Old 04-11-2012, 10:19 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default 2011 WRX | Blouch 20G XT-R | 462 WHP / 492 WTQ
Event: Dyno Pull
Ambient Temp: 55F Outside, ~70F Inside
Elevation: ~1,000ft
Weather: Sunny and Cool Outside
Tires: Dunlop Start Spec 255/40R17
Car: 2011 WRX Hatch
Tuner: Nuke @ NF Performance
Dyno Info: Dynojet
Transmission: Stock 5 Speed
Gear: 3rd
Peak HP at RPM: 462 WHP @ 5,850 RPM
Peak Torque at RPM: 492 WTQ @ 4,650 RPM
Baseline hp/tq for a stock on same dyno: ~240WHP Stock
Target Boost: 27psi Peak to ~25psi Redline
Target AFR: High 11's to 12.0
Fuel: E85
Engine/Power Modifications:
  • STI Crank Balanced
  • STI Rods Balanced
  • Coated JE Billet Pistons
  • TGV Deletes
  • Stock Heads
Intake/Exhaust/Fuel:
  • Blouch 20G XT-R Turbo
  • Invidia Catless Downpipe
  • Stock Cat Back Exhaust
  • Tial MV-R 44mm EWG
  • KSTech 73mm Intake
  • AMR 3" Hard Inlet
  • FMS FMIC
  • GrimmSpeed MBC
  • Walbro 255 Fuel Pump
  • FiveO Motorsports 1200cc Injectors
Driveline Modifications:
  • ACT HD Pressure Plate
  • ACT Sprung 4 Puck Disc
  • ACT Street Light Flywheel
Suspension Modifications: BC Coilovers
Other Modifications: Mach V 17x9" Wheels
More info on the car here:
http://forums.nasioc.com/forums/show....php?t=2078765
Here is the plot:
Here are the numbers from all 3 pulls.
  • 468WHP / 498WTQ @ 27.6psi
  • 462WHP / 492WTQ @ 28.0psi
  • 463WHP / 494WTQ @ 27.4psi
Here's the dyno video:
462 WHP / 492 WTQ
Sorry, I don't have the dyno plot yet. Torque is above 400ft-lb's between 4,000rpm's and 6,000rpm's, and power is above 400hp from 4,400rpm's to redline (7,100rpm's). Boost hits 20psi at 3,750rpm's. Enjoy!
EDIT:
Here's a quick video of me running through the gears.
It takes 4.42seconds to go from 50-100mph according to the video.
Old 04-11-2012, 11:04 PM   #2
WRrexu
Member#: 217061
2009 Wrx
How are you making so much more power since the orig e85 20g tune?
WRrexu is offline   Reply With Quote
Old 04-11-2012, 11:12 PM   #3
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
More boost? Different dyno? Both?
Old 04-11-2012, 11:44 PM   #4
mark richardson
Member#: 296997
2008 wrx
white
Nice numbers!
mark richardson is offline   Reply With Quote
Old 04-12-2012, 02:30 AM   #5
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Yuuuuuppppppppp! Awesome TRQ in 3rd
Kastley85891 is offline   Reply With Quote
Old 04-12-2012, 04:55 AM   #6
NoGraffix
Member#: 276209
I am Rub
Function>Form
you must not be worried about your trans at all
also any reason your whole engine shakes once you hit the end of the pull? Almost makes me think you have some broken mounts or something. I mean I know that's a good amount of power but I don't think I've seen an engine move so violently after a pull as in the video.
When you get a chance can you post a log for VD/airboy running purposes. This thing must be insane to drive and really streetable with 20psi of boosting coming on by 3700rpm. I'm really surprised you aren't worried about the trans going though. Also which clutch are you using?
NoGraffix is offline   Reply With Quote
Old 04-12-2012, 07:32 AM   #7
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
Very very impressive!
07VTRex is offline   Reply With Quote
Old 04-12-2012, 07:58 AM   #8
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by mark richardson View Post
Nice numbers!
Thanks!
Yeah, it's a lot of fun!
Yeah, I'm sure the trans is probably about to go any minute. The clutch is in the original post, but it's an ACT setup with HD pressure plate, sprung 4 puck disc, and streetlight flywheel. I really wanted to stay with something less aggressive, but it just wouldn't hold the torque.
When we swapped the motor a little while ago the mounts looked fine. They should have been replaced, but I didn't have anything on hand and I needed a car, so it just went back together as-is. I think it's just the flimsy stock mounts causing it to flop around.
I plotted a pull from after the swap and it did 440WHP/460WTQ in Airboy and about 500/500 in Virtual Dyno, Dynojet setting. This definitely seemed high, but it did it 3 logs in a row. I talked to the creator of VD and he said that the fast polling in RomRaider was causing spikes and throwing off the numbers.
Airboy seems to handle fast polling "better", but it still does things differently, because the plots look way different than the older (non fast polling) logs. I think the main issue is the random/inconsistent data and data rates that RomRaider outputs with fast polling turned on.
Thanks!
Old 04-12-2012, 08:09 AM   #9
bilt2run
Member#: 134211
graph please!!
bilt2run is offline   Reply With Quote
Old 04-12-2012, 09:39 AM   #10
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
if you are making 440whp on Airboy you are making 500whp on a dynojet. How much timing are you running? It must a lot. When are you going to the track?
Congrats it should be a mid 120mph car depending on the weight
Old 04-12-2012, 09:49 AM   #11
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'll let Nuke comment on timing if he wants. The car isn't meant to be a 1/4 mile car, but I would like to run at least once to see what it does. It will likely be full weight (curb weight is 3200lbs for this car). I'm hoping to be in the 120's trap speed.
Old 04-12-2012, 09:52 AM   #12
Nuke209
Member#: 108089
2003 WRX
NF Performance
Hm....is pk tq 15* too much?
Nuke209 is offline   Reply With Quote
Old 04-12-2012, 09:58 AM   #13
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
He's running a lot of boost, hence the torque. I have a buddy with similar numbers at around 24-25lbs, we just ran more timing.
907Bum is offline   Reply With Quote
Old 04-12-2012, 10:00 AM   #14
kijones
Member#: 241720
2007 STi
Urban Grey
awesome #'s!!! I'm just wrapping up a 20GXT-R swap in my 07 STI and now i really cant wait!
kijones is offline   Reply With Quote
Old 04-12-2012, 10:03 AM   #15
juanmedina
Member#: 133146
No it is not, how about up top 26*, 30*?
Old 04-12-2012, 10:09 AM   #16
Nuke209
Member#: 108089
2003 WRX
NF Performance
wow, i have never ran 30*
26 is alot also
Old 04-12-2012, 10:20 AM   #17
juanmedina
Member#: 133146
26 is alot also
I did with my green lol. I run 19-20* on my black
Old 04-12-2012, 10:22 AM   #18
Nuke209
Member#: 108089
2003 WRX
NF Performance
i'm about max 22* on this one.
i'm not too big into cramming timing into it...can do alot of damage
Old 04-12-2012, 11:19 AM   #19
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Maybe we should just do 40 degrees and see what happens.
Old 04-12-2012, 12:39 PM   #20
juanmedina
Member#: 133146
This 1/4th of mile calcualtor is quite accurate when using VD numbers according to EVOM:
http://vexer.com/automotive-tools/1-...MPH-calculator
Enjoy
Old 04-12-2012, 12:46 PM   #21
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Enjoy
Looks fun. I used my actual Dynojet number (462WHP) with a 10% loss (as noted at the bottom of the webpage) and entered 511HP. I figured curb weight + 200lbs and used 3400lbs. This gave me about 11 flat at 124-125! I'd be really impressed if I could do that, lol.
Old 04-12-2012, 01:23 PM   #22
Delphi
Member#: 239335
I want to see how long this trans lasts. Pretty good testament to how much stronger the 08+ 5 speeds are. Pretty sure if this was an 07 wrx drive train it would have popped on the dyno.
Awesome car Xluben, been following your car since day one and you make me want to spend so much money on mine
Delphi is offline   Reply With Quote
Old 04-12-2012, 04:19 PM   #23
stalkerz
Member#: 242207
You don't need an upgraded MAP sensor for 25-27psi boost?
stalkerz is offline   Reply With Quote
Old 04-12-2012, 04:43 PM   #24
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
26* - 30* is for pussys ;-) lol
OP 15* is safe - made his power with boost.. nice
Old 04-12-2012, 05:21 PM   #25
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Eh. It will probably break soon. I do agree the older ones seem even more fragile.
Yes. I have one.
http://forums.nasioc.com/forums/show....php?t=2310334
Boost is fun. I like torque.
FP Green vs. Blouch 20g xt-r fbi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 11-28-2011 10:56 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket SCIC Private Classifieds 1 02-08-2007 12:02 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket Private Vehicle 'For Sale' Classifieds 2 02-08-2007 12:01 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket SCIC Private Classifieds 31 02-07-2007 01:01 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket Private Vehicle 'For Sale' Classifieds 32 02-07-2007 01:00 AM
