mpg Avg in city (est.) 28.0 mpg Avg on highway (est.) -- Best fuel economy 31.4 mpg Worst fuel economy 25.5 mpg Avg for Regular 28.0 mpg Carbon footprint 2824 lbs CO2 Total Service Cost $0.00 Service Cost $0.00 / mi Total $0.13 / mi Largest Fuel Fill 13.862 gal Most Expensive Fuel $3.859 / gal Least Expensive Fuel $3.45 / gal Furthest Distance on 1 Fill 409.0 mi Avg Distance Per Fill 358.3 mi Avg Days Between Fills 4.3 days |
#300 | |
Member#: 304676
MAIC
Vehicle:2012 Impreza Ltd 5DR Deep Cherry Pearl |
| Thread Tools | |
| Display Modes | |
| New Impreza owner, low mpg? | stuffedcabbage | Newbies & FAQs | 34 | 09-25-2012 10:10 PM |
| 2012 Impreza Reviewed - Whytecliff to Seymour | brendan_mac | Vancouver Impreza Club Forum -- VIC | 16 | 12-23-2011 01:12 PM |
| NJ Impreza owners - sighting | Dan G | General Forum Archive | 76 | 10-06-2000 12:24 AM |
| Md or Va Impreza owners - I have an Impreza related question. | Snoopy | General Forum Archive | 1 | 06-05-2000 08:08 AM |
