Old 04-14-2012, 01:47 AM   #851
sc00by4life
Member#: 97135
Originally Posted by The Tall Man View Post
UPS just dropped off a set of flat black XXR 518's and Nexen tires a couple of days ago for my new 2012 satin white pearl WRX.
(as you know)
The stock tires are 25.3" in diameter.
The stock wheels are 17"x8" / 53 offset.
My XXR 518's are 18x8.5 / 48 offset.
My Nexen's are 255/35-18 with a diameter of 25". Since I chose some 18x8.5's, and not 18x9's, my 255's should creep up even closer to the to the stock 25.3" diameter. I wanted to keep the extra weight at a minimal, not throw off my speedo hardly at all, and not go over the stock height which would slightly slow my car down with a larger diameter.
I am still going to have my 2 rear fenders rolled next weekend because I still may add a couple of 1/2" spacers in the rear at a later time.
I feel I picked out some good numbers.
stretch effects tire diameter very little....wheel width doesn't make the tire taller or shorter.
I wouldn't add any spacers in the rear, if anything - do it in the front.
Old 04-14-2012, 02:26 AM   #852
The Tall Man
Member#: 316804
12 WRX/89 Conquest
TSI / 15 Viper TA 2.0
I suppose this isn't a fair comparison, but back in the late 80's, I put some Mickey Thompson 33x14.5" tires on some 15x8" wheels. Just few months later I decided to go wider with some 15x12's... I lost some tire height by going 4" wider on those wheels.
Really, in front? I was thinking another 1/2" would go well with those beautiful looking rear fenders.
I'm going stage 2 next weekend, so should I have been so concerned over wheel weight issues? I could always scrap the spacer idea and order a couple of 18x9.5's & 265/35-18's for the rear to achive the staggered look (at a later date). Also, how would the AWD WRX do on 2 different size wheels?
The Tall Man is offline   Reply With Quote
Old 04-14-2012, 02:39 AM   #853
sc00by4life
Member#: 97135
adding spacers to the rear will add to the understeer you already have to battle with our cars. adding spacers to the front will help turn-in response.
staggered on awd is bad.
Old 04-14-2012, 09:51 AM   #854
The Tall Man
Member#: 316804
12 WRX/89 Conquest
Thank you.
Old 04-14-2012, 05:28 PM   #855
compy_rex
Member#: 282100
2002 Impreza WRX
OBP front, PSM rear lol
year:2002
model: WRX Sedan
wheel model: Konig Runaway's
wheel size/offset: 17x8 +35
tire brand/model: open to suggestions
tire size: open to suggestions
suspension: Stock
alignment: Stock
fender mods: none
will be DD
New to the scene, did some research but nearly everything i saw was for 17x9 or 17x7.5 or 18x7 or somesuch. Wanted some input on what size tire i should get and what modifications i should make (fender or suspension). I already have the rims, car is sitting on stock 02 wheels (road rashed and curbed to hell from previous owner). i want to make these wheels work with my car, so im open to suggestions regarding necessary mods.
also for the future, thinking of getting epic springs or rce blacks on tokicos, so i will be lowering it a bit. thanks for any opinions!
compy_rex is offline   Reply With Quote
Old 04-14-2012, 08:38 PM   #856
rob1n1
Member#: 276425
2013 335is
Alpine White
year: 2007
model: WRX sedan
wheel model: Rota G-Force
wheel size/offset: 18x9 +35
suspension: stock struts w/ Swift Sport springs
alignment: stock range ATM, will go more negative if necessary
fender mods: none yet, will roll rears if necessary
spacers: yes/no? size? no
Tire and tire size is up in the air... guess I'm looking for a tire size that will work with my setup but not do anything weird (poke/stretch/whatever).
Also, struts may be replaced by Koni yellows or KYB AGX's, does this change anything regarding fitment from stock struts?
Old 04-15-2012, 08:30 AM   #857
bassalone
Member#: 302806
Default oops, wrong rims
i bought some forester rims w/ tires (215 60 r16) for my '97 outback sport and they dont fit!
everything is stock and i'd like to keep it that way. any advice?
bassalone is offline   Reply With Quote
Old 04-15-2012, 10:04 PM   #858
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
Will this work on a 02 wrx sedan without spacers? I want it to be as close to the outside as possible. The car is lowered on eibach springs.
17x8 +45 with 225/45s
dburgoon is offline   Reply With Quote
Old 04-15-2012, 10:07 PM   #859
roxtc
Member#: 286077
I have a 2011 Impreza 2.5i Hatch. Was wondering if there'd be any problems putting on a set of Enkei Lusso 18x7.5 5x100 42 offset.
roxtc is offline   Reply With Quote
Old 04-16-2012, 01:43 AM   #860
izzynuff
Member#: 310400
2005 Impreza WRX
SRRed
year: 05
model: wrx
wheel model: Rota G-force
tire brand/model: BFGoodrich g-Force T/A KDW NT
tire size: 235 40/18
suspension: Tein S-tech, rubs a ton putting BC BR coils on this weekend
alignment: Stock right now, might put some negative camber in the back
fender mods: rolled
spacers: no
izzynuff is offline   Reply With Quote
Old 04-16-2012, 01:51 AM   #861
izzynuff
Member#: 310400
2005 Impreza WRX
SRRed
Check my set up and pictures I just posted above, I have 235's and rear fenders rolled. It rubs real bad around corners and alot if there is weight in the back with just my lowering springs so you are gonna need to put coils on or just not have it as low as mine. I'm putting bc br coils on this weekend and rear fenders rolled is a must. I might do a little negative camber in the rear as well
Old 04-16-2012, 02:24 PM   #862
sc00by4life
Member#: 97135
year: 2007
model: WRX sedan
You will need to roll front and rears, as well as additional camber adjustment in the rear.
Old 04-16-2012, 03:32 PM   #863
rob1n1
Member#: 276425
2013 335is
Alpine White
Ok, that's pretty much what I expected. Would it be pretty extreme camber in the back, or still within sane limits?
Also, what are my options for tire size if I want to go normal (no poke/stretch/pull)? Will this cause more fitment headaches?
Old 04-16-2012, 03:38 PM   #864
sc00by4life
Member#: 97135
Aggressive fitments definitely reduce your tire choices.
Old 04-16-2012, 03:47 PM   #865
rob1n1
Member#: 276425
2013 335is
Alpine White
Yeah... no kidding. Am I pretty much going to have to stretch my tires for this?
I went for this offset because it was listed as a "moderate" fitment... I'm starting to think I might want to go higher on the offset to make my life easier.
All I want to do is fill my wheel wells more in a classy way
Old 04-16-2012, 04:21 PM   #866
sc00by4life
Member#: 97135
this is not a "moderate fitment".
for ease of fitment you want 40-48 depending on width.
Old 04-16-2012, 04:55 PM   #867
nhat
Member#: 140163
03 STi
hellaflunctional
depends on how much you modify your rear fenders.
fwiw, i've got 18x9 +35 with 245/40/18s and i have no rear camber adjustment. my front fenders are unmodified and my rears are rolled and pulled, front -2.7* and rear -1.8*. without pulling, you would need at least -2* with a 235/40/18.
Old 04-16-2012, 05:40 PM   #868
sc00by4life
Member#: 97135
i think you are lowered a bit more than swift's though nhat , which helps increase rear camber.
Old 04-16-2012, 08:39 PM   #869
saskatoonsubaru
Member#: 315852
year: 2006
model: impreza 2.5 i wagon
wheel model:core racing
wheel size/offset:16 x 7 offset +45
tire brand/model:Turanza
tire size:215/65 R16
suspension: stock
fender mods: no
spacers: no
saskatoonsubaru is offline   Reply With Quote
Old 04-17-2012, 09:56 PM   #870
Dinzdale40
Member#: 254306
2004 WRX STi
i have a 2004 STi with the fender lips rolled...
i'm looking at buying 17x8 RPF1's +45. will they need spacers to clear brakes?
i have rota torques that came with the car right now and they are 17x8, but i don't remember the offset...they are pretty close to the calipers and i think they are +48
just want to make sure i'm not missing anything before spending $1k.
thanks
Dinzdale40 is offline   Reply With Quote
Old 04-17-2012, 11:53 PM   #871
Z3RO
Member#: 87542
2002 Bugeye
Heres the car as she looks now.... still rubbing in the rear with the fenders rolled
year: 2002
model: WRX
wheel model: Rota Grid
wheel size/offset: 18x9.5 +38
tire brand/model: Falken ZEIX ZE912's
tire size: 235/40/18
suspension: 06 WRX struts with 2002 tanabe GF210 springs (Rear tophats are from 02 wrx
alignment: Stock
fender mods: front Stock, rears rolled slighty .
spacers: 5mm to clear 2004 STI brembos
Z3RO is offline   Reply With Quote
Old 04-18-2012, 12:32 AM   #872
sunnysid3up
Member#: 294078
2005 Subaru STI
thanks
You should be fine... look at tirerack they had a sale on that size RPF1s im not sure if they still do.
sunnysid3up is offline   Reply With Quote
Old 04-18-2012, 01:00 AM   #873
sc00by4life
Member#: 97135
year: 2002
model: WRX
alignment: Stock
Need more camber, possibly trim the rear bumper bracket.
Old 04-18-2012, 01:10 AM   #874
Z3RO
Member#: 87542
2002 Bugeye
yeah, im gonna go get the camber asdjusted.... Trying to avoid coilovers if possible.
Old 04-18-2012, 08:52 PM   #875
kapp_badbloodz
Member#: 203327
NOOB ALERT!
Hey guys... not new to subaru but new to wheels and fitment. I am looking for either grids or g-forces on my 2002 WRX that will sit on BC BRs w/camber plates. I am looking for something aggressive but not "HELLA" flush. Would still like flush and am expecting some rolling that needs to be done. Just want the aggressive look with nice flush fitment
But if I ask for functionality and drivability with this am i asking too much?
kapp_badbloodz is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
