Old 04-08-2012, 01:40 PM   #1
BerGaur
Member#: 289924
1999 Legacy Outback
Green
Default A Head Gasket Sealant by Subaru?
Have a Subaru with a bad head gasket, and not a lot of money or time. My father in law said that he found out about some head gasket sealant that is put out by Subaru. I find this very hard to believe. Maybe there is one they recommend...I would guess blue devil if that is the case. But as usual, he doesn't know a lot about it being that he heard it from a friend, a reliable friend, but still second hand. The problem I have is that they are not open today so I can't go there asking questions about it.
So, do they have one? Or was my father in law mistaken?
BerGaur is offline   Reply With Quote
Old 04-08-2012, 07:03 PM   #2
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Yes they have it It is in a blue bottle called Subaru coolant conditioner, but if the headgasket is already gone, it is a waste of money. It is more of a preventive measure.
blackfang is offline   Reply With Quote
Old 04-09-2012, 07:27 PM   #3
doa
Member#: 309039
2004 subaru wrx
I would not put that in your cooling system if I were you. If a problem exists you might as well fix it the right way, putting in that conditioner is only going to do more bad then good.
doa is offline   Reply With Quote
Old 04-09-2012, 07:34 PM   #4
blackfang
Member#: 131347
2007 Legacy 2.5i SE
The Subaru coolant conditioner is ok to use in your coolant system as it is required by Subaru. However, it will not address a blown headgasket or one leaking oil.
Old 04-09-2012, 08:18 PM   #5
BerGaur
Member#: 289924
1999 Legacy Outback
Green
Default Thank you for all your help
Old 04-11-2012, 09:13 AM   #6
rkramer
Member#: 118209
2015 WRX Limitec
some head gasket sealants DO work, but are never a permanent repair. Its more of a stopgap to allow you to enough time to trade the car in to a dealer for a new one... (I have no problem trading in a $1000 car with a blown head gasket to a dealer, but I'd never sell one like that outright to an individual without disclosing it.)
rkramer is offline   Reply With Quote
Old 04-11-2012, 05:55 PM   #7
mikeythejew
Member#: 141672
I'm a former Honda dealer mechanic before working my way to becoming a UPS diesel semi mech. We used block sealer as a last resort a few times at the dealer. It was for unfortunate customers who couldn't afford a proper repair on low value cars. Surprisingly, it worked. if you don't drain the coolant and use water, don't bother. You cant paint outside in the rain, so dump your coolant and do it right.
mikeythejew is offline   Reply With Quote
Old 03-10-2015, 10:52 PM   #8
fundamentalsurf
Member#: 415509
Even though using a head gasket sealer is a bandaid, which one is the best? there's one with Steel in its name. There's one with Blue something? Any luck or experience, anybody.
fundamentalsurf is offline   Reply With Quote
Old 03-11-2015, 08:12 PM   #9
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
there is one made by bars leak. its head gasket sealer. i used it in my parents old beater. it isnt worth doing the headgasket on their car. it fixed the leak for about 10 months. its starting to leak a bit again lately. here it is. like some have said, its not gonna last forever.
http://www.ebay.com/itm/like/3313097...lpid=82&chn=ps
Should I apply gasket sealant on intake manifold gasket? gopsu Newbies & FAQs 0 07-30-2009 11:54 PM
Bad Head Gasket on '03 Subaru Legacy? paulkrueger Newbies & FAQs 3 10-01-2007 10:18 PM
Can I use Liquid Gasket Sealant on OEM Gaskets? nerdydorkus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-24-2007 03:13 PM
Head gasket sealant redwagon Service & Maintenance 7 09-22-2005 10:14 PM
head gasket sealant longevity tcmo Normally Aspirated Powertrain 2 12-29-2004 11:11 AM
