Old 03-31-2012, 11:06 AM   #1
pseudodigm
Member#: 202891
2004 WRX
Rally Blue
Default Torque Wrench for Spark Plugs?
Can anyone recommend a decent (ie: doesn't have to be professional grade, this will only be used a few times a year, you know?) torque wrench that will: a.) Fit in the tight area you're in while changing sparkplugs, and b.) adjust down to 15-19 lbs?
I have a big 1/2 one that only goes down to like 30 and wouldn't even begin to fit so I've been trying to find a solution. Last time I did the plugs i did what the manifesto recommended (hand tight, then a 1/4 turn) but I'd like to be sure because I need to do a compression test soon and I hate to just guess...
The ones I've seen at Harbor Freight and Amazon are either like...NASA approved and really expensive, will do the right torque but look too big, or are small enough but go down to 20 or 30 and not 15.
Is there one that people tend to use or do people do 20 because it's close enough to 15-19 or does everyone just do it by feel?
THanks!
pseudodigm is offline   Reply With Quote
Old 04-01-2012, 03:00 PM   #2
happs subi
Member#: 200288
2002 Impreza WRX
Ace hardware has some small cheap ones. Honestly though, it would be a real bear to try and fit a torque wrench down there unless you plan on lifting the motor a few inches.
happs subi is offline   Reply With Quote
Old 04-01-2012, 07:56 PM   #3
pseudodigm
Member#: 202891
2004 WRX
Rally Blue
So most people just do it by feel then?
Old 04-01-2012, 08:18 PM   #4
jts749
Member#: 281293
2006 WRX CGM
1993 Saturn SC2 turbo
I just do it by feel, you feel the gasket smashing then it starts to get harder to turn when its all the way tight. That way they are probably over torqued but that's not such a horrible thing if you put anti-seize on them.
jts749 is offline   Reply With Quote
Old 04-02-2012, 09:10 AM   #5
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
until you strip the threads out of the aluminum head
Old 04-02-2012, 10:32 AM   #6
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i usually get them to the crush ring then another 1/4 - 1/2 turn. never used a tq wrench on them. now that i think of it, the only time i use a tq wrench is wheels and when building engines, all elese goes by feel.
PARANOID56 is offline   Reply With Quote
Old 04-02-2012, 10:45 AM   #7
lavid2002
Member#: 226864
There's always someone like you in these types of threads
"ZOMG u put lug nuts on without a torque wrench?!"
Cross threading the heads is a more common problem than stripping them out. Most of those spark plug boxes have instructions too for people who don't have torque wrenches like tighten until snug + 180* or something along those lines.
It's always better to use a torque wrench, but how much better? If good-n-tighten is good enough then settle for that. I'm not going to unbolt my motor mounts and lift the engine so I can fit a torque wrench on the side of the motor. Simply not necessary. If the motor is out of the car on the stand, it's another story.
-Dave
Old 04-19-2012, 07:14 AM   #8
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I always torque the spark plugs by hand and always have an all my cars. Had some bad locations with some cars I've seen in the past...
However... Have you guys seen how many of the heads that people are selling get the "harmless" nice little cracks around the spark plug holes?
I know mine got them on the EJ205 engine that I sold.
I would like to avoid reducing the resale value of my heads and avoid forming these cracks..
I don't know if you guys noticed, but 90% of the heads that come up for sale have them and 90% of the people (rougly) torque plugs by hand.
I'll say this: the heads that come up for sale with no cracks sell for a nice premium.
For this reason alone, I'd like to calibrate my "handtorque" by using a wrench on at least one of the plugs.
I'm going to look at what the factory says to use for the plugs.
Old 04-19-2012, 11:21 AM   #9
iant333
Member#: 264205
2000 swapped RS
SRP
What kind of enormous torque wrenches do you guys have. I have no problem fitting my old snap-on fixed 3/8th torque wrench in next to the engine on my EJ205. The head is actually the exact same size as my 3/8th ratchet.
You guys think a Subaru is hard to torque plugs on try doing it on a GM minivan or Pontiac Aztec.
Pretty much any 3/8 torque wrench should fit with the right extension size on the end.
iant333 is offline   Reply With Quote
Old 04-19-2012, 11:55 AM   #10
leecea
Member#: 37359
I was able to fit my Sears 3/8" drive torque wrench on 3 of the 4 plugs. The 4th was done by hand. IIRC, it goes to 10 ft/lbs.
Just FYI, before I had the 3/8 wrench, I used my 1/2" Sears to torque strut top studs to 15 ft/lbs even though the scale stopped at 20. I just turned it down 5 more lbs using the scale graduations and then checked using a 15 lb weight, a ruler, and bench vise. It was still acurrate at 15 ft/lbs.
leecea is offline   Reply With Quote
Old 04-21-2012, 02:13 AM   #11
dillonlightman88
Member#: 287889
2008 Wrx
You need 3/8" drive spark plug socket to small extension to universal swivel joint to long extension to long extension to any 3/8 drive torque wrench. All four. No problem.
dillonlightman88 is offline   Reply With Quote
Old 04-21-2012, 05:41 AM   #12
I have been using a harbor freight 1/4" drive, 20 - 200in-lb torque wrench for years on subaru sparkplugs.
it does take the right combination of spark plug socket and extension and 1/4" - 3/8" adapter to fit just right....but it DOES fit just right
I dont use any universal swivel....
180 - 190in-lbs is just right
and per the real honest to god spark plug engineer d00000d from ngk that posts over in the maint forum all the time ....you should NOT use ANY anti-seize products with their spark plugs as they are already anti seize plated from the factory and adding anti seize causes more and more serious issues than it solves or is supposed to prevent
Old 04-21-2012, 05:42 AM   #13
Old 04-21-2012, 02:15 PM   #14
RedStar101
Member#: 165878
I never use a torque wrench for spark plugs, but a Harbor freight would do the job fine.
RedStar101 is offline   Reply With Quote
Old 05-04-2012, 04:15 AM   #15
Rally Snow
Member#: 193614
02 Aspen WRX
need blinker fluid change
ya i dont use a torque wrench either. A bendy on your wrench extentions sure does the trick for changing plugs though.
Rally Snow is offline   Reply With Quote
Old 11-03-2012, 03:21 AM   #16
CalvinT
Member#: 329025
2002 WRX Wagon
NGK says to go 1/4 turn past finger tight.
Not a good idea to use any kind of swivel, they can throw your torque readings off.
CalvinT is offline   Reply With Quote
Old 11-18-2012, 10:23 PM   #17
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
Not can, do. Why use a precision tool at all, if your only going to make it imprecise.
extensions throw off your torque readings too, but at such a low ft-lb its negligible.
ProdriveDreams is offline   Reply With Quote
Old 11-18-2012, 10:44 PM   #18
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Because you feel super pro with a $300 Snap-On torque wrench in your hands, even if you're using it as a pry bar.
tibug is offline   Reply With Quote
Old 11-19-2012, 12:44 AM   #19
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
Not gonna lie... it is a nice torque wrench...
Old 11-19-2012, 03:31 PM   #20
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
Good to know Uncle Scotty. Been using a 3/8" torque wrench for the last 9 years with no issues. The spark plugs in the DOHC heads are tricky but you definitely have enough room to get the wrench in there.
V8Slayer is offline   Reply With Quote
Using a torque wrench on drain plug Drew303 Service & Maintenance 19 06-18-2009 10:55 AM
Using gear wrench in conjunction w/ torque wrench for top strut nut BIGSKYWRX Brakes, Steering & Suspension 10 01-07-2005 08:44 AM
Two Torque Wrenches for Sale $55 armand1 Private 'For Sale' Classifieds 1 12-04-2004 09:36 PM
What size torque wrench for STi wheels and lug nuts essogas Tire & Wheel 3 10-14-2003 02:33 PM
What size torque wrench for suspension work? SoLiDbReAkZ Service & Maintenance 4 06-11-2002 01:13 AM
