Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 04-01-2012, 01:13 AM   #5601
Skemcin
Member#: 167252
2002 OBS Wagon
Midnight Blue
Here are some pix of my lights. HELLA %00FF in the middle and HELA 500 Fogs on the outside.
Skemcin is offline   Reply With Quote
Old 04-01-2012, 02:23 AM   #5602
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
see much?
cosseywrx is offline   Reply With Quote
Old 04-01-2012, 10:37 AM   #5603
Skemcin
Member#: 167252
2002 OBS Wagon
Midnight Blue
Originally Posted by cosseywrx View Post
see much?
Let's just say vision is no longer an issue.
Old 04-01-2012, 03:50 PM   #5604
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Do you have alternator/charging problems?
Superorb is offline   Reply With Quote
Old 04-01-2012, 04:40 PM   #5605
Skemcin
Member#: 167252
2002 OBS Wagon
Midnight Blue
Not yet - but I'm monitoring it. I've got a Scangauge mounted in place of my center dash clock and run with my alternater voltage on one of the read outs. I've got to turn all my lights on and run my winch to see if the voltage stays at 14.1 and then test the amperage as well. But so far, no issues.
Old 04-01-2012, 06:09 PM   #5606
frizzanz
Member#: 196825
2005 WRX
Alpine White
A winch? Oh baby, can I get some details about that please? How'd you find a suitable mount, how well has it performed? Can you remove it easily?
That is really badass!
frizzanz is offline   Reply With Quote
Old 04-01-2012, 09:00 PM   #5607
Skemcin
Member#: 167252
2002 OBS Wagon
Midnight Blue
PM Sent
Old 04-04-2012, 02:55 PM   #5608
Proper282
Member#: 294084
02 Wrx Wagon
MBP
Talking
woohoo! The FedEx guy showed up this morning!
Get-Primitive light bar
temporary fitting of the lights so I can figure how I want to run the harness. I'm thinking some ADL clamps and split loom should do the trick.
Hopefully be able to mount it this weekend. The bar comes with all the things needed to install it(even a hole saw). Very good construction and great customer service. This bar was worth the $$$ and wait.
Proper282 is offline   Reply With Quote
Old 04-04-2012, 04:52 PM   #5609
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
^^ What'd you pay for it, and was shipping a killer?
Old 04-04-2012, 04:53 PM   #5610
subaru3169
Member#: 55252
* pullup bar *
^^^where are the mounting points??
subaru3169 is offline   Reply With Quote
Old 04-04-2012, 05:41 PM   #5611
Proper282
Member#: 294084
02 Wrx Wagon
MBP
It mounts through the bumper using the crash beam mounting bolts.
The bar was $395 shipped through fedex. Took only 2 days from oregon to cali.
A little pricey but it's solid as a rock!
Old 04-04-2012, 08:14 PM   #5612
subaru3169
Member#: 55252
* pullup bar *
i'd like to see how it mounts if you could take some pics when you get to it=)
Old 04-04-2012, 08:24 PM   #5613
gregroot198521
Member#: 280844
2006 STi
Originally Posted by Proper282
woohoo! FedEx Showed up this morning!
How thick are the bars it's made from? 1/2"?
gregroot198521 is offline   Reply With Quote
Old 04-04-2012, 09:29 PM   #5614
Proper282
Member#: 294084
02 Wrx Wagon
MBP
@ work right now. I'll take pics and measurements when I get home. Also planning on documenting the install as best I can.
Old 04-05-2012, 01:07 PM   #5615
Proper282
Member#: 294084
02 Wrx Wagon
MBP
The mounting hole.
the reinforcement beam bolt goes through here and secures the bar to the beam.
And the bar is 1" O.D. Thickness, not sure. It's not too heavy a wall. The whole bar only weighs about 12lbs.
Oh and a quick shot of the light mounting tabs.
This thing is really well put together. I wouldn't hesitate to purchase any of the Primitive products after seeing this piece.
Old 04-06-2012, 06:38 PM   #5616
Proper282
Member#: 294084
02 Wrx Wagon
MBP
installed
Old 04-06-2012, 07:03 PM   #5617
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
^^ So you drilled the stock bumper?
Old 04-06-2012, 07:10 PM   #5618
gregroot198521
Member#: 280844
2006 STi
installed
Now if only Paul @ Primitive made one for the 08+, I wouldn't have to try and get a custom one built
Old 04-06-2012, 07:10 PM   #5619
Proper282
Member#: 294084
02 Wrx Wagon
MBP
oh yeah!
http://forums.nasioc.com/forums/show....php?t=2336077
Old 04-06-2012, 08:15 PM   #5620
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by Proper282 View Post
I don't know about that, it makes it a permanent install. I'd like to be able to remove the bar easily if need be. I also think the wide hoops look out of place. I like the look of the light bar at the top of this page a bit more, but it's super pricey. Maybe I'll just get a local shop to weld a receiver-type setup for a bar on my bugeye.
Old 04-06-2012, 08:29 PM   #5621
Proper282
Member#: 294084
02 Wrx Wagon
MBP
Yeah I don't care about removing it. But I can actually remove it in probably 3mins(No exaggeration) it's only 4 bolts that are easily accessible and a plug for the lights. Maybe easier than most other bars out there. But if it's the holes that concern you I get that. But that wago is 10yrs old and the bumper it covered in chips and pitts
Old 04-06-2012, 08:41 PM   #5622
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I've got the same car as you but in silver
Old 04-06-2012, 10:35 PM   #5623
Proper282
Member#: 294084
02 Wrx Wagon
MBP
^ You've got good taste... I was looking for white, but found this one.
Old 04-07-2012, 11:45 PM   #5624
FLHRSI
Member#: 284321
Give a ring over there and ask. He probably would.
FLHRSI is offline   Reply With Quote
Old 04-07-2012, 11:51 PM   #5625
gregroot198521
Member#: 280844
2006 STi
Ah, I would, but I'm gonna have a local guy design something for me that will do double duty as a brush guard and a light bar, then I can off-road with my soon-to-be 2" lift and have a spot to mount the Rigid Industries LED light bar I want to get. Probably a 10" combo light and add 2 4" or 6" floods later on for some turning lights. FWIW though, I do run Paul's skid plate, and I would pobably run one of his light bars if I didn't have to ship, and hadn't started a plan already.
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 588 04-09-2015 02:49 AM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 03:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 12:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 03:37 PM
