Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 04-08-2012, 02:11 AM   #1
05lgt
Member#: 183415
2005 LGT
Default Buying a used 91 loyale awd, suspention q's
Ive searched for my answer for a while. So as the title states, im going to pick up a decent shape loyale with 150000k on her. And when the repairs start theres just a tune up and oil leak fix, then the worn suspention in that order.
Is there a wrx/legacy strut, sway bar, spring combo that will make things a bit more stable to drive? Such as lane changes and sudden braking situations and the like.
If I lower it about an inch id be happy with that. Its not going to see more than maintained dirt roads on a rare occasion any way.
Thanks for any info! Kris
05lgt is offline   Reply With Quote
Old 04-08-2012, 02:22 AM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
I tried to find you a thread, but its late and I need to go to bed... but look up 5 lug swap on here: http://www.ultimatesubaru.org/forum/ and you will likely either find parts for sale, or how to do the conversion on your car.
Flowmastered87GL is offline   Reply With Quote
Old 04-08-2012, 01:41 PM   #3
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
Try looking for some KYB AGX shocks for it.
Best way to beef it up without doing the swap.
TurboneX is offline   Reply With Quote
Old 04-08-2012, 02:04 PM   #4
05lgt
Member#: 183415
2005 LGT
I was considering that shock set up, then came across this 5 lug swap. Main reason I want to do this is to fit a set of 98 gt 16" snowflakes on it, along with some sway bars. Im still reading up on what subaru to remove these parts from. ill be dumpster diving at a local junk yard this coming wknd cause I spotted a 1st gen legacy there and they have the 5x100mm pattern I need.
Any body confirm this? Taking lots of pics and measurements with me also....
Kris
Old 04-09-2012, 10:50 AM   #5
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
The 2 major parts and hardest to find are the lower control arms and rear backing plates(XT6). There are ways to get around this tho. You can redrill the lower control arm ball joint hole to accept the EJ knuckle. For the rear you can use a EJ backing plate but you will need to fab and weld a plate to get it to fit on the EA hub. More searching over at USMB should get results for you.
Old 04-11-2012, 01:04 AM   #6
05lgt
Member#: 183415
2005 LGT
I found alot of really cool s##t in those links I can read up on. Thank you. Now I need the front windshield replaced soon and of course I want to know if there are models that share the same glass...
Old 04-12-2012, 12:15 AM   #7
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Pretty much an 85+ GL should fit.... but be warned sometimes parts places can pull the wrong part because the 2nd gen cars overlapped with the 3rd gen cars. Yours is 3rd gen.
Need more power for my 91 loyale pirate 'Old School' Subaru Forum 2 11-24-2004 04:04 PM
91 Loyale flasher steelerfan 'Old School' Subaru Forum 5 03-01-2004 01:02 AM
91 Loyale Western NC parts or fixup driver deadbolt Private Vehicle 'For Sale' Classifieds 3 01-25-2004 01:29 PM
91 Loyale wagon- is this normal? mikekaser Transmission (AT/MT) & Driveline 2 10-29-2003 05:56 PM
Looking at a 91 Loyale - any tips? drew510 North West Impreza Club Forum -- NWIC 5 10-29-2003 03:33 AM
