Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 03-24-2012, 10:59 AM   #26
busyychild
Member#: 270571
Originally Posted by rkjunior View Post
This is awesome news. I want to do this to my 2011... Do you have a list of part numbers?
I bought the mirrors whole off a wrecked STi. You can find the part numbers at the top of this thread or search any online subaru parts depot.
busyychild is offline   Reply With Quote
Old 03-24-2012, 11:03 AM   #27
emazz104
Member#: 281811
04 WRX
World Rally Blue
This is going to sound dumb, but is there a way to do this on the 06? The mirrors look the same, but I'm assuming they aren't, could the new covers fit the old mirrors? Or I could get 08+ mirrors and they would bolt up?
Great writeup by the way.
emazz104 is offline   Reply With Quote
Old 03-24-2012, 11:18 AM   #28
Airplay355
Member#: 213825
2013 BRZ
If you lube up the wires/hanger it will slide through the rubber tube much more easily.
Airplay355 is offline   Reply With Quote
Old 03-24-2012, 12:42 PM   #29
Ego4sho
Member#: 314461
Wow this is actually pretty awesome! very helpful post, keep em comin!
Ego4sho is offline   Reply With Quote
Old 03-24-2012, 01:01 PM   #30
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
busyychild great info. It is quite possible that the 11+ WRX premium is wired for the turn signals. It could just be your car as well, we never did figure that out ;-) I see you found the thread on 3gWRX about the same thing. I was keeping track over there of which people had "live" signal wires from the factory (they all have the actual wires) but we found no rhyme or reason.
For instance my 09 premium WRX had dead signal wire. But fortunately it is about 5 min to make them "live" which I explain in the thread on 3gWRX. Adding heat to a base is not too bad either, the dash wiring is there and you can use some unused wiring in the door.
Now let me know when you are ready for JDM power folding, most of the wiring is there in these cars for those too ;-)
Power6 is offline   Reply With Quote
Old 03-24-2012, 07:13 PM   #31
rkjunior
Member#: 112220
2011 WRX 5DR Premium
It looks like on the STI compared to the WRX harness the only additional wires are the Green/White? Wonder which one coincides with red/black on the LED.
rkjunior is offline   Reply With Quote
Old 03-25-2012, 08:34 PM   #32
busyychild
Member#: 270571
PFM would be sweet. Ill have to look into that. Thanks man.
Old 04-08-2012, 01:29 AM   #33
gatesan3
Member#: 315607
2010 Legacy 3.6R
does anyone know how much it would cost to get them painted? Im looking into doing most of the installation myself, except I would probably try to get them painted professionally.
gatesan3 is offline   Reply With Quote
Old 04-08-2012, 02:03 AM   #34
rkjunior
Member#: 112220
Local shop did my two caps for $75
Old 04-10-2012, 10:01 AM   #35
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Time to look around for wrecked STi's to steal some mirrors. It's such a subtle change, but looks so good for some reason. The WRX mirrors just look too plain.
Thanks for confirming the STI mirrors fit and work. After reading the initial writeup, there was no way I was doing all that work haha.
dcorn is offline   Reply With Quote
Old 04-10-2012, 05:08 PM   #36
Tunguska
Member#: 316376
Subscribed Wish I would have bought a premium because this is definitely going on my "to do" list.
Tunguska is offline   Reply With Quote
Old 04-10-2012, 05:11 PM   #37
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Its not too much work to add the signals, it amounts to breaking down the mirror a bit, and adding the signal and some wiring. Saves a lot of money over buying whole STI mirrors. Junkyards price them high because they came off the STI.
I have extra signals and caps. If you get a set of non-signal mirrors and send them to me I'll convert them to signal mirrors and send them back to you, for a small fee of course. The caps I have are assorted and used so you'd have to have them painted.
Old 04-10-2012, 05:26 PM   #38
WRBear
Member#: 207171
2009 WRX
I forget what the place I went to charged. I also had the chrome piece on the trunk done, but I don't think it cost me more than $50-$60 for the caps/trunk chrome painted. You should be able to get the caps painted for no more than $50.
WRBear is offline   Reply With Quote
Old 04-10-2012, 06:17 PM   #39
rkjunior
Member#: 112220
make sure its a newer STI for donor mirrors. I bought a set from an 08 and the harness was different.
Old 04-10-2012, 11:17 PM   #40
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
The difference is heated or not heated mirrors. 08-10 STI has unheated, 11+ has heated mirrors. Heated have a 10-pin connector, non-heated have an 8-pin connector.
They are easy to re-pin to another connector housing, but if you are buying whole mirrors you'll want to get them to match whether you have heat or not.
Old 04-11-2012, 02:18 PM   #41
rkjunior
Member#: 112220
yeah, I realized that once I took the glass off the mirror. I ended up ordering a set of 2011 STI housings and I will just transfer the required parts from my WRX mirrors. I debated pulling the wires for the LEDs out of the harness and transfering them into my WRX harness but I couldn't get the damn pins out.
Old 06-14-2012, 11:50 PM   #42
Vash337
Member#: 282107
2011 wrx sedan
obsidian black
scribed
Vash337 is offline   Reply With Quote
Old 06-15-2012, 04:31 PM   #43
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
It's actually really easy once you have the right tool. I learned to do this with NiCad battery connectors way back in my RC Car days as a kid and these work just the same. Get a really small screwdriver like a 1-2mm jewelers screwdriver and you can insert that into the pin socket and use it to release the pins.
Once you get the hang of it it is very easy to do. I think that the dissassembly operation was posted in the tutorial thread over on 3gwrx.
When I converted my mirrors over and added the power folders I started with a set of STI signal mirrors (8 pin connector) and then, based on Power6 and other's wire maps, combined the power fold unit, the signals, and my own heated mirrors into one housing and ran that all back through the 10-pin connector that was already in my car.
Ogden is offline   Reply With Quote
Old 06-15-2012, 04:34 PM   #44
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
The wires on the LEDs in the STI mirrors that I bought were green and white.
Old 07-15-2012, 01:27 AM   #45
opietrials
Member#: 293167
2013 Outback 3.6R Li
Cypress Green Pearl
I recently purchased the caps and lights for my 2011 WRX premium. In the process I also found out that the mirror harness is not available separately, you have to buy the mirror assembly which comes pre-wired with the correct harness. This leaves you three options: splice into the wires that you need and put small female spade terminals on the other end to plug into the lights, or buy the mirror assembly with the wiring already there, or try to add the pins needed to the current mirror harness plug and find the correct plug for the indicator light.
opietrials is offline   Reply With Quote
Old 07-15-2012, 12:23 PM   #46
rkjunior
Member#: 112220
You're better off just adding the wires to the plug. I wish I did this route rather than buy whole mirrors - it would have saved some money and it's not that hard to do.
Old 09-02-2012, 04:01 PM   #47
dstorm
Member#: 329237
2013 WRX
CBS
I'm wanting to do this to my incoming 13 limited hatch. If I'm understanding correctly, there's a chance that the existing harness will come prewired. Sound right?
dstorm is offline   Reply With Quote
Old 11-18-2012, 10:36 AM   #48
Pearldrummer7
Member#: 277514
2012 WRX & 818R
I think that's everyone's agreed guess on it, thought I'm not sure if anyone has reported back saying they are/aren't.
If you find out, definitely let us know! I'm interested in doing this to my '12 Premium (even if I need to wire it myself; I'm a Electrical Engy so it shouldn't be much if an issue!)
Pearldrummer7 is offline   Reply With Quote
Old 12-14-2012, 11:27 PM   #49
SGMSTI
Member#: 123219
2006 STI
SGM
I see everyone is putting these on the premium wrx what about the base wrx will it be the same
SGMSTI is offline   Reply With Quote
Old 12-14-2012, 11:46 PM   #50
BoDacious
Member#: 190110
Would it be plug and play for a 2011 wrx if i just purchased the harness for the mirrors? I want to avoid tapping into any other wires.
BoDacious is offline   Reply With Quote
08 sti sway bars on a 03 wrx??? cibon7 Brakes, Steering & Suspension 1 01-17-2010 03:17 PM
08+ STi mirrors on WRX and base model. No_Brakes23 Interior & Exterior Modification 2 08-07-2009 10:17 PM
08 STI suspension fit on 08 WRX? Caobay Brakes, Steering & Suspension 5 04-17-2009 09:08 AM
08 sti mirrors on 08 WRX??? digital-monk1 Impreza Forum 3 09-14-2008 08:34 AM
08 sti mirrors on 08 WRX??? digital-monk1 Interior & Exterior Modification 2 08-21-2008 06:24 PM
