Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 02-20-2012, 10:35 PM   #76
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Originally Posted by veener79
Just wondering what his a HIR bulb?
Quoting directly from Candlepower store (http://store.candlepower.com/9011hir.html):
"The HIR bulbs are not some tinted or over-wattage version of 9005 or 9006, but rather employ a relatively new technology called HIR, Halogen Infrared. The mechanical dimensions of the bulb are all virtually identical to the 9005 or 9006, but the bulb glass is spherical instead of tubular, with the sphere centered around the filament. There is a "Durable IR Reflective" coating on the spherical glass. Infrared = heat, so the coating causes heat to be reflected back to the filament at the center of the sphere. This causes the filament to become much hotter (producing more light) than it can by passing electricity through it, *without* the shorter life or greater heat production that comes with over-wattage bulbs (to say nothing of over-wattage bulbs' incompatibility with stock wiring.)
Here's the comparison:
High beam stock: 9005, 12.8V, 65W, 1700 lumens, 320 hours High beam ... HIR1(9011), 12.8V, 65W, 2530 lumens, 320 hours
Low beam stock: 9006, 12.8V, 55W, 1006 lumens, 360 hours High beam ... HIR2(9012), 12.8V, 55W, 1875 lumens, 800 hours"
0BlueSTi4 is offline   Reply With Quote
Old 02-20-2012, 10:42 PM   #77
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Originally Posted by erik11876
I did the 9011 high beam conversion (i have factory xenon) in my 2011 WRX today, what a HUGE difference. Don't waste your time, do this mod!!
Are you saying that you installed HIR1 or 9011 bulb into your high beams? HIR1(2530) is supposed to be only 430 lumens more than the stock H9(2100) bulb. Do you really see that much difference from extra 430 lumens?
And by "factory xenon" do you mean you have factory HID in your low beams? How does the factory HID compare to your new high beam HIRs?
Old 02-20-2012, 11:58 PM   #78
Jaker
Member#: 69185
2011 WRX 5 Door
Originally Posted by 0BlueSTi4
I wonder how much longer your HIRs would have lasted if you disabled DRLs.
I think they would have lasted longer if my daily commute did not involve rumble strips at a 4 way stop sign.
Jaker is offline   Reply With Quote
Old 02-21-2012, 10:42 AM   #79
erik11876
Member#: 275888
2011 WRX Limited
Yes I have factory HIDs. They match up nicely. The biggest issue I had with the factory high beams is there was a smallish gap between the projector cutoff on the HIDs and the bottom light scatter from the halogens. The 9011s fill that void of light in perfectly. The brightness difference is noticeable on a bright sunny day! The light is more of brighter white and less of yellowish color. Bang for your buck it's a GREAT mod. I got these per Daniel Sterns recommendation, well worth it.
erik11876 is offline   Reply With Quote
Old 02-22-2012, 12:23 PM   #80
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
Just wondering, does anyone know if the HIR2(9012) bulb can be modified to fit H11 socket and connectors?
subyski is offline   Reply With Quote
Old 02-25-2012, 02:47 AM   #81
Myth21
Member#: 246851
2007 UGM
2012 LR
It is not a bad DIY for $15 at all, but coming from always using HID this is quiet a disappointment... maybe down the road I'll bake em lights and retrofit...
Myth21 is offline   Reply With Quote
Old 02-25-2012, 12:20 PM   #82
veener79
Member#: 204304
2008 WRX 4D Stage 2
I agree compared to factory HID this setup is not close. What I have seen from cheap HID kits and what people pay for those this is a lot better setup for the cash in my opinion. You do not have to worry about blinding people or giving the cops a reason to pull you over.
veener79 is offline   Reply With Quote
Old 02-26-2012, 12:13 AM   #83
Airplay355
Member#: 213825
2013 BRZ
Just did this mod today because the stock bulbs absolutely suck. They light up the road directly infront of you and nothing else.
While certainly not HID, there's definitely a noticeable difference and with the squirrel finder bent down I have a pretty clean cut off instead of the stock glare.
I think eventually I'll retrofit in HIDs but for now this will keep me tied over.
Airplay355 is offline   Reply With Quote
Old 02-26-2012, 03:59 AM   #84
rattmobbins
Member#: 280184
2011 Impreza 2.5i
Spark Silver
Just got my bulbs in today too, and I'm not all that impressed. It's a little brighter, I think, but not whiter at all, which is really what I was hoping for.
Luckily I only spent $15 on 2 Philips bulbs on Amazon, so it's no biggie.
rattmobbins is offline   Reply With Quote
Old 02-26-2012, 04:13 AM   #85
0BlueSTi4
Member#: 98955
2011 WRX Hatch
+++++1
Old 02-26-2012, 01:55 PM   #86
erik11876
Member#: 275888
2011 WRX Limited
Obviously they are no replacement for HIDs, nothing is. With halogens they best you can do is brighter without adding an destructive heat that melts connectors and housings. I'm kinda over searching for a halogen that COLORwise, will match HIDs, it's not happening without frying stuff, having short bulb life and crappy light output. If you want HIDs, retrofit and you will be happy!
Old 02-26-2012, 11:14 PM   #87
Airplay355
Member#: 213825
2013 BRZ
It's certainly not a substantial upgrade. It is nice to be able to see now though and I only got the $7 bulbs as well. Did you bend down your squirrel finder? That seems to have helped me.
Old 02-27-2012, 03:05 PM   #88
Icy2012WRX
Member#: 310238
12 WRX Premium
ISM
I did this over the weekend and it's not a world of difference I can certainly tell..it seems like a more white light and the light seems to go farther to the sides and out more but prolly will save for a retrofit anyway lol
Icy2012WRX is offline   Reply With Quote
Old 02-28-2012, 11:28 PM   #89
Jejunum
Member#: 15773
2011 Impreza WRX
Any HIRs available for stock fogs?
Jejunum is offline   Reply With Quote
Old 02-29-2012, 02:31 PM   #90
Bullit62
Member#: 281311
2009 WRX
Originally Posted by hhcchen View Post
did anyone find out having their low beams on while turning on the high beams after the mod?
(the factory set up should be no low beam while the high beam is on)
Originally Posted by 0BlueSTi4 View Post
I don't see how having a different bulb would change the way the circuit works.
no one has both their high and low beams on while turning on high beam?
I found this happening as well. Before the mod my low beams and high beams operated separately. Now, when I click on my high beams, the lows stay on as well. I used the standard Sylvania H9's from AutoZone. They are definitely brighter than the H11's!
I live in a rural mountainous area with no public-funded outside lighting and decent lighting is vital to keep the local fauna out of my grill/windshield/front seat.
Bullit62 is offline   Reply With Quote
Old 03-03-2012, 02:05 AM   #91
Airplay355
Member#: 213825
2013 BRZ
My lows stay on with the highs now too, thought I can't confirm that this didn't happen before the mod. I don't care much as I live in a populated area and never get to use the highs. If I ever did though, they are surface of the sun bright so I'm OK with it
Old 03-05-2012, 03:58 PM   #92
Spdrush
Member#: 242806
2010 STI SE
Have had H9 bulbs in 2010 STI SE since new April 2010. The factory H7s are dangerous. Thinking of HIR bulbs in the brights without the stupid yellow paint.
All 4 lights go on with high beams I think from day one pre mod.
Spdrush is offline   Reply With Quote
Old 03-15-2012, 11:24 AM   #93
amason
Member#: 30723
2005 Legacy GT wagon
GRP
I don't believe you. I think your lows stayed on with highs from day one. Mine did (05 LGT) but I didn't really notice until a friend pointed it out. Yet another good thing about Subie lights.
Andy
amason is offline   Reply With Quote
Old 03-15-2012, 11:32 AM   #94
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
I checked this a couple of days ago, but forgot to post up. My car is stock, with stock bulbs. The high and low beams are on simultaneously when I hit the high beams.
bicycle_wreck is offline   Reply With Quote
Old 04-06-2012, 11:02 AM   #95
dickiescoob
Member#: 259508
2015 WRX Limited
Just did this last night on my car, and noticed the difference this morning.
Will do the wife's this weekend. Before doing hers though, I will get pics side by side of hers/mine for a good comparison.
dickiescoob is offline   Reply With Quote
Old 04-08-2012, 02:30 AM   #96
Myth21
Member#: 246851
2007 UGM
2012 LR
Here is a better comparison...as you can see it's definitely an improvement over stock H11's..
But I've always liked HIDs..really thinking about picking up retrofits.
Old 04-13-2012, 01:06 PM   #97
oceanwater48
Member#: 315882
V8 U make
Baby Poop
You have a 2012 subaru? or 2011 it doesnt matter. You have a housing which already can sustain a HID light that connect to ballast, connect to the orginal wiring. Put that ballast somewhere, next to a piece of metal. No plastic because that ballast will get hot !!!!
No need for a retrofit. My definition of a retrofit is buying a whole new housing with new bulbs and ballast installed in by removal of the OEM housing. Too much
oceanwater48 is offline   Reply With Quote
Old 04-13-2012, 04:09 PM   #98
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
a retrofit is when you install HID projectors in your original housings. the stock housings have Halogen projectors, not HID projectors, and while they look similar (both are projectors), they will refract light differently. HID bulbs with Halogen projectors may be "better" than HID bulbs with regular Halogen reflectors, but it is still not correct.
Old 04-13-2012, 07:06 PM   #99
Myth21
Member#: 246851
2007 UGM
2012 LR
Eh dude mines an wrx not sti. Hid housings only comes with sti..meaning I have regular halogen projectors....
Old 05-06-2012, 10:22 PM   #100
Divinito13
Member#: 318102
2010 OBS
How can I fit PIAA H9 into the low beam...would it melt/burn cables or headlamp?
Divinito13 is offline   Reply With Quote
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 09:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 09:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 07:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 02:01 AM
