#1 |
Member#: 303321
I am having troubles with EcuFlash not wanting to read my ROM on my 07 WRX I posted this in the OpenEcu.org forums but was wondering if maybe someone here has a solution to this. The cable is an op2 and the computer is a compaq with vista. Any help would be great thanks.
#2 |
Member#: 212154
South East
Vehicle:02 bugeye, manley ej257, pt5857, MBP on E85 |
what version of ecuflash? The beta version doesnt work with vista iirc. Try version 1.42 if you havnt already. And run as admin.
#3 |
Member#: 204014
South East
Vehicle:02 Bugeye Rotated, HTA3582, E85 |
What exactly is it doing? or not doing?
#4 |
Member#: 303321
Ok I will try the 1.42 and run it as admin. The program itself seems to be working fine it just doesnt seem to be recognizing my car. But the cable works fine with RomRaider.
![]() This was with 1.43 but it was doing the same thing with 1.42 |
#5 |
Member#: 294644
Vehicle:2011 WRX Agile Auto DGM 290.5whp 331wtq |
I had this same problem, i switched to a new laptop with windows 7 before really troubleshooting, hope you figure it out!
#6 |
Member#: 303321
Thanks i might save up and go to a laptop with Windows 7. Did you have many problems with Windows 7
#7 |
Member#: 204014
South East
I just went thru this on window 7. I have a post about 5 or 6 down from yours.
In options, do you have your "metadata directory" pointing at the "Subaru" file or the "rommetadata" file? |
#8 |
Member#: 303321
Downloaded 1.43, current definitions and pointed the directory at rommetadata and everything is working now
#9 |
Member#: 204014
South East
great
#10 |
Member#: 204014
South East
For folks searching:
For EcuFlash: 1. Download the latest EcuFlash definitions file. Choose the file with the units you wish to use (metric or standard). 2. Delete the “Subaru” folder (backing up if necessary) in the Metadata directory specified in File->Options menu of EcuFlash (ex. C:\Program Files\OpenECU\EcuFlash\rommetadata\). 3. Unzip the new Subaru definition folder into the same directory (rommetadata). 4. Make sure your Metadata directory is pointing to C:\Program Files\OpenECU\EcuFlash\rommetadata Not C:\Program Files\OpenECU\EcuFlash\rommetadata\Subaru |
#11 |
Member#: 245333
Vehicle:2002 WRX psm |
I had the same problem with my laptop. It was running windows 7starter edition. RomRaider worked fine but ecu flash would not recognize the car. Upgraded to a better version of windows 7 and the program works perfectly
| Thread Tools | |
| Display Modes | |
| Odd problem on spare laptop with ECUFLASH - Can't open image file | Hyper | Open Source Reflashes | 4 | 02-03-2010 07:23 AM |
| Trouble with lighting on Prosport Boost gauge | David03WRX | Newbies & FAQs | 4 | 07-04-2009 10:45 PM |
| Trouble with Cat on a Dolphin Level 5... | hikeeba | Off-Topic | 9 | 02-06-2008 12:17 PM |
| Can anyone help me with IPP on Vista? | subiekid | Off-Topic | 4 | 06-21-2007 12:40 PM |
| Problem with ecuFlash on 06 STI | blueturbo2 | Commercial ECU Reflashes | 6 | 06-06-2006 02:25 PM |
