Old 04-05-2012, 12:19 AM   #1
dillonlightman88
Member#: 287889
2008 Wrx
Default IAM .5 when flashed back to stock
Ive been running 89 octane in my stage 1 TP, 08 wrx for the previous tank.(before you give me the typical smiley face and box of popcorn read a bit more) I monitored it daily for any signs of detonation via romraider and learningview. My IAM didn't break from 1 at any point at all, and never read any knock what so ever at WOT.(read a tiny bit, -1.4 at no load but i had seen the same symptom with a full tank of 91. And never any fine learning in learning view) Here is a log of WOT 3rd gear TP stage 1 89 octane
https://docs.google.com/spreadsheet/...3JENnNMeUZvSUE
pulled a learning view after. saw nothing but zeros for fine knock learning, and 1.0 IAM. (these were last week)
So two days ago after running the tank down real low, i filled all the way back up with 91. Over the last two days i burned over a quarter tank and drove no more than 25 miles( probably closer to 20) I was alot more impressed by the gas mileage i was getting with 89 on the tp stage one. Starting questioning TP map a little more.
So tonight i went and logged a bit while sitting in the drive way screwing around, it seemed to be running funny cold so i logged for misfires on all 4 and noticed several misfires on 1 and 3. As shown here:
https://docs.google.com/spreadsheet/...3F1bVF3eXZpNkE
So i said screw this, im flashing back to stock. (also prior to all this i felt it was a little bit joltier then the stock map, like you could feel it stair stepping up the cells, while pulling through the gears, almost like some cells needed smoothed out(i think thats an accurate statement)) So I went ahead and flashed back to my stock map. Started it up, read a couple small misfires at idle sitting in the driveway again, then noticed my IAM had changed to a solid .5. 0 knock feedback or fine knock. Went out toook a light cruise checked for knock, nothing. Did a WOT 3rd gear saw this:
https://docs.google.com/spreadsheet/...HpwWVI5di1CTWc
pulled a learning view when i got to the driveway and saw that my IAM was .5 , af learning #1showed: 0-<5.6+-1, 5.6-<10.00=.1, 10.00-<40.00=.1, and the last one was zero. All zeros through the fine learning and no codes.
(sorry for the confusing numbers wasnt sure how to upload my screenshot, or what the numbers in af1 mean for that matter)
Sooo thought i would post up and see what everyone, or anyone has to say about my scenario. Input, advice, comments, questions, love to hear it all.
Thanks guys.
dillonlightman88 is offline   Reply With Quote
Old 04-05-2012, 12:23 AM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
the stock tunes have the IAM set at 0.5.
basically thats how subaru sells the car, then the ignition mapping tunes itself based on the various conditions such as octane, elevation, etc.
if the ecu goes through so many cycles without knock it will up the iam.
Old 04-05-2012, 12:41 AM   #3
dillonlightman88
Member#: 287889
2008 Wrx
Ic, so.. If I check back after ten fifteen miles on this map there's a good chance I'm going to see 1.0? Is that every time you reset the ecu on a stock map it resets to .5? Any thoughts on my misfires?
Thanx!
Old 04-05-2012, 12:46 AM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
The default value is 0.5 like i said....so yes any reset on a stock rom kicks the IAM back to 0.5
If nothing else has changed, then misfires are usually the result of a leak.
With an 08 wrx....is 6 years old....so you can start getting into lots of troubleshooting...front02 sensor, spark plugs and gap, leaks, etc.
if you didnt check your spark plug gap i'd start there.....and if you havent replaced your front 02 i'd do that next.
Both bad plugs and bad 02 sensor can cause misfires and horrible gas mileage.
Old 04-05-2012, 12:48 AM   #5
dillonlightman88
Member#: 287889
2008 Wrx
Are misfires like this to be of any immediate concern?
Old 04-05-2012, 12:55 AM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
its not common for a stage1 car to misfire....u just have to do the troubleshooting.
whens the last time you did your plugs and what did you gap them too?
if you're asking how long before your car dies due to misfires....i cant answer that.
Old 04-05-2012, 01:02 AM   #7
dillonlightman88
Member#: 287889
2008 Wrx
I put a set of NGks in a couple months back. They were factory gapped. I believe.
And no I'm not asking how long until my car dies from misfires!!
Maybe I need to check into my front 02 sensor, possible my outrages mpg and misfires are hand and hand?
Any input on a troubleshoot process for it?
Old 04-05-2012, 01:09 AM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
if you didnt check the gap of your plugs, i would start there. "pregapped" plugs are notorious for being over gapped to 0.045-0.055. they should be 0.028-0.030
if you're experiencing alot of hesitation while driving, thats a pretty good sign that your front 02 is bad. The hesitation along with the decreased gas mileage and the misfires could basically point to the plugs or the 02 sensor. Frst, i'd check the plugs and gap since they are cheaper. Then i'd disconnect the front 02 sensor and go drive. if any hesitation is gone, then thats a sing its your front 02.
Old 04-05-2012, 01:22 AM   #9
dillonlightman88
Member#: 287889
2008 Wrx
Great input!! Thank you for your help I appreciate it!
Old 04-05-2012, 07:57 PM   #10
dillonlightman88
Member#: 287889
2008 Wrx
I'm surprised I haven't gotten anyone brutalize me for using 89 !! Still wondering why the gas mileage was obviously better with 89 in my tank.
Old 04-06-2012, 12:43 AM   #11
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Old 04-06-2012, 01:52 AM   #12
dillonlightman88
Member#: 287889
2008 Wrx
Thanks nsfw. Deffinetely a good read.
neccisary to flash back to stock before oil change at the dealer? mattesonb AccessPort 5 02-17-2012 06:50 PM
Flash back to stock question (gutted uppipe) Humboldt wagon Newbies & FAQs 12 10-26-2007 09:57 PM
Noob question on flashing back to stock tokstad Commercial ECU Reflashes 3 11-16-2006 11:06 AM
Can ecutek be flashed back to stock?? MachinesWRX Engine Management & Tuning 1 11-30-2005 08:20 AM
can eku-tek flashed ecus be flashed back to stock programming? dothespeedlimit Engine Management & Tuning 2 03-29-2004 01:22 PM
