Old 10-12-2011, 02:16 AM   #76
jexeffectz
Member#: 131976
2006 18g'd WRX
CGM on Black
OKAY...so it turns out that I was leaking around the BPV. My silly self forgot to tighten down the bolts to the bpv, and while driving around, I lost a bolt which opened up the area even more. Everything is dialed in quite nicely now.
Current Settings:
Scalar = 950
Code:
6.50    9     11.5    14   16.5
3.64   2.07   1.36   0.95   0.79
Car stumbles a bit, but not as badly as before. I'm planning to drop the scalar back to 910 and increasing slowly. Any idea how to decrease startup and shift stumbles? It's not as bad as before, but it would definitely help.
jexeffectz is offline   Reply With Quote
Old 10-13-2011, 05:59 PM   #77
toneekay
Member#: 185126
2005 STI
AWDtuning feels like sex!
I noticed most of you guys are trying to tune with 1200+ cc injectors, but has anyone had any experience or issues with the 850cc side feed injectors from Five-O? I'm planning on picking up a set, but after reading around it seems like there's a lot of folks having problems with the injectors coming from them =/
toneekay is offline   Reply With Quote
Old 11-23-2011, 02:49 PM   #78
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Bumping this thread one time. I plan on picking up a set of the 850cc top feed injectors, from the factory they recommend a latency of .75ms @ 14v. Does this seem a bit low? Anyone have a base table they could send my way?
Subian is offline   Reply With Quote
Old 12-18-2011, 04:13 PM   #79
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
I have there 1600s running on stock ecu both on pump and E 85 with success
mecpgh is offline   Reply With Quote
Old 12-22-2011, 04:50 PM   #80
GravyRobber
Member#: 205568
2002 S2000
Suzuka Blue
Originally Posted by franksl47371 View Post
...What I found however is that there top feed 1000's do not fit in the manifold hole coerecly. They are not round like the stock injectors. They have 2 parts on the injectors raised up on each side where the stock ones would be a smooth circle. This causes that raised part to hit the injector hole lip on the intake mani. Therefore it will never seal in the intake with the donut gasket. And then all the air that wants can get around the seal causing it to go very lean.
My solution was to Dremel the injector to the same size as the stock ones. This fixed the leak issue and they seal just fine...
That is interesting, and the first I've heard of that. I don't suppose you have any pictures of what exactly you dremeled off? I have been pretty much set on these injectors until reading that
GravyRobber is offline   Reply With Quote
Old 12-22-2011, 05:19 PM   #81
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
would u mind throwing up a MAF tab screenshot with interpolation line on it? Im interested to see the scatter.
I havent tuned any of them yet. What scalar and latency did you end up with?
- ron
PhatBotti Tuning TKR is offline   Reply With Quote
Old 12-22-2011, 07:00 PM   #82
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
- ron
They fall off pretty bad down low both on pump and E , pump scaler 1373 E 85 1015....
stock ecu doesn't like them too much misses at idle on pump allot and few here n there on E. I'm getting ready to move next week so I really don't have time to do another maf plot
Old 01-14-2012, 04:30 PM   #83
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Originally Posted by RP31 View Post
Well, add me to the list of people with a wonky injector from Five-O.
I installed their 1200cc side-feeds, started tuning the car, and could never get a nice smooth idle. Logging the roughness monitors, cylinder #4's misfire count was through the roof at idle. Cruise and WOT were fine though. I was dealing with new injectors in a new engine with new fuel and intake systems, so I had a lot of stuff to adjust, but after ~500 miles of playing with the map, I decided the problem had to be mechanical.
Verified a lack of intake/boost and exhaust leaks, swapped coil packs, checked plugs, checked wires, etc. Finally decided to swap cylinder 2 and 4 injectors this morning and sure enough, the misfires moved to cylinder 2.
Guess I have to get in touch with Five-O.
After a second problem with these injectors that could have really cost me (Pintle cap came off of one injector, lower o-ring slipped, fuel dumping into the cylinder), I am done with Five-O. Bought the ID2000 sidefeed conversion kit and haven't looked back. Sooo much better.
Anybody want a set of 1200cc sidefeeds for cheap?
RP31 is offline   Reply With Quote
Old 01-14-2012, 11:58 PM   #84
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Sounds like their sidefeeds are not that great, how about their topfeeds?
I was going to order a set of their 1400s, I will post some logs when I get them running..
Old 01-15-2012, 12:58 AM   #85
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
It's really not their sidefeeds.....it's pretty much all sidefeeds over 1000cc. They all run like crap on pump gas.
The best solution is to do a tf conversion.
Old 01-15-2012, 10:26 AM   #86
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
I have their 1600s and there great on e85. And not so great on pump gas but still doable I recently drove a 700 mile trip with these on pump gas and got 27mpg high way with afully loaded car. Can't beat that considering there three times the size of stock injectors
Old 01-18-2012, 03:51 AM   #87
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Its nice to hear someone has got them working, hopefully 1400s are a little better on pump.
Old 02-07-2012, 09:45 PM   #88
moose00015
Member#: 180924
2007 Impreza WRX STi
2004 Forester XS Premium
I have a set of 1000cc injectors on my STi. It was tuned by Mikey from Phatbotti Tuning. I haven't had any issues other than e85 being a bitch to start when it's cold out. And the car eating gas, but that's because its hard to stay out of boost.
For the price and lack of experience with other injectors, I'd buy them again.
moose00015 is offline   Reply With Quote
Old 02-07-2012, 10:03 PM   #89
Phatron
Member#: 36033
CEO PhatBottiTuning
^^. Did u tell mike about the cold starting issues? That can be tuned out. That's not something that's specific to five-0 injectors....that's specific to e85
Old 03-27-2012, 06:20 AM   #90
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
Is anyone using these injectors on E85? What latency and flow scaling values are you using? I am having a problem with these injectors at certain throttle position AFR starts to swing from lean to rich and the car is studdering a little.
http://www.fiveomotorsport.com/denso...-fuel-injector
imppu2001wrx is offline   Reply With Quote
Old 04-06-2012, 07:57 PM   #91
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
Anybody have any Latency setting for the Denso 1400cc injectors?
My car is missing at idle pretty bad but at crusing speeds and reving up, it doesnt miss.
banshee04 is offline   Reply With Quote
Old 04-07-2012, 05:05 PM   #92
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
I've ben having the same problem with my 1600s from them. Its been on going for a while there hard to dial in.
Old 04-07-2012, 07:32 PM   #93
banshee04
Member#: 179014
'06 WRX/STi
Guess Ill just switch to E next week. Seems these injectors start acting right then.
Old 04-10-2012, 06:58 AM   #94
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
I want to bump this thread. I have been tuning a car with side feed 1200cc for the past few days. I just want to say that these injectors SUCK!. And that is putting it lightly. The fueling is all over the place at idle. The fuel corrections will be flat one minute then out of nowhere the afr will shoot rich and corrections swing wide. That may last a few seconds then back to normal for a while. But corrections still arnt what I would call acceptable.
As for idle control. SUCK! You can stop at a light and idle corrections are ok, stop at the next light and corrections will be -25. Next light they may be ok again. System voltage is stable, maf voltage is stable, map, all the data is correct and nothing to cause this behavior.
I would not recommend these injectors to any customer or client to install on there car.
fastblueufo is offline   Reply With Quote
Old 04-10-2012, 08:15 AM   #95
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Ya I see the same thing with my 1600s but it will stall its soo bad. I need to ditch them
Old 04-17-2012, 01:30 PM   #96
03aksuby
Member#: 167827
2004 STi
I have the 1600's and was having trouble with the afrs swinging from stoich to ~19 at idle and light, light throttle. Turned out I had a bad injector that was misfiring like crazy (logged roughness and it was reaching 100 at idle). Log your roughness on all 4 cylinders and if you don't see anything out of whack raise your idle and play with your tip in and you can correct the stalling issue.
03aksuby is offline   Reply With Quote
Old 04-17-2012, 04:57 PM   #97
fastblueufo
Member#: 212154
02 billet crank
Who wants to fubar the tune just to get the car to half way run decent. These injectors SUCK period. There not worth messing with. If your one of the LUCKY ones to get a set that drives decent then cudo's. But I bet the afr and trims still arnt what I would call acceptable. Considering some of the other injector options out there.
Old 04-17-2012, 05:57 PM   #98
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Yep time to ditch these cheap magnets
Old 04-17-2012, 06:18 PM   #99
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Ok, So I have had more then a few sets of these and have tuned A Lot more, I have only ran across one bad set all the others have been great fuel trims are plus or minus 3 on most
Old 04-17-2012, 06:20 PM   #100
sorrowfulkiller
Member#: 170439
I <3 Lamp
What sizes have you used mostly?
sorrowfulkiller is offline   Reply With Quote
Five O Motorsports Injectors apsdsmracer Car Part Reviews 185 02-26-2016 12:48 AM
The 2.0 vf34 that did, now a built 2.0/2.5? hta green on e85 karlknaupp Proven Power Bragging 684 06-30-2015 08:20 AM
555 Motorsports June Tuning Trip (June 19-22) Benchmark Tuning MWSOC Vendor Classifieds 35 07-14-2008 10:21 PM
555 Motorsports Chicago Tuning Trip & Dyno Day #'s Benchmark Tuning Proven Power Bragging 11 07-13-2008 01:48 PM
Primitive Motorsports/Cobb Tuning/JC Sports??? Kevin Thomas General Forum Archive 24 10-01-2000 06:54 PM
