Old 04-07-2012, 09:36 PM   #1
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Default boost issues
2002 wrx cobb ap tuned stage 2
It started off i was only hitting 5psi, i was missing the restrictor pill. i put one in and now I'm only hitting 10 psi.
I done the following to try and figure this out.
-swapped wastegates
-cleaned MAF
-Checked for leaks
-Loaded the stage 2 HWG (high waste gate map)
-Swapped BCS with one that I'm pretty positive is still good.
I disconnect the vacuum hose to the waste gate and i can hit 15 psi with ease..
what else could the problem be?
the car drives fine, its just pissing me off that i can't hit the target boost!
soob noob is offline   Reply With Quote
Old 04-07-2012, 09:52 PM   #2
van_dutch
Member#: 198633
2004 WRX
Did you get a pill specifically for your car? If you got one with a hole size not intended for your model year, you could still have issues.
van_dutch is online now   Reply With Quote
Old 04-07-2012, 10:36 PM   #3
soob noob
Member#: 220158
02 bugeye
medamullet tuned
i got it from the shop i bought my car from. so i assumed since they said it was.. i could go to the dealership and just get a new hose kit just for safety
Old 04-08-2012, 10:03 AM   #4
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Bump any more ideas? I think I'm going to just buy a new hose kit from Subaru with the restrictor pill.. Just to rule that out.
Old 04-09-2012, 05:06 PM   #5
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Bump.. Some locals are just suggesting throwing on a MBC and calling it good. It's tuned on cobbs stage 2 map, so as long as I dont exceed the tuned boost on that map I should be good right?
Old 04-09-2012, 05:11 PM   #6
LNG
Member#: 128576
02 wrx
Change ap maps and see if you get full boost
LNG is offline   Reply With Quote
Old 04-09-2012, 09:42 PM   #7
soob noob
Member#: 220158
02 bugeye
medamullet tuned
I've already done that, Several times. I went back to stock, reflashed stage 2, then loaded the high waste gate stage 2 map from cobb.
boost issues soob noob Rocky Mountains Impreza Club Forum -- RMIC 29 04-19-2012 01:05 AM
Boost issues /Boost in neautral? HELP PLEASE!!! miket430 Newbies & FAQs 18 07-25-2010 06:15 PM
idle issues and boost issues jdgrimm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-05-2006 09:45 PM
Boost issues or Gauge Issues? IwantONE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-12-2006 05:18 PM
Will Auxiliary Boost Controller fix Cobb AccessECU/AccessPort low boost issues? ImportVenom Engine Management & Tuning 2 06-23-2004 12:22 AM
