Notices
Old 04-08-2012, 09:41 PM   #1
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
Question swapping intake manifolds
I have a 2008 legacy gt. It currently has a "plastic" oem manifold. im looking into a BW EFR 7670 twinscroll and would have to rotate the manifold. At this point ive heard mixed opinions on my current manifold some say its great for preventing heat sink while others say its weak and doesnt allow proper air flow at higher power. so my question is what would be a good option in regards to swapping out my manifold for another? what year and vehicle would fit?
ruggerheist is offline   Reply With Quote
Old 04-09-2012, 12:39 PM   #2
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
Bump for some advice
Old 04-09-2012, 12:44 PM   #3
rob1n1
Member#: 276425
2013 335is
Alpine White
Try http://www.legacygt.com/ they might have more answers.
Old 04-09-2012, 11:19 PM   #4
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
I'm on there. That's where I got all my differing opinions but thanks
Old 04-09-2012, 11:21 PM   #5
monkiboy
Member#: 202958
2008 wrx
you don't have to rotate the manifold. why would you think so? there's even a couple build threads of folks with 08+ wrx and 05+ lgt doing what you are planning. i've got a 08 and a 7670 going on next week and while i am doing a rotated jdm long runner, i know for a fact it wasn't required.
perhaps you are committed to running full-race's fmic setup and tubing which requires a reverse mount? you couldn't do that with the composite manifold.
monkiboy is offline   Reply With Quote
Old 04-11-2012, 11:14 AM   #6
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
You just reposted my op. What manifold from what model/year will fit an ej255?
Old 04-11-2012, 01:06 PM   #7
monkiboy
Member#: 202958
2008 wrx
you're whole premise/query/search is based on the fact that you state you have to rotate your manifold for your future plans - you do not. your stock manifold will work just fine.
Old 04-11-2012, 03:01 PM   #8
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
Full race kit requires a rotated manifold, so yes I am committed to that. So since I can't reuse my manifold what can I use? Would an RS work?
Old 04-11-2012, 09:06 PM   #9
monkiboy
Member#: 202958
2008 wrx
any to provide further specificity to this thread, you are talking about how the full-race fmic kit requires the rotated manifold. you are not under the presumption that the full-race twin scroll kit does, correct?
also, are you familiar with the costs and laborious effort is required in rotating a manifold (regardless of which), custom efforts, possible throttle body issues/resolution, etc required? if not, it is far more cost effective to run your stocker manifold in stock configuration with any myriad of cores and just have the one charged pipe fabbed up.
if you're still set on the full-race fmic kit and reversed manifold, just about any manifold can work. you will want to take into consideration the throttle body of the manifold you are using and that of your current car. all stis are DBW as are all 06+ wrx. the 02-05wrx is DBC.
if you really don't care about costs, then it'd be a great consideration to perhaps pick up a jdm long-runner manifold and eliminate the necessary work and costs of tgv deletes. this will of course require work to swap from dbc to dbw and a bit of fab with the fuel rail alignment and holding bracket.
Old 04-12-2012, 01:45 AM   #10
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
Out of all if your posts, you would've saved yourself and myself by just posting the very last paragraph. But ill take care of tgv deletes separately so long runner or whatever is not happening. How about this; What make/year subaru has an intake mani that is capable of directly swapping over onto an 08 legacy gt?
Old 04-12-2012, 01:53 AM   #11
monkiboy
Member#: 202958
2008 wrx
just a little bit more effort and specificty in your original post would have saved us some time. and you have yet to confirm details of the build and components.
i guess you really don't want sage advice. you just want the answer to a question that very likely will lead you down the wrong path and higher costs with no appreciable benefit.
ok, fine.
an 08+ wrx. it's the same manifold so it will swap right over. outside of that, no other manifold is capable of directly swapping over.
this is an unnecessarily tedious effort and my exit. sincerely, good luck to you, sir.
Old 04-12-2012, 10:40 AM   #12
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
The specifics are still being ironed out, I.e. fueling, how tgv deletes are being handled, etc. I do appreciate your advice, just saying you could've been more concise. And I could've given more info
Old 04-13-2012, 04:06 AM   #13
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
If I go rotated I'll just flip the stock manifold. They are plenty strong, and I strongly suspect they're easier to flip than the old style manifolds since the TB doesn't angle upward. Set up the FMIC so the charge flows clockwise. Find some pics of a flipped LGT manifold and you'll see what I mean - it works out pretty well.
Old 04-14-2012, 01:23 PM   #14
sleazy07sti
Member#: 273116
2007 Hawkeye Sti
0bp
I'm looking to go with the jdm manifold with the long runners and need to know everything needed for the swap.I already have aftermarket topfeed fuel rails and topfeed id1000 Injectors.I just started a thread on this matter so any feedback will be highly apriciated
sleazy07sti is offline   Reply With Quote
Old 04-14-2012, 02:31 PM   #15
monkiboy
Member#: 202958
2008 wrx
as to avoid a threadjack since your query is very different, ill reply in your thread.
Old 04-14-2012, 03:04 PM   #16
sleazy07sti
Member#: 273116
2007 Hawkeye Sti
0bp
Yea didn't mean to thread jack.definitely apriciate it bro
Old 04-15-2012, 12:30 PM   #17
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
I let my ignorance get in the way of this thread. Looked into a long runner and it makes sense. Monki guy, you mentioned the labor and cost involved with switching from dbc to dbw. My LGT is dbw so the long runner should, in theory, bolt right up?
Old 04-15-2012, 02:07 PM   #18
monkiboy
Member#: 202958
2008 wrx
your lgt is DBW, correct. the jdm long-runner intake manifold is designed for a DBC throttle body. the intake manifold will bolt up fine in whatever configuration but you will need to either run the jdm rails or get a bracket fabbed up for the alternate jdm spacing of the fuel rail attachment of the manifold. then you have to find a way to get your DBW throttle body adapted to fit the DBC opening and bolt holes of the jdm intake manifold. there are a few ways to do this and it's really up to you.
these are the questions "sleazy*" has, though, in his thread if you want to read over there and perhaps even more ideas or folks with experience will contribute.
g'luck!
Old 04-15-2012, 05:52 PM   #19
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Get an usdm sti intake manifold and be done with it.
Any year will work but different years have different connections.
Old 04-15-2012, 06:23 PM   #20
jamal
Member#: 71875
98 Legacy GT
my wheels fit
keep the stock manifold and be done with it.
they work well rotated too.
jamal is offline   Reply With Quote
Old 04-15-2012, 06:46 PM   #21
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Yes they do but not with the full race reverse intake fmic kit without modification.
Old 04-15-2012, 08:51 PM   #22
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
So the composite mani is strong enough to hold high boost pressure? That was my main concern, structural integrity.
Old 04-15-2012, 08:52 PM   #23
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
What kind and how extensive of modification?
Old 06-30-2012, 02:11 AM   #24
sleazy07sti
Member#: 273116
2007 Hawkeye Sti
0bp
bump from the dead...i officially have adapters for sale in order to run the dbw tb on the jdm long runner intake manifold.shoot me a pm for prices
Swapping intake manifolds Ryan314 Newbies & FAQs 16 11-17-2009 11:54 AM
96 ej18 intake manifold -> swap to 96 ej22 manifold mxpunk Subaru Conversions 4 05-02-2007 05:18 PM
EJ20/EJ25 Intake manifold swap Really_Soaked Normally Aspirated with bolt-on Forced Induction Powertrain 3 07-25-2002 10:28 AM
butterfly valves in intake manifold? swap! Otaku64 General Community 14 02-16-2002 12:10 PM
2.5 intake manifold swap fourbanger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-23-2001 10:28 AM
