Old 04-02-2012, 01:25 AM   #101
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Originally Posted by brockd View Post
How loud is it? I just want a slight rumble to drown ou the cvt noise.
The rumble itself is not too loud due to the EL headers but present nonetheless. If you just disconnect the muffler at the 2 bolt flange then expect a fair amount of drone. It takes 5 minutes to remove the 14mm bolts. If you like the way it sounds then you know what you need to do. As I mentioned in a previous post, I have ordered what I need to hopefully address the drone issue. I will keep you guys updated with my progress.
italia490 is offline   Reply With Quote
Old 04-02-2012, 01:42 AM   #102
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I've read another forum member who had unbolted the muffler as well, it creates a nice boxer rumble. I was actually looking to get a muffler shop to custom fabricate me an exhaust system based on aftermarket dimensions and specifications; however, that won't be for a while, since my car is still new.
Old 04-02-2012, 02:45 AM   #103
brockd
Member#: 235571
2012 Impreza 2.0i
I plan on in bolting tomorrow. Just wanted some input before
brockd is offline   Reply With Quote
Old 04-02-2012, 04:53 AM   #104
pkL
Member#: 313093
2012 Impreza 2.0i
I want to unbolt my muffler too but wouldn't the exhaust gases melt or wrap the metal/plastic underneath your car, since the gases are still pretty hot still at that point?
Old 04-02-2012, 05:32 AM   #105
brockd
Member#: 235571
2012 Impreza 2.0i
i wouldn't think so. seems like it would be pretty easy to just cut off the stock muffler and weld in a different muffler that is the same length.
this is kind of a dumb question, but has anyone replaced their stock license plate lights with LEDs? want that hyper white look the cadillacs have.
Old 04-02-2012, 05:32 AM   #106
brockd
Member#: 235571
2012 Impreza 2.0i
Old 04-02-2012, 05:37 AM   #107
pkL
Member#: 313093
2012 Impreza 2.0i
Oh I thought you meant you were going to unbolt the muffler and leave it that way. If you replace the stock muffler with an aftermarket one there shouldn't be any problems, I'm assuming its an universal muffler you're going to be using? One issue though, there is no cutout for the muffler on the wagon, so that might be an issue.
Old 04-02-2012, 05:55 AM   #108
brockd
Member#: 235571
2012 Impreza 2.0i
i ran a straight pipe on my 03 silverado when i had it and nothing melted. so im not too worried. i will not be replacing the exhaust anytime soon, just unbolting the two bolts. no cutout is needed, just have it dump under the car.
Old 04-02-2012, 10:00 AM   #109
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I have a complete LED swap on my car except for the DRL's. It looks nice and is not hard to do.
Old 04-02-2012, 10:04 AM   #110
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
For those of you that will be unbolting your muffler, you are going to want to secure the muffler away from the pipe coming from the car with some tie straps or remove it completely. Reason being is that it will move back into place and you'll lose the rumble.
Here is the link from Youtube for those that are interested in how it sounds:
http://youtu.be/c6hpf-j5EqY
Old 04-02-2012, 10:20 AM   #111
PAO56
Member#: 304676
2012 Impreza Ltd 5DR
Deep Cherry Pearl
easy to do..already done it here...space is tight to work in...and can be tricky getting the cover to snap back in place...but a few minutes each side will work.....gives that nice clean white light look to the plate...
PAO56 is offline   Reply With Quote
Old 04-02-2012, 02:57 PM   #112
PAO56
Member#: 304676
Deep Cherry Pearl
if anyone is interested in the rear bumper reflector led light conversion...i found the kit for $20 less, let me know and I can send you his site....great to deal with and same day shipping....
Old 04-02-2012, 03:14 PM   #113
brockd
Member#: 235571
2012 Impreza 2.0i
Which LEDs did you go with? I was searching for some on amazon since I have a gift card but they all seem to be crap quality
Old 04-02-2012, 06:06 PM   #114
brockd
Member#: 235571
2012 Impreza 2.0i
Unbolted it today. Little too loud for my taste. Sounded damn good though.
Old 04-02-2012, 08:23 PM   #115
79letour
Member#: 302570
2012 Impreza
Ice Silver Oil Burner
I'm waiting till 36,000 miles then I'm going to ditch the cats and put a turbo-style muffler in the stock location. I still say the stock exhaust is well built.
Old 04-02-2012, 10:11 PM   #116
pkL
Member#: 313093
2012 Impreza 2.0i
Originally Posted by PAO56 View Post
if anyone is interested in the rear bumper reflector led light conversion...i found the kit for $20 less from the vendor who supplies JW Motoring.....let me know and I can send you his site....great to deal with and same day shipping....
I'm interested, got link? Thanks.
I talked to several people and they have said the stock exhaust is well built so I'll most likely wait to modify my exhaust/muffler.
Old 04-02-2012, 10:48 PM   #117
SubyDoWhreRU
Member#: 308063
What about buying some longer bolts and putting spacers in between the exhaust and muffler? Think that would produce a noticeable difference without being too loud and still keep it bolted tight and not just having the part hang there?
SubyDoWhreRU is offline   Reply With Quote
Old 04-02-2012, 10:59 PM   #118
brewer90
Member#: 315265
Originally Posted by 12DGMSport View Post
Anyone got word on a hitch for the 2012 hatch?
I called Curt Mfg today and they said they should have one out on the street in one to two weeks. The design is all done but they are waiting on marketing to release it.
brewer90 is offline   Reply With Quote
Old 04-03-2012, 12:10 AM   #119
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
That's not a bad idea. Definitely leaving the muffler hanging is not a viable option.
Old 04-03-2012, 10:16 AM   #120
PAO56
Member#: 304676
Deep Cherry Pearl
you have a PM
Old 04-03-2012, 04:05 PM   #121
pkL
Member#: 313093
2012 Impreza 2.0i
you have a PM
Okay got it thanks.
Old 04-03-2012, 08:33 PM   #122
SubyDoWhreRU
Member#: 308063
doing something like this wouldn't void my warranty would it?
Old 04-03-2012, 08:39 PM   #123
Brian Vantana
Member#: 314834
2012 Impreza
Dark Metallic Grey
Potentially a lazy newbie question but why can you not just post the link?
Is there some sort of rule here against that? I can not think of an obvious reason.
I would be interested in seeing them.
Cheers
Brian Vantana is offline   Reply With Quote
Old 04-03-2012, 09:11 PM   #124
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
If you are concerned about voiding your warranty then it might not be a bad idea to wait till it expires. Everything I have read, SOA is hard to deal with. With that being said, performing a modification like this should not void your warranty. Check out the Magnuson Moss Warranty Act. In a nutshell, SOA cannot deny your warranty claim unless they can prove that any issue you may experience is tied directly to the modification that you did. Not to mention if you do need to go into the dealer for service, just replace the OEM bolts and gasket and no one is the wiser.
Old 04-03-2012, 09:14 PM   #125
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Cheers
If I had to guess, I'd say this is the link:
http://www.car-lab.com/2007-2011-sub...rs-light-lamp/
Looks like they have a 3 wire setup, Ground, Running lights/turn signals and brake lights. Doesn't look like an OEM reflector however I am curious to see how these ones light up.
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 1 12-29-2011 11:31 PM
Message Board Statistics All times are GMT -4. The time now is 10:54 PM.
