Old 04-14-2012, 12:07 AM   #4651
trishHUYNH
Member#: 248840
2011 Impreza
Originally Posted by imp2.5wag View Post
They paint that kind of stuff all the time
Great! Thanks!
trishHUYNH is offline   Reply With Quote
Old 04-14-2012, 12:40 AM   #4652
premier00000
Member#: 251060
2008 Impreza Outback
Been looking at buying a roof basket since I go camping quite often and also do mobile detailing and I came across this one...
http://www.discountramps.com/roof-luggage-rack.htm
It's the biggest and least expensive I've seen so far, what are your guys opinions on it?
Old 04-14-2012, 01:22 AM   #4653
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Looks like a shady install Lol. 4 u bolts only, sounds like it may come loose or something. Just my .02. If I were to get this I would problably add a little more security and sturdiness.
Navysesal is offline   Reply With Quote
Old 04-14-2012, 03:25 AM   #4654
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
If you get anything rack related just stick to either yakima or thule.
Here's the one my brother uses on his 04sti: http://compare.ebay.com/like/2609914...Types&var=sbar
-This thing is sturdy as hell, plus yakima already makes accessories made specifically for subaru's, so why not? You might need some universal mightymounts if you have the oem crossbars, otherwise you'll have to shell out more for the right crossbars and other mounts.
Old 04-14-2012, 10:25 AM   #4655
premier00000
Member#: 251060
Yeah, I already have the cross bars. The basket is one of the biggest I've seen. Which is big enough for most of my camping gear. (can't fit much inside the car because I'll have 2 kids in there.
Old 04-14-2012, 11:18 AM   #4656
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
For stuff like a rack I wouldn't want to skimp. I would hate to lose a bunch of stuff and possible damage my roof because the cheap basket I got failed.
I have contemplated getting a box since I have discovered that my car can comfortably seat 4. Yet only has enough luggage space for 3. Then I found out the box I want is $700+.
Old 04-14-2012, 11:46 AM   #4657
premier00000
Member#: 251060
I was thinking about getting a box, but if I needed to haul wheels/tires, a cooler, or other things like that, a box wouldnt be ideal. I figured everything that cant get wet can go in the car, and all the other things (can go up on the roof, or even on a hitch basket)
Old 04-14-2012, 01:50 PM   #4658
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
You need a BIGGER car.
Also, keep in mind there's a limit of weight you can carry on your roof.
Fendyman is offline   Reply With Quote
Old 04-14-2012, 03:02 PM   #4659
theoutbackdream
Member#: 301179
2013 WRX Limited
I would say just buy a new car like an outback or a forester. An impreza as a camping car imo is too uncomfortable for 4 people. Imho, the impreza is like a 2-3person camp car, due to limited space.
Old 04-14-2012, 03:02 PM   #4660
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
This is true hah. Although I will have to agree with jourdan, unless you make some modifications to the cheap basket to make it a lot more sturdier.
Plus you could always try and go the mini-trailer route if you get a hitch installed
Old 04-14-2012, 04:20 PM   #4661
DirknJirkn13
Member#: 249696
2010 Outback Sport
Took a couple exhaust videos today, first one is a cold start and the second is after it warmed up.
DirknJirkn13 is offline   Reply With Quote
Old 04-14-2012, 05:11 PM   #4662
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Not bad. Sounds so weird...
Old 04-14-2012, 05:28 PM   #4663
DirknJirkn13
Member#: 249696
2010 Outback Sport
Weird how?
Old 04-14-2012, 06:34 PM   #4664
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
It doesn't sound very deep, it sounds like it's on the verge of rasp, and it gets worse (IMO) as you rev higher.
Old 04-14-2012, 07:02 PM   #4665
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Do you have pictures looking straight at it from behind? It almost looks angled down.
Old 04-14-2012, 07:40 PM   #4666
DirknJirkn13
Member#: 249696
2010 Outback Sport
Look a few pages back...it might be slightly angled but it's probably because of the longer hangers I used so I could clear the bumper.
Old 04-14-2012, 07:58 PM   #4667
premier00000
Member#: 251060
The Impreza IS a bigger car that what I used to have. (Scion tC).
I'm not planning on anything heavy on the roof, just the big bulky things, like a tent, canopy, chairs, and maybe clothes and sleeping bags.
Old 04-14-2012, 11:41 PM   #4668
theoutbackdream
Member#: 301179
2013 WRX Limited
Wow, your exhaust seems a LOT deeper than my exhaust even though its the same one...
Old 04-16-2012, 11:29 AM   #4669
bradyarz
Member#: 272381
2008 Impreza OBS
Decided to try my hand at some fabrication:
bradyarz is offline   Reply With Quote
Old 04-16-2012, 03:32 PM   #4670
DirknJirkn13
Member#: 249696
2010 Outback Sport
Not working?
Old 04-16-2012, 04:08 PM   #4671
bradyarz
Member#: 272381
2008 Impreza OBS
It works, just no action shots yet.
That said, I'm just not entirely satisfied. I was hoping it would be rock solid when I was done, but there's some wiggle. I'm going to try to add some extra bracing at some point.
Also, using the hella wiring harness, the switch doesn't light up. Everything else functions as it should, just no lit up switch. Anyone have any thoughts on that?
Old 04-16-2012, 04:35 PM   #4672
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Pic isn't working for me?!
Old 04-16-2012, 04:47 PM   #4673
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
+1 same
Old 04-16-2012, 06:06 PM   #4674
bradyarz
Member#: 272381
2008 Impreza OBS
hmm. it worked for me across 2 different computers. how's this?
Old 04-16-2012, 06:46 PM   #4675
Digital Dillon
Member#: 288727
2008 WRX premium
I did the same thing a little while ago...
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 03:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 12:57 PM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 10:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 03:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 03:35 PM
