Old 04-16-2012, 02:05 AM   #1
Kevin5
Member#: 281316
2006 Impreza WRX
Default Going Stage 3 BPV Question
06 WRX currently Stage 2 with Cobb ACN91 OTS Map. Gathering parts for a Stage 3 (Vf39 Turbo Upgrade) The TMIC I got had the BPV from the 07 STI it was harvested from still attached. No where in the map notes does it mention BPVs. Any idea to use the 06 wrx's or the 07 Sti's on the new map. (I know OTS maps suck and will be looking forward to a pro tune this year!)
Cobb Hardware notes:
Hardware Requirements: Otherwise stock vehicle with a STOCK INTAKE SYSTEM ONLY, tested with a VF39 turbo, STi or equivalent TMIC, Cobb Tuning turbo-back exhaust system with high-flow catalytic converter. An equivalent turbo-back exhaust system could be used. If the turbo- back exhaust system relieves back-pressure to an excessive point boost creep is possible. If a lesser flowing turbo-back exhaust system is used then boost targets may not be achievable. The addition of any other hardware may make the vehicle perform poorly.
Kevin5 is offline   Reply With Quote
Old 04-16-2012, 02:57 AM   #2
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
Should work just fine for you man. No need to swap it.
BlackJavaPearl04 is offline   Reply With Quote
Thinking about going Stage 3?? Need some answers!! 1badgvr4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-16-2009 10:13 PM
GOING stage 3 need parts. wickedrider Private 'Wanted' Classifieds 4 07-15-2008 08:45 PM
GOING stage 3 need parts. wickedrider Private 'Wanted' Classifieds 22 04-04-2008 03:32 PM
finally decided to go stage 3 AudiTTkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-09-2006 04:33 PM
Stage 3 muffler question, Hey Nathan! Davenow Proven Power Bragging 10 03-22-2003 11:06 PM
