Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 03-07-2012, 04:58 PM   #1
arod15
Member#: 304906
2015 STI
CWP
Default 2011 wrx stage 2 cobb sf
2011 wrx hatch with catted downpipe, cobb sf intake, and tp stage 2 map. I use 93 octane fuel. Did a 3rd gear pull though I had to slow down due to traffic and it was raining. I really just use the car as a daily driver, just want something safe and reliable. How's everything look? Eric at TP gave me the ok, just wanted to see if there was any other incite. Thanks!
https://docs.google.com/spreadsheet/...kTzBReWc#gid=0
arod15 is online now   Reply With Quote
Old 03-22-2012, 09:53 AM   #2
slinkyWRX
Member#: 280483
03 Bugeye WRX
looks good to me. no knock and running a good amount of boost.
slinkyWRX is offline   Reply With Quote
Old 03-30-2012, 05:06 PM   #3
tougestar
Member#: 287562
Obsidian Black Pearl
i was looking through your logs and noticed that you logged "manifold relative pressure". is that the same as turbo "boost". sorry for the newb question
tougestar is offline   Reply With Quote
Old 03-30-2012, 05:40 PM   #4
Dartholomew
Member#: 208771
2009 WRX
He's probably logging through a Tactrix (opensource). "Manifold Relative Pressure (corrected) (psi)" is the same as Boost on an AccessPort.
Dartholomew is offline   Reply With Quote
Old 04-01-2012, 05:02 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
you're logging the wrong MRP....its pegging at 18.43.
keep an eye on your intercooler endtanks....
Old 04-02-2012, 01:20 AM   #6
throttlehappy
Member#: 313497
2012 S206
^^ As above. Log the extended parameters version for accuracy
throttlehappy is offline   Reply With Quote
Old 04-02-2012, 02:17 AM   #7
Dartholomew
Member#: 208771
2009 WRX
As Phatron mentioned, log "Manifold Relative Pressure (corrected) (psi)" instead. The one without "(corrected)" doesn't show boost above 18.43 so you'll never really know if you're overboosting.
Why is it like that? No idea. But it is.
Old 04-07-2012, 02:04 AM   #8
arod15
Member#: 304906
2015 STI
CWP
Oh wow, thanks for pointing that out. Luckily I decided to recheck this thread. I'll have to relog a few runs tomorrow with the correct MRP to see if I'm overboosting, which it's very possible that I am if 18.43 is the highest the non corrected will read.
2011 WRX Stage 2 HWG Cobb Map bkruelle Proven Power Bragging 21 01-02-2012 09:16 PM
2011 WRX Stage 2 Numbers? BrendanTheGreat408 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-01-2011 03:27 PM
Advice: possible cold feet 2011 WRX Stage 2 EricInHoodRiver AccessPort 19 11-12-2011 12:24 PM
2011 WRX stage 2 Log check please aTriz AccessPort 4 11-03-2011 04:41 PM
2011 WRX Stage 2 overboosting issues Jaker AccessPort 32 02-23-2011 03:01 PM
