Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 04-05-2011, 07:19 PM   #26
RB2B
Member#: 222663
2004 STi
Sticky In The Pre-2002 Thread!!!
RB2B is offline   Reply With Quote
Old 04-06-2011, 07:56 AM   #27
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
When I get a chance next I'll go back and edit my first post. I've done more comparisons on these two since then that I haven't posted yet.
I'm glad I finally got a sticky thread
AWD P & A is offline   Reply With Quote
Old 04-06-2011, 01:45 PM   #28
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
At the head of your post, can you list out the observed differences?
rob is offline   Reply With Quote
Old 04-06-2011, 06:43 PM   #29
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Sure! I plan on going back and adding everything from injectors all the way to internals.
Old 06-20-2011, 10:29 PM   #30
cmyles
Member#: 275572
2004 WRX
JBP
Is this thread only about the Heads?
What about blocks?
I know that EJ20K are Open deck? Or Semi ?
as opposed to Ej20g which, most are closed deck motors.
cmyles is offline   Reply With Quote
Old 06-21-2011, 09:18 PM   #31
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
Dent Black/scratch primer
Sorry I haven't been able to fix this thread..I'll get on it ASAP.
To answer your question theres not much difference on the blocks..
20k- forged internals, open deck
Late G- open deck, cast pistons and rods
The early 20G blocks were closed deck until like 93-94ish
Cbgrandtheftauto is offline   Reply With Quote
Old 07-02-2011, 01:31 AM   #32
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Of the regular WRXs only the manual 1992-1993 GC8A WRX had a closed deck block.
After that the closed deck block was a special option of STI version 1 and 2 and only standard on the 1994-1996 WRX type RA versions with light weight valve train heads (I believe they also had the 5th injector).
All other GC8/GF8 engines are open deck including the 1999-2000 EJ207.
All rods on all GC8/GF8 engines are the same (which are nothing special, they are identical to non-turbo USDM EJ18/22 rods).
All WRX had cast pistons, except:
1994-1996 EJ20G WRX type RA (mentioned above)
1997-1998 EJ20K WRX STI / STI RA
1999-2000 EJ207 WRX STI / STI RA
All other EJ20G, EJ20K, EJ205 and EJ207 GC8/GF8 engines have cast pistons.
Marnix is offline   Reply With Quote
Old 11-19-2011, 01:39 PM   #33
2slofouru
Member#: 90539
95 L with ej20k
powa, Raven R6
So what would be the difference in the heads and cams of a normal wrx ej20k and ej20g? I've also heard of RA non sti so would the heads just be normal k and g in those cases? I see information bouncing back and forth in this thread.
2slofouru is offline   Reply With Quote
Old 03-14-2012, 01:01 AM   #34
2slofouru
Member#: 90539
95 L with ej20k
powa, Raven R6
Another bump of hope. I have valvetrain from ej20k and ej20k sti heads and the valves in both are identical, low magnetic exhaust and normal high carbon steel intake. The spring retainers are of course different because the sti has shim under bucket. I plan on replacing the valves, springs, and retainers and retaining the shim under bucket arrangement. What I'm wondering is why the normal k heads have a 48mm long spring whereas the sti springs are 56mm? I'm looking for single (non dual) aftermarket springs, retainers, and valves for the sti heads and am not sure which to use at this point.
Old 03-14-2012, 06:30 AM   #35
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Originally Posted by Matt Monson View Post
But riddle me this... These are EJ20K STI heads with shim under bucket. What about just plain standard Ej20K heads with shim over bucket. Wouldn't those be the same as those late Ej20G heads? Isn't it only because these heads are STi that there's any difference at all between the two castings?
I think you are right. Only the STI, Spec C, Type RA heads have the shim under bucket from what I know.
If anyone cares I just converted a set of those shim under bucket to solid buckets like what is used on the MY04 and up engines. There was BARELY enough room to grind the valves to spec once the retainers were replaced meaning all of my shims were in the 488-499 range
ciper is offline   Reply With Quote
Old 03-15-2012, 12:21 AM   #36
2slofouru
Member#: 90539
95 L with ej20k
powa, Raven R6
This section (pre-2002 factory turbo powertrain) needs a sticky section with compiled good (true) specific information on head and valvetrain specs for the pre 02 turbo ej's instead of random conjecture and opinion. There is always so much searching required for the pre usdm turbo information but it rarely leads to anything solid.
Old 03-15-2012, 04:32 AM   #37
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
It's really easy. Heads for 1997-1998 DOHC turbo are as follows:
EJ20G: shim over bucket, normal valves and springs, all same as USDM EJ25D except for the cams
EJ20K: shim over bucket (same as EJ20G), specific EJ20K valves and springs, specific EJ20K cams
EJ20K STI: shim under bucket (unique for EJ20K STI and 22B), same valves as EJ20K, specific EJ20K STI springs, retainers, same cams as stock EJ20K
The castings for the above heads are nearly identical, so if you want to convert to aftermarket setup use USDM EJ25D setup. If you want to use shimless buckets use the 2004-2008 EZ30R exhaust buckets they are 33.0 mm in diameter, same as the 1997-1998 EJ20G and EJ20K buckets.
Old 03-15-2012, 05:38 AM   #38
ciper
Member#: 15543
90BJ Legacy LS ABS
I'm pretty sure EJ25D was the same as the EJ20K (late EJ20G possibly). The EJ25D has solid lifters. EJ25D has single bolt coil attachment. EJ25D has plastic cam gears. Look at the valve covers
Here are pictures of some EJ25D heads.
http://imageshack.us/photo/my-images...082239fg3.jpg/
http://i4.photobucket.com/albums/y10...s/IMG_3591.jpg
Then the first picture in this thread is EJ20k- http://forums.nasioc.com/forums/show...9&postcount=32
You dont need to use EZ30R buckets specifically. MY04 and up shimless buckets are the same and much easier to find I converted my STI ej20k heads using standard 2005 STi buckets I had. (with regular retainers of course). I honestly think the EZ30R buckets are the exact same parts with a different part number. It's too weird they are the EXACT same price down to the penny and are identical in appearance.
Edit: Haha already a thread about this - EJ25D w/ EJ20K Heads?
Old 03-15-2012, 06:57 AM   #39
ciper
Member#: 15543
90BJ Legacy LS ABS
If anyone has some extra EJ20G/K cams and some extra valves I would be interested in them. Another shop screwed me over and threw away a set of Spec C RA heads I had
I have a full set of EJ20 shim UNDER buckets I could offer in trade if you're interested. Thats 16 of the special buckets, retainers and little shims.
I want to crosslink this thread here -
Differences in Ej20G and Ej20K
Old 03-15-2012, 07:54 AM   #40
2slofouru
Member#: 90539
95 L with ej20k
powa, Raven R6
Thanks Marnix, for adding some useful information. It's good when a knowledgeable member gives factual information based on what they know to be true rather than saying "they appear to be", "most likely", "seems like", or "we'll settle on" in front of technical information. Based on your reputation here and your demeanor since I've been a member here, its easy to trust your input
Old 03-18-2012, 05:34 AM   #41
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Thanks. It helps I have first hand experience with all factory DOHC turbo engines to date especially the 90s JDM engines. It also helps I have the JDM FSM ('New Model' book) and the EUDM and JDM factory part catalogues (CD-ROM).
Old 04-09-2012, 10:59 PM   #42
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Good info thanks. What is the difference between 20k and 20g cams? I've got a 97 forester 20g and I'm planning to put my 257 block together with these heads. Are the 20k cams better?
kimokalihi is offline   Reply With Quote
Late ej20g cams Cbgrandtheftauto 1993 - 2001 Impreza Specific Parts 4 03-11-2010 02:49 PM
EJ20K vs EJ20G Maf Scaling? JDMFLCL Pre-2002 Factory Turbo Powertrain 7 03-02-2010 09:14 AM
late ej20g (20k) engine timing rs182 Pre-2002 Factory Turbo Powertrain 28 01-10-2010 03:48 PM
EJ20G vs EJ20G Old vs Late w/Pictures bape-ape Pre-2002 Factory Turbo Powertrain 9 02-20-2009 04:34 PM
ok. who actually knows ej20K electronics and ej20G electronics well? swapstar Subaru Conversions 24 12-21-2005 03:48 AM
Message Board Statistics All times are GMT -4. The time now is 03:58 AM.
