Old 04-05-2012, 08:50 PM   #1
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Default Boost Issue While Tuning
I've been working on tuning my 2002 wrx ej205 motor with vf43, sti tmic, dw650cc injectors, spt intake, perrin hard inlet pipe, up & down pipes, 3" exhaust and Grimmspeed electronic boost control solenoid.
The issue I'm running into is that when running 80% duty cycle on the boost control solenoid, I'm only hitting 12.5 psi. Why would I be underboosting like this? I should be running more like 17 psi at 65% duty cycle, so I'm told. Any input?
Soarer is offline   Reply With Quote
Old 04-06-2012, 10:43 AM   #2
AREA1320
Member#: 112508
Boost leaks?
AREA1320 is offline   Reply With Quote
Old 04-09-2012, 05:12 PM   #3
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Originally Posted by AREA1320 View Post
Boost leaks?
Nope, no leaks. In my experience, if there was a boost leak, it would be pretty obvious. Also, upon reverting to an older map, the boost levels went back up.
Old 04-10-2012, 12:53 PM   #4
LTM87
Member#: 307759
2004 Impreza WRX
Do you have a log available that we could look at?
LTM87 is offline   Reply With Quote
Old 04-10-2012, 01:29 PM   #5
wrxkid2003
Member#: 228945
There is a lot that could cause this a log and you map ,if you can share it, would me big help.
wrxkid2003 is offline   Reply With Quote
Old 04-10-2012, 02:05 PM   #6
Dartholomew
Member#: 208771
2009 WRX
When you're saying your running 80% vs. 60% wgdc, are these from your logs or what you have set as targets in your map?
If you have no leaks, and boost levels return to normal with another map, then it could be in your tables, no? Easiest thing to do may be to run a map compare and see if you've got adjustments or scalings in your target boost, turbo dynamics, or other compensation tables that would affect your maximum boost.
Dartholomew is offline   Reply With Quote
Old 04-12-2012, 01:08 PM   #7
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Got this sorted out. It turns out that the tuning software for some reason was running the atmospheric adjustments. We had turned this off but for some strange reason on the 10th reflash, it turned them back on. Once we clicked them off, it started working as it should.
Issues while having sex linux>windows Off-Topic 39 08-19-2013 07:18 PM
Having issues while going under boost.. BoostedGuy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-24-2011 08:18 AM
Mechanical Issue or Tuning Issue? (Bucking/Hiccups) MConte05 Open Source Reflashes 6 06-30-2009 12:51 PM
Interesting issue while tuneing. (odd rev limit issue at 5500-6k) DoctorNick Commercial ECU Reflashes 4 05-12-2007 08:53 PM
Boost issues or Gauge Issues? IwantONE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-12-2006 05:18 PM
