#226 |
Member#: 308167
Vehicle:1998 Legacy 2.5GT Black |
you can centre the rear wheel by spacing the trailing arm bracket, same as in the front with the transverse links
#227 |
Member#: 26315
BAIC
Vehicle:07 Outback Silver/Silver |
#228 |
Member#: 26315
BAIC
I just measured the opening. It's just about 29 and 3/4+". There's 2" in back and 1" in front of the tire. The most would need to do is about 1/2". You probably can't get 29s in there. But you could 225/70R16 (28.5") if you centered it. I'm probably going to leave it and do Yoko Geolander 215/70R16 (28").
#229 |
Member#: 26315
BAIC
I went back and looked at a pre-lifted picture. Even pre-lifted the rear wheel is a bit forward in the opening.
#230 |
Member#: 4835
Vehicle:2003 Baja 5MT Yellow w/ 220,000 miles |
Lifting with just spacers on the struts, will there be any additional stress or wear and tear and the cv/axles?
I have spacers at home that are either 1.5" or 2", they came with the Scorpion lift kit for my 2003 Baja. |
#231 |
Member#: 26315
BAIC
I would say yes as you are increasing the angle on the CV joints. It's not much but it is greater than stock.
#232 |
Member#: 308167
I have to replace a cv about once a year but I got lifetime warranty and I beat the shizz out of my car
#233 |
Member#: 26315
BAIC
#234 |
Member#: 308167
#235 |
Member#: 314199
Vehicle:2013 WRX ISM |
there are a couple lifted outbacks over on the outback forum as well, lots of people do it
#236 |
Member#: 4835
#237 |
Member#: 308167
Lifted king springs on Outback suspension, I don't think the lift is as much a factor as my driving habits but it sure isn't helping matters.
#238 |
Member#: 235679
Vehicle:99 Legacy 2.5GT Tuxedo Black |
i5 racer
you should come to some of the suby meets at dicks in crown hill this spring/summer, i will be there rockin my new legacy sedan! would be cool to meet some more local suby guys, they are supposed to be starting up again in april, i think my friend who is running it said first and third wednesdays every month, but check the local forum or i can to make sure of that would be cool to meet ya, dont worry they arent snobby "off road ready" haters, guys come with all sorts of subies, even a couple brats have been there. i took my stock legacy for a while, they are cool guys |
#239 |
Member#: 118141
Vehicle:95 'lifted' legacy |
#240 |
Member#: 26315
BAIC
No trailing arms. It has a rear arm that's part of the hub.
I don't think that just spacing the rear arm bracket will center the rear wheel. It might get it back a little. It might even go back to the stock location but that isn't centered either. I'm going to try to modify the OEM bracket. I'm going to fill the original holes and redrill them about 1/2" back. |
#241 | |
Member#: 64060
Vehicle:98 lifted FOZ M/Ts glacier white |
If you go 3" you will have issues.. with kings and subtle 1" spacer blocks it's more like 2.5" -2 3/4" after spring sag..(once the weight settles down. ). A body lift of 2" will correct angles. However, now body lifts are available unless you make one. Australia has lift kits.. ![]() |
#242 |
Member#: 4835
VERY NICE! Love the rock crawling action! Question will I need camber alignment after a 2" spacer lift?
#243 |
Member#: 26315
BAIC
On mine ('07 OB) I ended up with no camber issues. The tech was able to get factory spec camber front and rear (no adj for rear). But the toe on the rear ended up slightly toe out.
#244 |
Member#: 26315
BAIC
#245 |
Member#: 308167
I have Outback trailing arm brackets. Actually, the whole Outback conversion is there. Essentially, all you need to do is lower the forward mount as much as the knuckle is lowered and it will be the same position as factory
#246 |
Member#: 322031
Vehicle:97 OB, 2.5 manual |
hi, I'm new here and I am from New Zealand.
![]() a lot of great ideas to modify my OB, thanks for that. thanks, steve Last edited by SubbyQ; 06-02-2012 at 05:50 PM. |
#247 |
Member#: 235679
welcome to the family!
i dont currently own an outback anymore but i will be assisting my friend in his rally spec outback eventually so ill still be around (i didnt stop driving scoobs, i just got a 99 Legacy 2.5GT... no way im moving from subaru's any time soon!) |
#248 |
Member#: 322272
E. Canada
Vehicle:2003 Impreza Black |
What a great thread. Thanks for all the ideas everybody!
#249 |
Member#: 235679
i5racer! i saw you driving down aurora yesterday! wasnt driving my Lego GT though, i was in my mom's hyundai running to get parts for my car. wish i was in it, woulda said hi!
#250 |
Member#: 276486
Vehicle:'08 lifted outback subtle + king |
| Thread Tools | |
| Display Modes | |
| lifted outback sports | dmdellicolli | Brakes, Steering & Suspension | 12 | 09-03-2008 10:31 PM |
| Lifted Outback | Allied Armament | Outback Forum | 3 | 04-15-2006 03:19 AM |
| Anyone have a lifted Outback Sedan? | jsavage | Outback Forum | 8 | 03-01-2006 04:44 AM |
| Suspension/body lift, Lifted outback Legacy "BEEFY" | Allied Armament | Brakes, Steering & Suspension | 0 | 11-27-2005 10:56 PM |
| Anyone own a lifted Outback? | JC | Legacy Forum | 22 | 03-04-2003 03:14 AM |
