Old 04-09-2012, 10:15 PM   #1
maverick83
Member#: 309577
Default Boost targets on STI 2011
Hello,
I have some questions regarding the tune of my EDM STI 2011 MT (de-cat 70mm turbo back exhaust and prodrive EBCS):
- is there a particular way to start tuning the target boost map? Shall I change only from 350 raw ecu value column on,or is better to start from the first column?
- somebody has got definitions for my car in order to let ECUFLASH work with it? So far I'm just using RomRaider.
- Any change in the CL/OL Transition tables is requested to improve the safety of the engine?
Thank you!
maverick83 is offline   Reply With Quote
Old 04-10-2012, 12:05 PM   #2
dux10
Member#: 235338
2002 Faggin Wagon
srp
have you checked Rom Raider for definitions?
dux10 is offline   Reply With Quote
Old 04-10-2012, 08:41 PM   #3
maverick83
Member#: 309577
Yes,I've downloaded both the def for the STI 2011 and the new 32BITBASE but when I click on a map appears that is not possible to show the map etc.
I can see all the maps but they are greyed out...
Old 04-11-2012, 08:05 AM   #4
quazimoto
Member#: 70395
You need to set the user level. Please read all of the FAQ's at the top of the page on here and Romraider.
Old 04-11-2012, 01:30 PM   #5
maverick83
Member#: 309577
I've done everything as said in Romraider forum and I've set the user level to developer but nothing changes...
Old 04-13-2012, 11:03 AM   #6
throttlehappy
Member#: 313497
2016 STi FA20DiT
Yellow
Your EcuFlash table is for uploading/downloading the ROM only.
RomRaider does the editing
Which ROM ID do you have? AZ1G500G ir something?
throttlehappy is offline   Reply With Quote
20G Boost targets for STI? niemkij AccessPort 0 10-22-2008 06:50 PM
Boost Control on STi UTEC? SupraScooby Engine Management & Tuning 5 08-15-2005 10:00 AM
Acceptable Boost Levels on STi Motor artdoesart Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-30-2004 09:09 AM
TXS boost controller on STi vf39hipsi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-06-2004 06:57 AM
Another idea to combat boost creep on STi... Evil STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-05-2004 01:32 AM
