![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 291738
Vehicle:2005 wrx blue |
So here is the story. I have goldies bbs and they are 17x8 +53 with potenza 225/45r17 on now. So these used tires I wanna get are dunlop also 225/45r17 but they were on a different wheel (17x7). Do u know would they fit? I have no clues about tires. Maybe its a stupid question, I tried to search but nothing came up. Thanks for help guys
#2 |
Member#: 72891
MAIC
Vehicle:2004 WRX SDN JBP 96 SVX -2012 Fiesta |
Yes they will fit. Same size tire ....... What wheel the were mounted on before doesn't matter. Just make sure they have even wear ......
#3 |
Member#: 291738
Even on the different rim width? With 1 inch different. Just to make sure. Thanks
#4 |
Member#: 72891
MAIC
#5 |
Member#: 291738
Thanks for the advice
#6 |
#Belieber
Moderator Member#: 140163
MAIC
Vehicle:03 STi hellaflunctional |
unless you own an 05+ sti or have done a hub swap, those bbs goldies are 17x7.5.
#7 |
Member#: 291738
I got the 07 bbs, without the hub swap. According to master oem wheel spec, 05-07 bbs are 17x8. And 08-10 are 17x7. I believe they should fit on ok.
#8 |
Member#: 133855
NWIC
Vehicle:2009 STi SparkSilver Dom Tuned @ MPS |
These going on your 2005 WRX without a 5x114.3 hub swap or conversion spacers? 08+ STi BBS are 18x8.5 my friend.
#9 |
Member#: 72891
MAIC
07 STi BBS will not fit on your 05 WRX. WRX has 5x100 lug pattern, 05 and up STi is 5x114.
#10 |
Member#: 97135
NWIC
#11 |
Member#: 291738
I got wheel adapter to fit to the WRX hub. I am talking the wheel width,because I am trying to get some used tires for the bbs. Between 05+ goldies 17x8 compare to 09-10 WRX wheel width 17x7. They are 1 inch different in the width on the wheel (according to master OEM WHEEL spec) But have the same tires mesurement. That's was my concern if the tires are interchangeable. But MD04WRX said it doesn't matter.
#12 |
Member#: 8365
Vehicle:2005 Legacy GT Ltd Atlantic Blue |
Tires will fit the wheel.
The question is if the wheels + tires + spacers/adapters fit your car. Krzys |
#13 |
Member#: 291738
Hahaha yea that would be another question. But I am sure it will, because I already have them on. I am just getting smaller width tire. I am gonna try and see Haha thanks guys
#14 |
Member#: 8365
"smaller width tire"?
Does it mean you are not getting 225/45R17? Krzys |
#15 |
Member#: 291738
I meant the same size tires was on a smaller width rim and now I am putting 8" width rim. Haha my bad for confusing u.
| Thread Tools | |
| Display Modes | |
| FS : 17x9 et35 5Zigen FNO1R-C, 275 width Nitto NTO1 tires, 275 width Avon street tires | impreza2 | Wheels/Tires | 7 | 11-05-2010 05:33 PM |
| same tire...different circumference | dome | Tire & Wheel | 5 | 01-07-2008 01:32 PM |
| Same Tire Different Speed Rating | Silver04WRX | Tire & Wheel | 2 | 03-03-2004 02:23 PM |
| Same tire noise with two different sets? | Jeremy | Tire & Wheel | 1 | 09-02-2003 10:02 AM |
| MY04 sedan vs. wagon: same or different width front end? | Wagon Joe | Interior & Exterior Modification | 3 | 07-31-2003 01:54 PM |
