Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 01-12-2012, 06:14 PM   #26
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
good work guys!
All4bSpinnin is offline   Reply With Quote
Old 01-14-2012, 01:59 PM   #27
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Here is an updated schematic of the circuit I built. The circuit gets its 5V power from the USB cable. My 555 timer wasn't stable because I hadn't tied the RESET line to Vcc initially. After I did that everything worked fine.
Noah is offline   Reply With Quote
Old 01-18-2012, 01:59 PM   #28
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i love progress
Old 01-18-2012, 08:19 PM   #29
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Pulled it off my prototype board and got it on a real board this weekend.
Old 02-14-2012, 08:18 AM   #30
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Well since everybody seems to like to show off their ECU Recovery antics I'm going to post my version as well
I built it for ECU Recovery since there seems to be nobody in Asia being able to do it and sending ECUs back and forth to Tactrix became a bit of a problem due to the time involved. However thumbs up for Tactrix for this service which they offer really cheap!
2nd reason I wanted this was mainly to be able to wipe ECUTek completely off of the ECU for a lot of our customers which have complained about the lack of service and poor performance/drivability.
ECUTek dealers/tuners do not take this personal as I'm sure many of you are doing a proper job, however that seems not quite the case over here. I kinda lost track of all the blown engines I had my hands on after having been graced with an ECUTek tune. Nuff said!
I decided to make a bit out of an artwork out of it and wanted it to be very neat.
This is the Top side:
Very clean as I wanted it to be!
This is the Bottom side:
As you can see I have done component placement in such a way that the interconnections are as short as possible. For connections that are further away I use very nice 30 AWG Teflon wire which is perfect to keep all very neat.
This is the ECU Recovery board connected to my EDM MY06 WRX ECU:
I used Raychem Spec-55 Wire to make the connections as it's my wire of choice! I make all my Motorsport looms with this wire. It's very light and can withstand temperatures of 200*C continuous and 400*C short burst. It's a tad expensive though
Last but not least a test of the Watchdog Signal made with my Tektronix oscilloscope:
I have tried to Recover the ECU (although it wasn't broken but wanted to test it) and it worked perfectly. I used ECUFlash to do the recovery and did not find any problems like the others described. It might be due to the fact that my Microcontroller is a SH7058 instead of a SH7055 but I'm not sure.
Anyways needless to say it all worked a charm!
If anybody is interested send me an email
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
jkopinga is offline   Reply With Quote
Old 02-16-2012, 08:00 PM   #31
Franko
Member#: 193628
2010 STI
SSM
Its so awesome to see people are being helped with my setup!
Awesome!
Franko is offline   Reply With Quote
Old 02-17-2012, 03:35 AM   #32
Xtreme.
Member#: 292380
Nice technical work guys! EE FTW!
Xtreme. is offline   Reply With Quote
Old 04-12-2012, 05:30 PM   #33
toxin
Member#: 51259
2007 WRX
СGM
Does any of you guys have ECU test pad schematic for '07 WRX?
Looks like in the picture
the Watchdog timer wire goes to the P427, not to the P407 as it shown above for '05 WRX.
Can anyone share the diagram, how to hook up '07 ECU to the Shboot circuit?
Thanks.
toxin is offline   Reply With Quote
Old 04-13-2012, 11:30 AM   #34
toxin
Member#: 51259
2007 WRX
СGM
Franko, thanks for sharing this. Great job.
Are there any tricks in installing the USB driver for the DLP chip?
I' trying to flash the ROM but the Renesas toolkit won't communicate with the COM port.
Windows set up the driver automatically whithout reporting any issues.
Any advice will be highly appreciated.
Old 04-13-2012, 01:16 PM   #35
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
As far as the drivers go, you can get them from http://www.ftdichip.com/FTDrivers.htm but when you plug the USB cable into your computer, it should show up under your Device Manager as a COM port. When you setup the Renesas flash developement software you select the proper COM port and then continue with your flashing.
After you get that set you should see this.
If you're still having problems post some screen shots of the error you're getting.
Old 04-13-2012, 07:21 PM   #36
toxin
Member#: 51259
2007 WRX
СGM
Here's a screenshot and log what I got:
Code:
OS: Windows Vista/Server 2008 [Non-Admin]
FCF Settings Applied: SH/7058F, (C:\Program Files\Renesas\FDT4.08\kernels\ProtC\7058\Renesas\1_0_00\)
FDT API initialised: version 4, 08, 01, 001
Clock Frequency (External) = 10.0000MHz, Clock Mode = 0, CKM = 4, and CKP = 2
Connecting to device 'SH/7058F' on 'COM9'
Configuration:
'BOOT Mode' connection - using emulated interface
Opening port 'COM9' ...
Loading Comms DLL
Loaded Comms DLL
Initiating BOOT SCI sequence
Sending inquiry for getting line size
Error No 15005: 'COM9' read time out
Error No 15019: Download() failed
Configuration:
Loading Comms DLL
Loaded Comms DLL
Any advice how to resolve an issue will be highly appreciated.
Old 04-13-2012, 07:28 PM   #37
toxin
Member#: 51259
2007 WRX
СGM
I tried to choose an "Advanced messaging" option, and here's what I got:
Code:
Configuration:
Loading Comms DLL
Loaded Comms DLL
Attempting 9600
Received immediate response from device: 0xE6
Detected generic boot device
Old 04-13-2012, 07:34 PM   #38
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
It seems that it is connecting but then timing out. Are you able to measure the output of your watchdog timer?
Attempting 9600
Old 04-13-2012, 07:36 PM   #39
toxin
Member#: 51259
2007 WRX
СGM
Attempting 9600
Unfortunately, I don't have a scope
Old 04-13-2012, 07:37 PM   #40
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Ok, well is the Reset pin on the timer tied to +5V Vcc?
Old 04-13-2012, 07:40 PM   #41
toxin
Member#: 51259
2007 WRX
СGM
Yes, pin 4 is tied to Vcc
Old 04-13-2012, 07:51 PM   #42
toxin
Member#: 51259
2007 WRX
СGM
What I see in the successful logs that after the line "Received immediate response from device:...." the DTK is saying something about using micro-kernel.
My logs show "Detected generic boot device" line instead
Does that mean that the DTK communicates with the DLP chip, but can't go any further to the ECU?
Thanks.
Old 04-13-2012, 08:24 PM   #43
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Well I'm not entirely familiar with the software and flash process, but when it flashed mine that was the next thing in the process. When I initially built the circuit I had issues with my watchdog timer circuit resetting itself and not sending out the proper signal. I don't have the log files at my disposal currently, but it would connect briefly and then time out and give me errors. I wish I had an ECU at my disposal right now to see if I can replicate your issue, but I don't.
Code:
Opening port 'COM2' ...
Loading Comms DLL
Loaded Comms DLL
Attempting 9600
Received immediate response from device: 0xAA
Using micro-Kernel : 'C:\Program Files (x86)\Renesas\FDT4.08\kernels\ProtB\7055\Renesas\1_0_00\uGen7055r.cde'
Downloading and verifying micro kernel...
Device is erasing...
Erase Timeout value set to 21 seconds
Erase Successful
micro-Kernel download successful
Old 04-14-2012, 02:20 AM   #44
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
I found some info on that error code you're getting.
Old 04-16-2012, 02:24 PM   #45
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
good work. Not for the faint of heart, but I guess if it's already bricked what's the harm???
medamullet is offline   Reply With Quote
Old 04-16-2012, 08:24 PM   #46
izergfx
Member#: 308012
C# & Java Devs***
PM me***
Also, according to the SH7058 manual, the H'E6 response is from the ECU, and represents a successful bit-rate-adjustment sequence.
izergfx is offline   Reply With Quote
Old 04-17-2012, 10:39 AM   #47
toxin
Member#: 51259
2007 WRX
СGM
What's the voltage reading of the WDT should be?
Thanks.
Old 04-17-2012, 01:46 PM   #48
Izero
Member#: 121332
2004 STi
Platinum Silver Metallic
this should be set as a sticky!
Great write-up!
Izero is offline   Reply With Quote
Old 04-17-2012, 04:53 PM   #49
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Thanks.
The voltage will vary between 0 and 5 volts, but you won't be able to read that on just a multimeter.
Also, I noticed the ECU layout is different than the 04 and 05 STI ECU's that I have unbricked. Could you take a high resolution of the test pad side of it?
Old 04-18-2012, 07:53 AM   #50
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
The TESTPADS have the same numbers for all ECUs I have seen so far. That means the pads listed that should be used MUST be used. There are more pads but they are for other purposes.
I believe the 07 ECU is exactly the same as the 06 ECU. I'll check whether I still have a Hi-Res picture of the testpads somewhere on my PC. If I do I will post it up.
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
How to remove an ecu Quackyboy Newbies & FAQs 9 04-22-2010 09:26 AM
How to Make an STI Look Like a Sleeper? FostersAFB General Community 88 10-20-2004 09:29 PM
How bad is it on the tranny to treat an auto like a manual? thrillho Transmission (AT/MT) & Driveline 8 06-07-2004 08:23 AM
Want to learn how to tune an ECU...and actually do it on a real dyno? 2000vfr800 Engine Management & Tuning 9 03-19-2003 02:20 PM
How long for an ECU to reset w/ no flash? Keith99RS New England Impreza Club Forum -- NESIC 0 08-22-2002 03:28 PM
