Old 04-12-2012, 11:09 PM   #176
Fish
RIP Sirkbac
Member#: 869
1987 GPZ-750 TURBO
90' MX-5/11' DGM STi Sdn
whats the second line on the AFR chart?
Fish is offline   Reply With Quote
Old 04-13-2012, 12:37 AM   #177
Shadow27AU
Member#: 287434
Boost and AFR are shown on the same graph. The numbers on the left are for the boost reading whereas the numbers on the right measure the AFR.
Shadow27AU is offline   Reply With Quote
Old 04-13-2012, 01:38 AM   #178
gordyzero
Member#: 56219
2011 WRX STI Limited
SPW
If the 2012 STI has even a slightly safer map. I want it and the dealer said they would install it if it was a option. I will know tomorrow. I am fighting with myself to just throw 5 g's @ this pile and call it a day. But I know its money wasted. Damn. Sad face.
gordyzero is offline   Reply With Quote
Old 04-13-2012, 02:19 AM   #179
561wrx
Member#: 166427
03 wrx
This story sucks bro. Damn it!
561wrx is offline   Reply With Quote
Old 04-13-2012, 09:33 AM   #180
SWP n Gold
Member#: 110783
2010 WRX
2012 STi air:fuel
It's not safe. Like I posted before, it's running 14:1 (lean) until 4,200rpm and doesn't drop to 11:1 (safe) until 4,900rpm. This is because the EJ engine is antiquated, which is probably why they're going to get rid of it for the 2014 model year.
SWP n Gold is offline   Reply With Quote
Old 04-13-2012, 10:17 AM   #181
Traffic Baron
Member#: 316645
2012 WRX Base Hatch
So, 14:1 is not safe? 14.7:1 is stoich for gas though. It should be fine with that. Not max power, but should be safe. But I can understand that some comfort level below stoich should be there on a boosted engine.
Traffic Baron is online now   Reply With Quote
Old 04-13-2012, 11:47 AM   #182
Clark Turner
Member#: 178047
02 WRX STI Spec C
The delayed enrichment is an emissions mandate. I work for a manufacturer and have had to implement this system. Its a simple fix. Even if you intend to leave the car stock. You can get a tune that will provide a large factor of safety by correctly adjusting the enrichment delay and rpm settings.
The TRQ curve dictates when enrichment is needed. Please to do not listen to hacks telling you to zero all these tables and settings. If you do, You end up with poor mileage and lots of carbon build up in the motor from the over enrichment as you drive around town. Gas is expensive. There is no excuse to just waste it
C
Clark Turner is online now   Reply With Quote
Old 04-13-2012, 06:32 PM   #183
s2ktosti
Member#: 70151
2011 WRX Limited
I just installed the Cobb stage 1 on my 2011, it's so much smoother now it's not even funny.
s2ktosti is offline   Reply With Quote
Old 04-13-2012, 07:41 PM   #184
PraetorianGuard
Member#: 230273
2009 WRX Hatch
OBP Tq'd Stage 1
C
Can you explain a little further? Is the EPA forcing Subaru to run a lean tune from 3-4k? I'm assuming it's the same in the WRX, but not a problem because it runs lower boost and TQ?
PraetorianGuard is offline   Reply With Quote
Old 04-13-2012, 07:49 PM   #185
gordyzero
Member#: 56219
SPW
Picked it was up today, 2 miles later the same code came back. This time it was for the other 2 cylinders. The dealer can't figure this out. Im back in a rental car. I have photos of my old cylinder walls. I will post them if I can through the android app.
Old 04-13-2012, 07:54 PM   #186
gordyzero
Member#: 56219
SPW
This is beyond stupid, I am defeated by this, completely. At least the dealer has been awesome about this. There even going to bring it back to me 3 hours away, when they figure it out... I hope they wreck the ****ing thing beyond repair. Friday the 13th really is bad luck
Old 04-13-2012, 08:06 PM   #187
PraetorianGuard
Member#: 230273
2009 WRX Hatch
OBP Tq'd Stage 1
That really sucks. You should call SOA and demand a new shortblock (and an upgraded warranty while you're at it). Yours was clearly built on a Friday at 4:59 PM.
Old 04-13-2012, 08:16 PM   #188
gordyzero
Member#: 56219
SPW
That shortblock had 8 miles on it, It cant be anything in that new block, uhhh right? The tech looked like he wanted to kill himself. He said he was going to swap coils, and see what happens. He cleared the code 3 times and the code back on each road test. He also mention my down pipe cat might be damaged causing back pressure. No on understands whats going on. I think this car can't be trusted. Starting to consider a chat with SOA. The dealer doesn't make these wheel barrels, they just push the ****ing things. I wish SOA tried as hard as the dealership. F'ing corporations.
Old 04-13-2012, 08:47 PM   #189
k mier
Member#: 98000
05 sti [email protected]
Keep track of every visit, every nut and bolt, every receipt, etc. it may come in handy if you have to do something like the lemon law.
k mier is offline   Reply With Quote
Old 04-13-2012, 08:53 PM   #190
Snow Drift
Member#: 75071
4 Train - Subway
Past: 05, 08, 11 Red WRXs
Don't waste your time with SOA they have nothing to do with your car as you are in New England. You need to call SNE (Subaru of New England), they are located in Norwood, MA and control the distribution of cars, training of techs, advertising (feel the freedom!) and warranty claims. Call (781) 769-5100.
Old 04-13-2012, 10:04 PM   #191
gordyzero
Member#: 56219
SPW
Thanks Snowdrift ! I can't seem to post pics from the Android app. Basically, by the looks of things don't you ever use Subaru oil.
Old 04-14-2012, 02:18 PM   #192
SWP n Gold
Member#: 110783
2010 WRX
It is the same in the WRX, and it is just as much of a problem for the WRX in my opinion.
Old 04-14-2012, 03:31 PM   #193
Snow Drift
Member#: 75071
4 Train - Subway
Why don't you see the same ringland failures in the WRX? (most are early 2008 STI)
Old 04-14-2012, 03:40 PM   #194
gordyzero
Member#: 56219
SPW
I wish my ringlands would have been the problem. Week 3 of this ****.
Old 04-14-2012, 03:54 PM   #195
JordenP
Member#: 305041
2013 STOCK WRXSDN
Because WRX stock tunes do not run anywhere near as lean as stock STI's, in the closed to open loop transition.
JordenP is offline   Reply With Quote
Old 04-14-2012, 03:56 PM   #196
Clark Turner
Member#: 178047
02 WRX STI Spec C
All the maps from 04 and on have the delay and run lean into into boost. 08 included.
C
Old 04-14-2012, 04:03 PM   #197
gordyzero
Member#: 56219
SPW
So here was the official explanation on the warranty paper, oh and here what it would have cost me had I tuned it, $4556.73 ..
" Diag. Results found P0303/P0304 cyl #3 and cyl #4 misfire. Completed compression test and leak down. Upon tear found cyl. Hones unevenly worn. Scorned top and bottom of each hone. Replaced engine block and 4 exhaust valves due to not completely sealing post assembly. "
Old 04-14-2012, 04:32 PM   #198
SWP n Gold
Member#: 110783
2010 WRX
Some of the graphs I've looked at show the WRX tune not running as lean as the STi, but still too lean for longevity's sake. And others show AFRs as high as a stock STi. The lean areas of the stock tune vary even among WRXs.
2009 WRX: Stock and Stage 1:
The first graph starts to richen up at the 3,300rpm mark whereas the second one doesn't start to richen up until 3,900rpm.
However, the STi seems to richen up consistently after the 4,000rpm mark.
2010 STi: Stock and Stage 1:
2011 STi: Stock and Stage 1:
And now just to confuse the **** out of everyone, take a look at this:
2009 STi: Stock and Stage 1:
Stock is richer throughout the entire RPM range than even Stage 1. So, who's ready to move on to a different engine platform so we can have safe factory tunes on our cars?
Old 04-14-2012, 04:49 PM   #199
gordyzero
Member#: 56219
SPW
Every map is blank on android, ? I will try desktop vs.
Old 04-14-2012, 06:59 PM   #200
pux888
Member#: 8356
02 STi swap
12 WRX limited
Good for you man, I truly feel for the people that tune a stock car trying to avoid ring land failure only to have an engine fail for an issue such as yours.
pux888 is offline   Reply With Quote
2011 STi Sedan 305/368 EFI Tuned krotondo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-22-2011 01:46 AM
***PhatBotti Tuned: E85'ed 2011 STi, 330whp!! Per Gear Data + Tuning Discussed*** PhatBotti Tuning TKR Proven Power Bragging 54 06-24-2011 10:58 AM
2011 STI OTS map vs Pro tune Jose Gordils Newbies & FAQs 6 05-09-2011 11:08 AM
2011 STi V-Limited LIPS IN STOCK! Yeah we got them! RallySport Direct Vendor 'General Sale' Forum 1 11-08-2010 03:03 PM
07 STI Blown Piston or Ring? 07stilover Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 49 01-25-2008 01:24 AM
