Old 03-19-2012, 06:58 PM   #1
Doomsayer
Member#: 190806
2004 WRX 16g'd
Default Up Pipe -> Turbo leak
So i recently discovered that I have leak from my up pipe to my turbo. I installed everything myself about ~6 months ago. I had no leaks when I finished all my installs so this is a recent development.
I used the Grimmspeed 2x thick gaskets, so I'm not sure if the gasket failed or what the issue is.
My question is whether I should buy another gasket or if I should just forgo the gasket all together? Any help would be appreciated.
As a bit of an aside, I also threw a p0304 code (cyl 4 misfire) could this leak possibly trigger it?
Doomsayer is offline   Reply With Quote
Old 03-20-2012, 04:39 PM   #2
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
You need a gasket.
Use a stock thickness gasket.
DiscoGsus is offline   Reply With Quote
Old 03-20-2012, 04:59 PM   #3
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
find out if the leak is from the lower or the top gasket first. You have to have a gasket or it will leak like crazy. No it will not cause the code, thats a separate issue
UK-Wagon is offline   Reply With Quote
Old 03-20-2012, 05:31 PM   #4
jimbosv650
Member#: 261307
04 wrx wagon
Been there. The lower joint was the issue in my case. I used on oem gasket and locking nuts, that solved it.
jimbosv650 is offline   Reply With Quote
Old 03-20-2012, 05:44 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I'd try tightening the flanges down first. Hardware can vibrate itself loose over time. If tightening it up doesn't fix it some new gaskets may be necessary. If they've blown out or become defective because of a defect in the part we will definitely get them replaced for you!
Mike
GrimmSpeed is online now   Reply With Quote
Old 03-20-2012, 07:24 PM   #6
Dirty_WRX
Member#: 258491
2002 VF34'd Bugeye
My Other Ride's your MOM
Mike
This is why i buy from GS if possible the customer service is 2nd to none.Hell they even hunt your problems down and try to fix them apparently
Dirty_WRX is offline   Reply With Quote
Old 04-09-2012, 05:56 PM   #7
Doomsayer
Member#: 190806
2004 WRX 16g'd
Mike
Mike,
I retightened everything in that area (downpipe, uppipe, turbo, etc...) and the leak persists. So I do believe that I need a new gasket.
Canada: Turbo XS Up Pipe + HKS Turbo timer brandonbeeb Private 'For Sale' Classifieds 1 04-05-2006 04:09 PM
up pipe " turbo xs kicks a" just a little heads up!! boostinscooby Car Part Reviews 1 07-30-2005 11:46 AM
fs: hks up pipe w/ turbo inlet gasket spankaveli Private 'For Sale' Classifieds 0 12-23-2003 11:34 AM
up pipe to turbo studs ErikAnderson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-12-2003 04:18 AM
