Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 08-15-2011, 09:26 PM   #526
gts24
Member#: 90799
2005 Saab 9-2X Aero 5MT.
I'll be doing this fix at some point this week.....
gts24 is offline   Reply With Quote
Old 08-19-2011, 01:41 AM   #527
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
Did the fix on my 05 STi, hasn't worked since I bought the car almost a year ago....Damn it's pretty loud! Probably going to end up turning it off anyways
danny_d19 is offline   Reply With Quote
Old 10-18-2011, 12:19 PM   #528
Izero
Member#: 121332
2004 STi
Platinum Silver Metallic
Originally Posted by DriftIt View Post
The busted alarm buzzer was getting to me so I decided to remove it and pull it apart to find out why it wasn't working and figured why not take a few pics and make kind of a diy of how I was able to make mine work again. Best part about it was, aside from a little time spent, it was free!
Tools needed:
Step One:
Remove the grille by pressing down on the tabs in the locations shown on the pics and pull the grille up and out.
Step Two:
With the grille out of the way, unplug the wiring to the buzzer by pressing in on the tab on the back of the connector. Unbolt the 10mm bolt holding the buzzer mount on the radiator support and remove the buzzer.
Step 3:
This is the point of no return, you may end up damaging or breaking the case and or buzzer so be willing to sacrifice it for a new one if you end up damaging it too much.
I went barbarian on this thing and used wire clippers to snap the back section of the buzzer off right at the seam. In retrospect I probably could've borrowed someones dremmel to make a small cut and separate it, but this way worked for me so.....
The reason my buzzer (and I assume many others) stopped working, is because of the weak solder connection between the wiring inside of the buzzer and the connector pins. Use your pick or screwdriver and check the soldered connection by pushing or pulling on it VERY LIGHTLY to see if the connection has been broken, if it has, proceed, if not you need to just replace the buzzer with a new one or an alternative.
I checked the buzzer to see if it was still good by touching it to the poles of a 9V battery (below).
Edit: I separated the buzzer from the case, however this isn't really necessary. Just bare a couple spots on the ends of the wiring inside the buzzer so you can test it. Once you've checked to make sure the buzzer is still good, move the wires enough to be able to clean out that white silicon crap that's covering the contacts that the wires are supposed to be soldered to. I used a pick and a flat screwdriver to scrape it off.
Step 4:
After making sure the buzzer still works, clean off the spots on the case where the wiring was soldered. Bare a short section of wire on each lead, place the buzzer back in the case (if you removed it) and solder the wires as shown and make sure each has a good connection. I plugged my buzzer back in to make sure it worked on the car before sealing it back up. After making sure it works, press the case back together and seal it with some RTV silicone. After mine dried, I taped electrical tape around the seam to help hold it together and make sure it stays sealed.
I have been looking for a fix to this problem for awhile now. And I figured I would quote it b/c its impossible to find the damn fix on this mega long thread. lol
The radio Shack replacement part number is 273-0060
OEM Replacement part number is: 88021FE000 - $36.77 from Subaru Genuine Parts
Izero is offline   Reply With Quote
Old 10-18-2011, 12:51 PM   #529
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
I couldn't find the silicon, so I electrical taped mine after dremel separation.. STILL working even in the rain!
I swear that you could put a wind of painters tape over it and it'll last better after re-soldering than it did from the factory.. I hope new replacement units are better made?
420WRX is offline   Reply With Quote
Old 10-18-2011, 01:38 PM   #530
ireallydriveabimmer
Member#: 261778
06 WRX
WRB HELLA FUNCTIONAL!!
Same problem...is there a fix anyone wanna tell me what page its on...I'm on my phone and its slow ass shizznit
ireallydriveabimmer is offline   Reply With Quote
Old 10-18-2011, 01:41 PM   #531
420WRX
Member#: 27752
Your username is so appropriate.. the post above my post, which you replied to, has the fix.
Old 10-18-2011, 02:03 PM   #532
ireallydriveabimmer
Member#: 261778
06 WRX
I'm an idiot for not atleast looking on the last page....I don't rele get the username reference...I don't feel like getting into a fight if that's an insult so I'm just going to thank you for responding...ill kill u with kindness haha
Old 10-21-2011, 05:51 AM   #533
DriftIt
Member#: 137388
'05 WRX
Just checking in on this. Glad the fix is working out for everyone. Funny how a little thing like the alarm chirp not working can bug you. I guess more than anything it's just knowing that something on your car that's supposed to work, isn't working even though you may decide not to use it. I didn't realize how common it was for the chirp to go out until I started going to meets and people asking why their car doesn't chirp like mine does when they lock their car, lol. Anyhow, still holding up since I did the fix a little over three years ago.
DriftIt is offline   Reply With Quote
Old 10-23-2011, 01:46 PM   #534
civicseth
Member#: 235558
2004 JBP STi
2002 MBP WRX
I fixed mine today by cracking it open and resoldering. Thanks for the photos and advice! Let's hope this thing hold up for a while now.
civicseth is offline   Reply With Quote
Old 10-23-2011, 03:22 PM   #535
nymtber
Member#: 253247
2007 Impreza Wagon
Thanks for the photos and fix for this! I fixed my 07 wagon today in about a half hour total. I really missed the chirp when parking in a parking lot because I know if it chirps once the doors are locked and I don't have to keep pushing it till it honks. But, I forgot how loud that chirp is!
Hope everyone who misses their chirp finds this page, such an easy fix!
I will add: if you break the cheap push-lock pins that hold the front grill in, I found Lowes carries some 1/4" push lock pins in their fastener section in the "automotive fasteners" bin, 2 for $1.06 I think it was. They look a lot more durable than the subaru factory pins, but they do take a little more effort to snap down. I'm sure subaru's are a better fit, but I am cheap...
nymtber is offline   Reply With Quote
Old 10-24-2011, 11:40 PM   #536
slayers_x
Member#: 101220
MY05 imprezaRS
riding on open diff
i bought a new one but now since i plugged it in it's producing a constant noise . like power is being constantly supplied to the buzzer. any ideas on how to fix it ?
slayers_x is offline   Reply With Quote
Old 12-06-2011, 02:56 PM   #537
hi-flo
Member#: 220008
2004 WRX STi
fixed mine today **** yea. thanks for the DIY!
hi-flo is offline   Reply With Quote
Old 03-19-2012, 03:45 PM   #538
cracky
Member#: 181399
05 STi
Mine has been down since forever... just pulled it out this weekend.
Gonna do the DIY.
great post.
if that still doesnt work there are many piezos you can source for a lot less than the dealer price.
cracky is offline   Reply With Quote
Old 03-19-2012, 03:58 PM   #539
DougG
Member#: 58975
2005 WRX Premium Sed
WRB, Cobb TBE, stage 2
Failure of solder joints is an increasing problem in electronics these days. It affects clocks and keyless remotes in Subarus, among other things. My dishwasher, TV, and other gear has failed because of the new solders that are being forced on industry by certain political forces. The new solder contains no lead, thus being inherently more brittle. I have two spools of solder inherited from my father that are 50 years old. They contain lead and I routinely use them to fix the crappy joints I find.
DougG is offline   Reply With Quote
Old 03-19-2012, 04:07 PM   #540
420WRX
Member#: 27752
Lol.. my electrical tape repair is almost going to last longer than the factory solder work..
That's sad for two reasons, the first being that I haven't glue'd it properly, and the second being that it was so badly done to start with..
If you folks read back, I'm one of the owners that had their ENTIRE wiring harness replaced. Took the dealer a couple days to rip apart the interior and replace the harnesses. The whole time I was telling them "The internet nerds say it's just the buzzer" and they were saying "Don't believe what you read. We do this for a living."
*facepalm*
Old 03-26-2012, 08:17 PM   #541
DeM3n
Member#: 184692
2004 STI
Much thanks for this DIY. I pulled the buzzer apart and sure enough one of the wires was not connected. Had my brother-in-law solder it and the chirp is back!
DeM3n is offline   Reply With Quote
Old 03-29-2012, 01:02 PM   #542
evistor
Member#: 228927
2005 Impreza WRX STi
WR Blue
Does anyone know if part # 88021SA001 is applicable for my 05 STI?
I just opened mine and it was solid clean and all intact.
the only worry is this 88021SA001 says its for a 08+ Impreza but it looks identical to the old one.
evistor is offline   Reply With Quote
Old 03-29-2012, 01:14 PM   #543
420WRX
Member#: 27752
If you have a cheap $20 voltage meter, set it to ohms and bridge the connections coming out of the buzzer.. if the stock buzzer isn't toast, swapping it won't help.
Old 03-29-2012, 01:19 PM   #544
evistor
Member#: 228927
WR Blue
you mean if the stock buzzer IS toast? or isn't?
sorry, not much of a tech person.
Old 03-29-2012, 01:53 PM   #545
420WRX
Member#: 27752
Let me make this simple then.
IF buzzer = broken THEN swap = chance of working
IF buzzer NOT broken THEN swap NO chance of working
Old 04-13-2012, 02:23 PM   #546
SnooBen
Member#: 238198
WR Blue
Thumbs up
Yes it is applicable! I just ordered and installed that part on my 05 STi and it works perfectly. I think the only difference from that part number to the part number first posted in this thread is the style of mounting bracket. The buzzer itself seems to be the exact same part.
SnooBen is offline   Reply With Quote
Old 04-19-2012, 09:38 PM   #547
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
this is my problem
anyone know where I can get a new plug too?
KeithS05RS2.5 is offline   Reply With Quote
Old 04-19-2012, 10:19 PM   #548
Blktrax
Member#: 220971
2002 WRX 219K Mi.
Original Motor and Turbo
Is the plug actually broken? the problem is the weather pack failed and let moisture in, when you do repair it pack it with dilectric silicone, that should help.
The dealer has a harness repair kit that allows the pins to be removed and replaced with short leads, the buzzer itself, need a new one. as the pins are stuck in the harness connector
Blktrax is offline   Reply With Quote
Old 04-19-2012, 10:36 PM   #549
420WRX
Member#: 27752
I'd just snip it off, slip some heat shrink over it, solder it direct, torch the heat shrink, and then go drink a beer.
After you fix the beeper you won't need to keep swapping it out.
Old 04-20-2012, 06:10 PM   #550
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
@420WRX
I was thinking that, no worries of battery drain with direct wire? Doesnt seem like it would to me...
Keyless Chirp FIX! alieus Car Audio, Video & Security 18 01-13-2010 12:19 AM
changing keyless chirp exrage Car Audio, Video & Security 0 11-06-2007 11:19 PM
Free: 04 keyless entry module BlackRS New England Impreza Club Forum -- NESIC 0 08-23-2004 10:49 PM
The 04 keyless entry "chirps" instead of honking? Butt Dyno Car Audio, Video & Security 2 05-29-2003 09:32 PM
Remote Keyless "Horn Chirp" Warning. How do i get Rid of it? William WRX Legacy Forum 5 07-26-2000 04:39 PM
